Doughnut spare tire for 2019 E 450
Did a quick search of threads on this forum but was unable to find the answer – if it is already out there please let me know and I will attempt to close this thread.
My 2019 E450 came with run flat (RF) tires and of course did not come with either a spare or a doughnut. Just returned from two long road trips - one to upstate NY the other to Vermont for a week of skiing. On each trip I had a bit of apprehension: If I had a flat I was more than 100 miles from a Mercedes dealer or tire store that carries RF.
In the trunk is a huge compartment very similar in size to the compartment of my 2016 E350 which had a doughnut in the compartment.
Before I knock myself out, has anyone figured out whether or not a doughnut will fit in this compartment? My tires are 245X45X18.
I realize that the wheel will have to have enough offset to allow the brakes to operate and lug bolt pattern to fit.
Thanks!
Thanks!
Almost 200 views and no suggestions?????????
Am I the only one worried about getting a flat with no spare and being more than 100 miles from the nearest Mercedes dealer or tire store that carries RF?
Sorry, not ignoring you. I just didn't worry about it with the previous cars with RFT's and I'm not overly worried with the current cars.
2015 ML350+2021 E350
Not an easy answer. Below is a link to a compact spare for W213...which has now been discontinued according to that site. Maybe still available elsewhere, or has been replaced/upgraded. Check with your dealer. Not sure, but I think TireRack sell some generic types. I have no idea about the fitment into the trunk well.
https://www.mercedesbenzpartscenter....ItMGwtbDQtZ2Fz
Here's a repair kit. Other sources have similar choices, but be aware that there are some potential negatives to using this stuff.
https://www.griotsgarage.com/product/12v+tire+inflator+repair+system.do?from=Search&cx= 0
There's always MB Roadside...and I suspect that is what most of us are relying on (but hoping we never need).
Both of this links, BTW, came from searching previous threads.
Good luck.
Good luck.
There are many posts on this forum regarding spare tires for the W213. I'll save you some time. Here is a link to my repository of posts regarding W213 maintenance and other interesting tidbits. Look for the W213 Spare Tire file.
As Cao Black posted the lower well in a W213 will NOT hold a spare tire. To verify this simply measure the width/height of the well and compare it to the diameter of the spare tire.
2021 E450, 2020 C43, 2015 C300, 2007 C280
Bring your own tow truck
However, I am not a real New Englander, so I understand that 100 miles does not go nearly as far in the larger states west of the Hudson. Even within 100 miles of Boston, Also, the pleasure of a a Mercedes owner's trip would be seriously reduced by an unexpected end, with he and his partner having to endure a ride back to their neighborhood auto shop in the cab of a tow truck. A ride like that that wouldn't work at all for a family. And some trips don't take well to being expectedly ended, such as trips to a wedding or funeral or trips to an airport.
(Added 01/15/19, 19:33) I forgot to mention that I also have a ContiComfortKit, by Continental. This is a compressor and a bottle of sealant. This was made in Germany; It was the only such kit that did not get reviews like, "broke on first use." The ContiComfortKit has been discontinued and replaced by the ContiMobilityKit. Note that the specifications of the ContiMobilityKit include, "Ensuring an unaltered driving performance for another 200 km at a maximum 80 km/h." That probably also applied to the ContiComfortKit, and I think it is unlikely that any of the lesser, competing brands do any better.
I once drove my previous Mercedes (see my Signature, below) to Denver and back. It had a spare. If I ever follow my dream to visit my sisters in Rochester, NY, Asheville, NC, and Phoenix, AZ (and back!), I guess I will have to use most of my trunk for one of my old wheel/tire sets.
OP:
1. No wheel/tire (donut or not) will fit in area under floor.
2. I took a spare from my former C218 '14 CLS550 (same spare was used in my former W212 '14 E550 as well), MB P/N A 2124013302 18x4.5 et36, removed 155/60-18 (25.3" diameter) donut tire, installed on it bought from the TireRack 135/80-18 (26.5" diameter which is close to W213 OEM diameter) donut tire, and carry the donut assembly (25 or less lbs total weight) in the trunk. Does it take some space? Yes, but less than a full size spare wheel/tire, and I do have piece of mind that am not getting stranded.
Gave up trying a long time ago. It simply does not exist. I have a compressor based can of "fix a flat" type system in my trunk. The other option is putting a spare in the trunk that takes half the space. If you have a major tire failure your only option is the MB SOS or a tow truck. The fact, is that in the last 30 years and 100s of thousands of miles I've only had to change a tire 1 time. Those are pretty good odds.
Thanks guys!
The tire fix, "fix it flat" in a can, I have decided against: In other forums it was posted that unless you scrap the stuff off within 24 hours, the tire and wheel are basically toast and even within 24 hours the TPS sensor must be replaced.
Dear Cao Black: the link to the spare tire: when I changed to 2018 E400 it said the spare tire was not compatible. It was for the E300.
I really do not want to give up the trunk for a spare tire - I need that space for my ski gear!
I will check with my local tire store (Mavis) and tire rack to see if they have a solution. In the meantime I will buy small compressor to try to keep the tire filled, albeit stopping frequently to do so, so that I do not run on the sidewalls of the RF and destroy the tire, and limp to a tire store to have the tire removed and patched.
kmdsid (04-05-2019)
Does anyone know if MB SOS provides any kind of emergency spare tire? Your SOS call must have the ability to identify your year and model to the MB dispatcher; they do greet you by name. If they don't supply a spare, do they do anything? Their own pump-and-slime system?
gfmohn (01-15-2019)
Couple more choices:
https://parts.mbfm.com/p/Mercedes-Be...134000600.html
https://www.oemercedesbenzparts.com/
JTK44 (01-15-2019)
Thank you. How far will they tow? To the MB nearest dealer? Out in the Great Plains of this great land of ours, that can be a mighty long way, podner. When I drove to Denver and back in 2008, I took a look in the booklet of dealerships that came with my Mercedes (the 2007 C280 shown in my Profile). I noticed that in the huge state of Nebraska, there were only two MB dealers, in Omaha and Lincoln. There are several MB dealers in Colorado, but all are either in Denver or else north or south of the city (on or near I-25). So for an MB owner approaching Denver from the East, MB of Denver was the closest dealer -- 495 miles from Lincoln! From a point halfway between Lincoln and Denver, a tow could be up to 247 miles!
Those with real possibility of getting stuck in the middle of nowhere IMHO should really consider giving up part of the trunk space for a full size spare (since donut has very limited capabilities). Even though I have zero chance of getting stranded in the middle of nowhere, over the years I learned to rely on myself as much as possible for anything, hence I carry a spare wheel/tire assembly in the trunk.
Just a sample of several available on eBay: https://www.ebay.com/itm/10-MERCEDES...7wsk:rk:1:pf:1
The following 2 users liked this post by ua549:
Holtgraver (07-30-2019),
mustangn8 (01-02-2020)
Dear threeMBs:
Checked you link to Ebay: I assume that a doughnut that fits an E300 17" tire will also work with and E300 18" tire and and E450 18" which I have all being W213. What do you think?
In your opinion will the doughnut on Ebay work with my 2019 E450 (W213)?
If it does, I have to get the dimensions to see if it fits in well in my trunk.
Frank Rizzo (01-17-2019)
Dear threeMBs:
Checked you link to Ebay: I assume that a doughnut that fits an E300 17" tire will also work with and E300 18" tire and and E450 18" which I have all being W213. What do you think? No it does not. E450 has 14.2 rotor and large caliper (both same as on W212 550 and C218 550) What fits E450 will fit E300 but not vise versa.
If it does, I have to get the dimensions to see if it fits in well in my trunk. Nothing will fit in that area. Have to give up trunk space.
An other possibility (I have done it myself many times over - had full size spare in wheelwell of E550 and CLS550) is to purchase the cheapest 18" that fits E450, currently $118 at the TireRack, and mount the least expensive full size 225/50-18 tire (no typo here, you want to take the least amount of space possible) about $110 at TireRack. Full size spare for E450 all under $230 shipped.
Following are also required: jack A1645800218 and its handle 4145810049.
One more thing. If one is going spare wheel/tire route from W212/C218 550s, do not forget to get five 27mm OEM bolts because for W213, MB decided to use 45mm bolts like they do with S-class and SUVs.
Dear nycebo:
Changing to non RF does not help: You have a flat in the middle of nowhere and you wait and wait for a flat bed to take you to the gas station and then wait for a new tire - our 18" tires are not usually in stock.
With RF you can either do the same (wait) or "limp" in to gas station and then wait for a new tire - having driven to the gas station the RF is not destroyed. So having the RF is actually better not worse than having non RF.
What I was trying to accomplish was, after having a flat is either change the tire myself with a compact spare or wait for Mercedes service to come and change the tire. By changing the tire for a compact spare, I then would be able to drive to the gas station and have the RFfixed and then be on my way.
But this may all be academic: If three MBs is correct and the compact will not fit in the well then I have to look for other options as I do not want to give up all that trunk space for a spare as I need it for my ski equipment.
Mercedes Benz e450 Wagon / Porsche 911 Cabriolet
@JTK44 Unless the blowout is catastrophic, then ContiComfortKit will allow me to "limp" to a service shop. And, I have a much better shot of tire replacement than you do. Indeed, most of the photos I have seen in this forum recently are of catastrophic failure to RFTs. I agree, it's not practical to change it for most drivers, especially if they live in metro areas. However, I hate that MB doesn't give us a choice.
PS - a doughnut won't fit in the underbelly of the trunk. In my wagon, their is a cross beam structure that would block it even if the circumference and diameter were correct.
In other threads I have read that using the "fix it can" makes the tire useless (too costly to remove all the gunk from the tire) and in addition you must replace the TPS and then pay to have the wheel cleaned - get the gunk off the wheel. Those total costs, the cost of cleaning the wheel and replacing the TPS, will be about the same cost of replacing the RF. The advantage to non RF is that the replacement tire may be more readily available.
The doughnut, I think we can all agree, is the better solution.
Thanks, Mercedes
I live in Denver. In 2 weeks I am driving to Phoenix, there is a dealer in Colorado Springs and then Santa Fe before Albuquerque a total distance of 467 miles, then it is 411 miles to the next dealer in Phoenix. How far will MB tow me with a flat tire? Do they send a truck from the nearest dealer's location? That will take 3 or 4 hours if I am half way. MB is obviously used to the compactness of European cities distance wise.
For those who are counting on a ride to the nearest MB dealer, then what? If it is a Sunday or a holiday (when a lot of family trips happen), nothing happens. This problem was discussed in another thread in MB World. One owner commented that he had had to wait for three days for the dealer to receive a tire that fit. It wasn't really compatible with his three remaining tires, so he had to buy another tire when he got home. Certainly, that will be true, if all you can get from the dealer is a runflat. Many dealers will refuse to put a runflat on a car with non-runflats.
The one time I used MB SOS, it was in a suburb close to Boston. I was in my previous MB (see my Profile), so I had a spare. They sent a kid in a subcompact. He couldn't have "towed" a motorcycle. It appeared to be his personal car (no logos or anything).
Bottom line: on a long trip with a family, you really have to rent a car. It need not have a spare. If it does, that's a plus. Even if it doesn't, you can count on the rental company's own repair/recovery service to have a tire tire that fits. Of course, you give up the driving pleasure of your King of the Autobahn that you paid for. Thanks, Mercedes.
jimh6 (06-13-2023)
