Mercedes Dealer $150 off $300 Service
Received 1,466 Likes
It's back. $150 off $300+ in service. Expires Dec 31st 2018.
https://www.mbusa.com/mercedes/servi...n_back_savings
The following 11 users liked this post by cetialpha5:
300SE1993 (12-05-2018),
Artiom Maksimov (12-10-2018),
chassis (12-29-2018),
fingroupb (11-18-2018),
ghlkal (11-24-2018),
and 6 others liked this post.
Received 1,616 Likes
2014 E550-sold 😩
Nice! Thanks!!
B service and driveline fluid change for me, plus I need an alignment after hitting the mother-F pothole. My dealer has a special on the alignment running now, so it's all good.
edit-all services complete and car tracks as smooth as silk again. Clean bill of health from the tech. Thanks for that great coupon!
Is this good for any repair jobs, or only for regular maintenance?
Last time I used it, they were pretty accommodating to make sure that the total bill was enough to use the coupon, I think they just get the money from corporate so they don't care, I just told them up front that I had it.
2010 E350 4Matic
It's the same thing. Any service job is considered repair/maintenance. It won't work on parts though so if you need a key or battery, you're out of luck.
What if they install the battery? Wouldn't that qualify?
Maybe. You'll have to try them. Maybe they discount the service of installing it, but not the battery.
Advance Auto will install the battery for free and they usually have a 25% off discount code so you can take $47.25 of the price of the battery which list for $190 so $142.49 after the code. Current codes can be found at retailmenot.com which has the current code as RMN25. It's probably going to be way more than that at the dealer.
MBNUT1 (11-17-2018)
Anyway, thank you for the reply, that is a good news, I can think of something I need it to be fixed.
2010 E350 4Matic
Ok now I'm not sure what to do. I was going to buy the battery at Mercedes parts counter for $208. Then the coupon came along though I sent for it and haven't received the email from them. Mercedes service told me I needed a battery 6 months ago and wanted over $300 including installation. I figured if I could get $150 off then I could at least get them to put it in for free. Then you bring this offer to my attention. So do you think the Autocraft battery is as good of a battery as the one from the dealer? Probably looking at up to a $75 savings. Complicating things further looks like Pep Boys has a Bosch battery for $176.
Ok now I'm not sure what to do. I was going to buy the battery at Mercedes parts counter for $208. Then the coupon came along though I sent for it and haven't received the email from them. Mercedes service told me I needed a battery 6 months ago and wanted over $300 including installation. I figured if I could get $150 off then I could at least get them to put it in for free. Then you bring this offer to my attention. So do you think the Autocraft battery is as good of a battery as the one from the dealer? Probably looking at up to a $75 savings. BTW do you know the correct group size for the E350?
As for the battery, I believe it's an H6/L3/48 AGM battery. Autozone doesn't seem to have it in an AGM form. Pepboys has several but charges to install it. Right now it's 20-25% off, but might go to 35% on black friday. They have 2 of them, the Champion and Bosch. The Champion is about $10 cheaper, but seems to have the same specs as the Bosch. The Bosch is known to be a decent one, no idea who makes the Champion one if it's the same company or not. Advance Auto seems to have a 3 year warranty. The Bosch/Champion has 4 year warrranty. Standard Mercedes warranty is 2 years on parts which I think is all you get even if it's a battery. If you don't need it installed, I'd get the one from Pepboys, probably around $130 with the 35% off code which you could find on retailmenot when it gets released. I signed up for their emails so I'm always getting their emails with their discount codes.
MBNUT1 (11-17-2018)
2010 E350 4Matic
They were quoting me about 2 hours of labor so they said it'd be around $200-$250 so I told them I had the coupon and afterwards the total was $250 minus the $130 coupon I had at the time. Got a free lunch and had the car washed afterwards so it wasn't too bad.
About battery installation, I know Walmart install for free, but I don't know if they have batteries compatible with MB vehicles, and if their prices are competitive (usually are, Walmart always has lower prices)
2 hours of labor $200-$250???....hmmm, it looks like your dealership has cheaper rates there, over here to my dealer they charge $147/hour.
In the past they've been cheaper for most things, but I'm not so sure once you factor in those discount codes which Walmart doesn't do.
NOT correct
I replaced the battery in my 2010 about 6 months ago. Got it from Pep boys with a 35% coupon, a Bosch battery. I replaced it myself, its not a hard job, nor does it take that long. I don't think you have to worry about the car loosing memory settings since the Aux battery probably backs them up. It is a heavy bugger of a battery though, an extra set of hands getting it in wouldn't be a bad idea.
2010 E350 4Matic
Dealer said they would take the coupon for a battery replacement. They want $323 to replace the battery. I will wait to see if Pep Boys has the 35% off their Bosch battery on Black Friday. If not I will use the coupon for the dealer.
Pick one up at Sams, drop it in your self, piece of cake, 3 year replacement, around $150 .
$323 for a battery? Is it plated in gold?
2010 E350 4Matic
$323-$150=$173. The difference is worth letting them put it in (they are a couple of blocks from my office and my back is a little screwed (sciatica)) plus I will get my car washed. I could have bought it from them for $208 if I installed it myself without the coupon. Will wait to see if Black Friday brings any deals worth doing it myself.
Just my 2 cents.
MBNUT1 (11-22-2018)
I am not telling you what to do, I just want to tell you what I'll do if I was in your situation: I will use the coupon for another repair/maintenance job and the battery I could buy it another place for less than $150 and have it installed for free or I even install it myself.
Just my 2 cents.
Just my 2 cents.
2010 E350 4Matic
Just my 2 cents.
Just my 2 cents.
Anyway Happy Thanksgiving guys.
