S-Class (W222) 2014-2020
S Class W222
Old 01-16-2019, 03:15 AM
Kosiwere's Avatar
S550
S Class W222
what could be the reason why radiator coolant go to washer reservoir nonstop
2015 S550
New radiator was installed recently, what should i look at as this is disturbing.
Old 01-16-2019, 09:32 AM
superpop's Avatar
2019 S63 4Matic+, 2018 E400 Cabrio, wardens car.
Sounds like a plumbing issue or a leak. On my 15 there is a coil that runs through the washer fluid reservoir that I assume is filled with coolant that heats up the washer fluid to melt ice in the window, I would look at that plumbing in and out of the washer fluid holder as that is where it is most likely entering from.
Old 01-16-2019, 10:00 AM
Kosiwere's Avatar
S550
Superpop, do you know the location of the plumbing because there is no leak from anywhere in the car
Old 01-16-2019, 11:39 AM
superpop's Avatar
I would look inside the fluid reservoir. That is the only place where coolant could enter.
Quick Reply: S Class W222
