E-Class Coupe (C238) & Cabrio (A238) 2017 - E200, E220, E300, E350, E400, E450 [Coupes &Cabriolets]
Projector lights open door
Old 11-26-2018, 07:33 PM
TOM992's Avatar
E53
From Alibaba Express. Fits but a little loose. $11 pair.
arnsbrae (11-27-2018)
Old 11-28-2018, 04:30 AM
stephos's Avatar
MY19 E450 4MATIC Coupé
That does look pretty good and you definitely can't argue with the price
Old 11-29-2018, 09:10 AM
Ari91's Avatar
c238
Hey mate, it does look awesome!! Do you have a link where to buy?
thanks a lot
Old 11-29-2018, 09:26 AM
TOM992's Avatar
E53
https://www.aliexpress.com/item/2pcs...909836633.html
- Cable connectors are not compatible. I have cut the cable and use 2 WAGO connectors.
- A little bit loose. I used some rubber on the edges between the light and the door trim.
Ari91 (12-03-2018)
Old 12-03-2018, 12:31 PM
Ari91's Avatar
c238
Smile
Thank you TOM992
Old 01-22-2019, 01:47 AM
TheBlackParade's Avatar
E class Coupe 200
I bought a set of these but from Amazon, and even though it was not listed as compatible, I was able to make an adapter and fit it, and was surprized it blinks
and makes the remaining red light (in the door) also blink at the same rythm.
When I connected it to a test 12VDC supply, it was continuously ON, but blinks only when fitted on the car.
I checked polarity, battery voltage - and couldn't find the issue. I returned them in the end and ordered another set from Alibaba, this time.
This makes me wonder if the 12V supply for the door lights has some kind of control circuit which would make non standard lights, or lights drawing too much power blink ?
Old 01-23-2019, 07:27 AM
paulgeoghegan's Avatar
paulgeoghegan
Just to say that after seeing your picture (above) I ordered from Alibaba and the connectors were fine and the fitting was easy.
A little loose but not enough to worry about them falling out of place, but I will use a dab of glue to make them totally secure.
For the price, I am very happy.
Old 01-23-2019, 07:40 AM
FedM's Avatar
2019 E450 4MATIC Coupe
Sad that they do not offer the same but with AMG
Old 01-23-2019, 08:09 AM
TOM992's Avatar
E53
4 types avalable
Old 01-23-2019, 08:10 AM
FedM's Avatar
Originally Posted by TOM992
4 types avalable
yes thank you I noticed that already. But I don't like it actually
Old 01-23-2019, 05:07 PM
FedM's Avatar
Originally Posted by benzparts
if you guys are still looking for door lights STAR and AMG i still have a couple in stock:
Genuine mercedes-benz accessories
Will this fit coupe?
Old 01-23-2019, 05:18 PM
FedM's Avatar
nothing said about e coupe here
Old 01-23-2019, 05:22 PM
paulgeoghegan
No, those pictured don’t fit the coupe / cab.
Old 01-23-2019, 05:23 PM
FedM's Avatar
whats your VIN?
Old 01-23-2019, 05:25 PM
paulgeoghegan
I can send a picture of the correct light for the cab. I would imagine the doors are identical on the coupe and cab.
Old 01-23-2019, 05:32 PM
FedM's Avatar
can you post it here?
Old 01-23-2019, 06:05 PM
paulgeoghegan
Projector light for A238
This fits. Aliexpress for around £8
Rate This Thread
Rate This Thread:
Quick Reply: Projector lights open door
