C63/C63S AMG
2019 larger screen
Old 11-25-2018, 09:16 AM
japamg's Avatar
C63s
2019 larger screen
Hi all
Do you think will be possible to change the screen? Understand there are many different connections so difficult to do it
Thanks!
Old 11-25-2018, 09:31 AM
ShakyTom's Avatar
C43 AMG Coupe
If you are talking about fitting the facelift wider screen to a pre-facelift, I can't see that ever being possible. Different resolutions, aspect ratios and software design.
The best option for a larger screen, but retaining OEM look and functionality would be an aftermarket android screen. You obviously also get the benefits of things like Google maps, waze, carplay, android auto etc
Something like this would be my pick, looks much better than the super wide ones most people seem to fit.
https://www.aliexpress.com/item/9-33...923580730.html
japamg (11-25-2018)
Old 11-25-2018, 10:09 AM
Rippe's Avatar
polarwhite AMG C63s W205
I think Tobias Moers said in one interview that in AMG the screen needs to be positioned lower, so that the driver can see right front corner. In case one install bigger screen, this will prevent visibility.
Old 11-25-2018, 10:13 AM
japamg's Avatar
C63s
Thanks!
Didn´t consider that option, but now will do...
Old 11-25-2018, 10:18 AM
ShakyTom's Avatar
C43 AMG Coupe
I've got one on the way which should be here Tuesday - I would be more than happy to write up my honest thoughts once it is installed
japamg (11-25-2018)
japamg's Avatar
C63s
Interesting option this one
https://fedju.shop/de/17-w205-ntg5x
Old 11-25-2018, 10:20 AM
japamg's Avatar
C63s
That would be great! Because I am currently looking for one
Old 11-25-2018, 11:47 AM
IdTamer's Avatar
C63 coupe
Also looking at one, would appreciate your review! Do you have command navigation currently?
ShakyTom's Avatar
C43 AMG Coupe
Yes I currently have the stock comand system.
Old 11-25-2018, 03:23 PM
japamg's Avatar
C63s
What´s the size of our current screen?
Old 11-25-2018, 03:26 PM
ShakyTom's Avatar
C43 AMG Coupe
The comand screen is 8 inches.
japamg (11-25-2018)
Old 11-25-2018, 03:34 PM
ShakyTom's Avatar
C43 AMG Coupe
Found this picture of the same 9 inch screen, but installed in a different car.
IMO, it looks better proportioned than the super wide 10 inch one.
Old 11-25-2018, 03:44 PM
japamg's Avatar
C63s
Looks very nice actually!
But the screen in the facelift is 10.25 inch right?
Old 11-25-2018, 04:07 PM
ShakyTom's Avatar
C43 AMG Coupe
It is, but the entire interface is designed for that wider aspect ratio and the corners of the facelift version are much more rounded than the android one.
Old 11-25-2018, 04:12 PM
japamg's Avatar
C63s
Thats right
And have just realised that facelift screen also been flattened...that is something I want too
Old 11-28-2018, 03:24 PM
IdTamer's Avatar
C63 coupe
Smile
Any updates?
Old 11-28-2018, 03:49 PM
ShakyTom's Avatar
C43 AMG Coupe
Have had it half installed but I wouldn't recommend it just yet as my unit has terrible light bleed.; it could just be my unit or it could be a widespread thing. They are currently working with me to try and get that resolved and I will be sure to post my full thoughts once that is sorted (after all, customer service is everything).
Other than the light bleed everything has been positive so far. It's snappy, responsive and integrates very nicely with the OEM functions such as 360 camera and radio.
Its narrower bezels (especially on the sides) and slightly wider aspect ratio make it look much more modern.
Stock comand screen
Unit dimensions: 9 3/4" x 5 1/2"
Screen dimensions: 7 1/3" x 4"
Android screen
Unit dimensions: 9 3/4" x 5 1/5"
Screen dimensions: 8 1/3" x 4 1/5"
Old 11-28-2018, 04:03 PM
IdTamer's Avatar
C63 coupe
Stock comand screen
Android screen
Very cool! What do you mean by light bleed? Did it come with everything you needed to install it?
Old 11-28-2018, 04:10 PM
ShakyTom's Avatar
C43 AMG Coupe
This is the light bleed on my unit (the bright white lighting at the edges - this is a completely black image). It's only really visible on dark backgrounds, but that includes the stock system and using night mode of google maps or waze, so it kinda sucks.
Old 11-28-2018, 06:04 PM
ShakyTom's Avatar
C43 AMG Coupe
Oh and if your car doesn't have aux, it's probably a good idea to add an aux port so that you don't get an audio delay using bluetooth.
Search "w205 aux module" on eBay.
Old 11-28-2018, 08:58 PM
IdTamer's Avatar
C63 coupe
Wow that looks terrible, I see what you mean. How bad is the audio delay with Bluetooth? thanks
Old 12-02-2018, 09:05 PM
IdTamer's Avatar
C63 coupe
Any luck getting the light bleed issue fixed?
Old 12-03-2018, 12:59 PM
ShakyTom's Avatar
C43 AMG Coupe
No updates as of yet, a replacement is on the way but as everything is from China, it all takes time.
They assure me the replacement will not have the same issue and I will be sure to update this post with my findings.
IdTamer (12-04-2018)
Old 12-07-2018, 12:19 PM
ShakyTom's Avatar
C43 AMG Coupe
Started getting dark so these are the best pictures I have for now.
New screen has a small amount of light bleed in the bottom left corner, but it is WAY better than the old one and perfectly liveable.
Old 12-08-2018, 07:39 AM
IdTamer's Avatar
C63 coupe
Very cool! Could you please post a video showing some of the functions? I would like to see how Google maps, Spotify, etc worked with it.
Quick Reply: 2019 larger screen
