CLS55 rims on an E55?
Old 12-10-2018, 04:05 AM
mondo's Avatar
Alfa Romeo Giulia Veloce
anyone running W219 CLS55 rims on a W211 E55? if so, any issues?
i have someone interested in a swap for the aftermarket 20's currently on my car.
Old 12-10-2018, 06:55 AM
hayseed's Avatar
04 e55
I have them on mine -- a little wider wheel and stance, no issues
CLS55Part Number
A2194011202 9.5 J X 18 H2 ET28
A2194011102 8.5 J X 18 H2 ET25
mondo (12-10-2018)
Old 12-10-2018, 08:06 AM
KAMG's Avatar
2005 C55 AMG (sold), 2005 E55 AMG
I'm running CLS55 wheels. More aggressive stance due to the lower offsets and wider wheels. I have 245 fronts and 275 rears. The rears rub over bigger dips unless I drive raised, but my car is also lowered. I think some guys even run 255 and 285 but they must be not as low. You also have to watch the front as a few people have wrecked their fenders when turning, but they must've been driving slammed and going over some pretty big potholes
mondo (12-10-2018)
Old 12-15-2018, 02:10 AM
G_Money's Avatar
'04 E55 (Gone but not forgotten), '13 C63 P31 (RIP), another '13 C63 PP
They fit perfect and look great.
mondo (12-15-2018)
Old 12-16-2018, 08:33 PM
E55Greasemonkey's Avatar
Received 1,483 Likes on 983 Posts
This place is a joke.
They stick out further than the factory E55 wheels. Some like the look, some don't.
mondo (12-16-2018)
Old 12-16-2018, 08:49 PM
mondo's Avatar
i'm just keen to go back to 18's and the guy with the CLS is sort of interested in my wheels. he'll probably need spacers though looking at the offsets etc...
Old 02-18-2019, 06:12 AM
MercMiki's Avatar
E55 AMG 2004
Originally Posted by [color=black
CLS55Part Number
KAMG do you have those ET's?
Is the rear tire rubbing on the inner or outer side?
Have you lowered the car a lot, still on original air suspension?
Asking bcoz I'm gonna use C218 19" wheels with the following specs on my E55 and trying to decide whether to get 5m/10mm, 7mm/12mm or even 10mm/15mm spacers to avoid rubbing if somehow possible...
A2184011702 9.5 J x 19 ET48 + 285/30
A2184011602 8.5 J x 19 ET34.5 + 255/35
Old 02-18-2019, 09:50 AM
AMG__POWER's Avatar
2023 e450 cabriolet, 2015 s550, 2024 c300 , 2006 E55, 2005 e320, 2007 gl450,
Wheels
Yeah I got them too, 19’s and running 285 in the rear. Along with star lowering, for some reason it isn’t letting me post a pic
Old 02-18-2019, 11:37 AM
MercMiki's Avatar
E55 AMG 2004
Are you using spacers?
Old 02-18-2019, 11:52 AM
AMG__POWER's Avatar
Nope they bolted right on
Old 02-18-2019, 12:28 PM
karpetcm's Avatar
2006 E55 AMG
I almost bought this one a while ago before mine and he told me its CLS55 wheels on there, 295 rears. I thought they fit just right.
Old 02-18-2019, 03:36 PM
AMG__POWER's Avatar
thats bad ***, imma def go with 295 next, although i wonder if 305 will fit
Old 02-18-2019, 04:13 PM
karpetcm's Avatar
2006 E55 AMG
Im sure you can put 305's on but in the pic and when I saw it in person I can tell if it went any wider it would kinda buldge. Every tire is different some tires are wider then others even though they both can be 305's. It does give the car a nice stance though that's for sure. I myself will more then likely go with 295's when I swap out the rears.
Old 02-18-2019, 05:03 PM
AMG__POWER's Avatar
hmm I’ll have to see, if 295’s are better I’ll go with them
Old 02-19-2019, 12:54 AM
KAMG's Avatar
Yes my CLS55 wheels are ET 25 and 28. Lowered on links, pretty sure original struts (car only has 87k miles). They rub on the outside. Pictures are of the car in S2. The W218 CLS wheels may need spacers to clear the inner side as they have higher offsets than the stock E55 wheels. W219 CLS wheels just bolt on with no spacers needed
Old 02-19-2019, 02:11 AM
mondo's Avatar
good info guys, thanks.
i've actually swapped my aftermarket rims for a set of 18" AMG IV style twin 6 spokes from a W207 Coupe since starting this thread. planning on finding some nice 19" rims to replace them with in time.
Old 02-19-2019, 06:18 AM
AMG__POWER's Avatar
I don’t think the 218’s came with these wheels
Old 02-19-2019, 01:56 PM
Yuille36's Avatar
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
These wheels are timeless and look great on either a E55 or E63. And I like that the rears are concave
Old 02-19-2019, 02:44 PM
AMG__POWER's Avatar
Defo, In some ways I like them more than my 65 wheels
Old 02-19-2019, 04:13 PM
KAMG's Avatar
No the 5 spokes came on the 219 CLS55. MercMiki asked if I had the 25 and 28 offsets (from the CLS55 wheels) and I said I do, and that's what's on my car now. Then he said he was trying to fit 218 CLS wheels which had higher offset than stock E55 wheels which is why I said you may need spacers to clear the inside. Hopefully that made sense lol
Old 02-19-2019, 04:45 PM
AMG__POWER's Avatar
oh that makes sense hahah my bad mis understanding
Old 02-20-2019, 07:56 AM
MercMiki's Avatar
E55 AMG 2004
Thanks for all your comments and pics guys, much appreciated.
I think I will get 5mm spacers for the front and 10mm for the rear.
I came to this conclusion after some calculations comparing the CLS wheels to the stock 18" wheel offsets.
W218 CLS wheels, with the following specs:
A2184011702 9.5 J x 19 ET48 + 285/30 tire
A2184011602 8.5 J x 19 ET34.5 + 255/35 tire
Inner Clearance: the inside of the wheel to the strut housing
Outer Position: position of the outside edge of the wheel
REAR
Inner Outer
-15mm -3mm
...with a 10mm spacer...
-5mm +7mm
...and my rear tire is 20mm wider than stock, so adding 10mm per side...
-15mm +17mm
FRONT
Inner Outer
-10mm +2mm
...so with 5mm spacers it will be...
Inner Outer
-5mm +7mm
...my front tire is 10mm wider than stock, so 5mm wider each side...
Inner Outer
-10mm +12mm
W219 CLS wheels, specs copied from hayseed's post
REAR
Inner Outer
+5mm +17mm
...KAMG wrote he has 275's in the rear, so adding 5mm per side...
0mm +22mm
FRONT
Inner Outer
-1mm +11mm
So 5mm/10mm spacers are pretty much optimal when trying to keep the wheel position as close to stock as possible with these W218 wheels.
Based on these very scientific calculations lol I might have a generous 5mm extra in the rear/outside compared to KAMG who wrote hi has some rub there. I'm not gonna lower my car as much as he has, so it might be ok for me like this.
It's gonna be tight on the inside, though, so fingers crossed...
Last edited by MercMiki; 02-20-2019 at 08:06 AM. Reason: Corrected calculations...
Old 02-20-2019, 11:13 AM
MercMiki's Avatar
E55 AMG 2004
Any suggestions where to get decent spacers and longer bolts, preferably as a kit from the same dealer....
Old 02-21-2019, 08:51 AM
bierry's Avatar
E55
Front hubs are tapered
REAR
Inner Outer
-15mm -3mm
-5mm +7mm
-15mm +17mm
FRONT
Inner Outer
-10mm +2mm
Inner Outer
-5mm +7mm
Inner Outer
-10mm +12mm
REAR
Inner Outer
+5mm +17mm
0mm +22mm
FRONT
Inner Outer
-1mm +11mm
The front hubs of the W211 (at least my ‘06 E55) are tapered and NOT 66.56 mm diameter throughout its length. It is only 66.56 mm at the first part (innermost ~3 or 4 mm) of the hub then tapers to less than 60mm diameter for the remaining length of the hub.
I tried 5mm spacers myself and it covered enough of the hub’s first portion that by the time even my stock 66.56mm bore wheel went on, it only contacted the smaller portion of the hub, and was no longer a hub centric fit and there was play. It did introduce vibrations to the steering despite theoretically the lug nuts with their ball seats should center the wheel when torqued. Vibrations eliminated as soon as I removed the spacer and wheel resumed contact with the full diameter of the hub.
Old 02-21-2019, 10:34 AM
MercMiki's Avatar
E55 AMG 2004
Hmm, interesting point.
I would o course prefer not having to use spacers at all, but in the rear I have to, otherwise they will def rub on the inside. Maybe I give it a try without spacers in front first, to see if it works. 5mm spacers aren't that thick anyway.
Quick Reply: CLS55 rims on an E55?
