Nitro Fill Dry Air.. Let the discussions begin.
Honestly I have the following question for DIY'ers.
If one were to purchase a Good Air Compressor with integrated dryer. Is that not the same as Nitro fill.
My basic understanding is that Moisture is what causes the tire Air fluctuations. So, remove moisture = Nitro My theory, Nitro systems cost thousands of dollars and a "Cartridge" needs to be replaced every 2 or so years to maintain the machine.
Hmmmm… So, if I fill a tire with extremely dry air, no extreme expansion / contraction due to water vapor heating up and expanding and contracting when cool....
https://www.popularmechanics.com/car...ogen-in-tires/
30 Gallon ASME Steel Air Tank"NEW" Air Dryer Cartridge System - Up to 98% Dry Air
6.40 CFM @ 40 PSI 5.30 CFM @ 90 PSI
110 Volts / 60 Hertz / Single Phase
=leftThe CALIFORNIA AIR TOOLS 30020DCADC Ultra Quiet, Ultra Dry Oil-Free Air Compressor with Air Drying System is designed to be one of the quietest 2.0 Hp air compressors in the industry having only 70 decibels of sound
So, if you purchase a very amaizing / quiet air compressor with storage as in the
https://www.youtube.com/watch?v=jewURptFH-4
Then connect the following
You now have a Nitro Fill System......
it expands rapidly and unpredictably.
CALIIFORNIA AIR TOOLS 30020DCADC
2.0 HP (Rated/Running)
not the same.
no need for nitrogen filler tires as waste of money.
Variation in tire pressure comes from temp changes and air leakage from tire.
leakage occurs whther nitrogen or air.
What nitrogen is supposed to do is have less rise in PSI as tire warms.
Great if you are a F1 racer and can feel difference of 1/2 psi.
If you google enough you can read both sides of this debate for about a year....
I guess you figured I am on the cheap side and normal air.
one thing to think about..
when they mounted those tires did they do so in a NITROGEN filled room with some guy on 02 breathing machine?
nope..
so the tire had all sorts of normal air in it when the beads were set...then pressurized with N2.
again crazy for normal person... we have been fine with compressed air for 100 years...
save ya money.
nope..
save ya money.
Nice Ride (02-12-2019)
The math and physics:
a) dry gasses expand and contract linearly with temperature
b) a wet gas is a dry gas with water vapor in it
c) water vapor pressure is temperature dependent,
d) but water vapor pressure is not linear in its temperature dependence.
e) as water vapor gets close to the boiling point its pressure rises dramatically.
f) this is a problem on vehicles where the tires get above 200ºF
g) if your tires lasted 10 years, the water may accelerate the decomposition of the rubber.
g) road cars seldom have tire temperatures greater than 150ºF
h) our tires rarely last 3 years let alone 10.
Thus, I put nitrogen in tires that go on race tracks, and I am happy to put std air in my road going tires.
If someone wants to put nitrogen in my road going tires for free it's fine with me.
If someone wants to put nitrogen in my road going tires for $$$ I will tell them to take a flying ***k
The following 2 users liked this post by Mitch Alsup:
hyperion667 (02-15-2019),
nope..
save ya money.
nope..
save ya money.
I had a Nitro Fill on my Escalade in 2009. It has nothing to do with ride quality with the exception of tire pressure fluctuation. Since I see all Seasons, I did notice the air fluctuation in the winter was minimal. When they do a NITRO FILL, the unit lets all the air out of the tires, then does a NITRO fill, at this point the Nitrogen (moisture) content is still not high enough in a tire, so it may only be 80% in the 1st pass, then the machine once again lets all the air out of the tires and fills a second time ( Hence my theory, removing more moisture and filling with more dry moisture free air. ). This should bring the Nitrogen up above 90%, a third drain and fill should bring it up and over 95%, assuming the Machine is working. They actually make a small tester to check the Nitrogen content. My belief is this tester is nothing more than checking the moisture content (Oxygen/Other gasses)
Cannot get all the air out of the tire impossible - if they did the tread would be sucked down to the inside of the rim and ruin tire is my guess.
I have never heard of this mystery N2 machine - Sorry
My race prep shop uses a strap around the tire to do just about what you say, compress the tire--and they do it 3 times: fill to 50 PSI, release air and tighten strap, repeat 3 times; finally adjusting to 35 PSI.
but there is still regular air in the tire.
TO complete fill with 100% N2.
you need vacuum chamber like NASA has....
Throw tire inside on wheel bead not set yet.
Then evacuate chamber... as low as NASA can go which is about as low as you can go (still some air in there but negligible)
then in your Space suit set bead with N2 pressure line. and fill to about 5psi.
Now slowly allow chamber back to earth so tire does not blow up.
Recheck pressure as would be about 14 to 15 Psi higher then when in vacuum.
Complete fill....
Now do not unseat bead again....
my point being is no matter what you have atmosphere inside your tire unless you seat bead & fill it on the space station.
so N2 is waste of $$$ but some sleep better paying for it.
Just fill with clean dry air from your little nail gun compressor and all is good.
Take about a 20 to 30 F degree change in temp for you to notice 2-3 psi change in tire pressure. (depending on tire size)
Complete fill....
Let us see how much:
Put tire on rim: inside there is 0 PSI above 14.2 PSI atmospheric pressure and its 100% air.
Fill tire to 50 PSI and now the ratio is (100%)*14/(14+50) = 21% air
Deflate tire back to 0 PSI inside (14PSI atmosphere--still 21%)
Fill tire to 50 PSI and now the ratio is 21%*14/(14+50) = 4.7%
Deflater tire back to 0 PSI inside
Fill tire to 50 PSI and now the ratio is 4.7%*14/(14+50) = 1.07%
So, there is some air, but 99% of the water vapor is now gone.
Nice Ride (02-13-2019)
Air is mixture ratios is based on volume not pressure.
Not sure what your math is proving.
Since the pressure inside would be based on the density of the gas inside and temp of inside and outside of tire.
So you need to calc starting volume when tire is strapped toght to wheel and there will be some volume of gas in there unless they use a vacuum pump but if they do that the bead witll unseat hence there is some air in there. Then measure how much N2 they pump in to raise pressure to whatever.
Roll tire to mix air and calc new gas ratio.
Let this gas out.
Squeeze tire down again.
Repeat many times.
What do they charge?
Also since there is and always be some air inside the tire in some nook or cranny or where the wheel is not flat.
Next time you have flat tire try and push outside tread to inside wheel and not have any gaps.
Heck cannot do with bike tire unless it has a brand new tube that is empty to start for most part.
I mean where is valve stem on top, side, bottom?
Might have impact on what comes out.
Just not worth the hassle or money is all my point is for normal driven cars heck even track cars.
It was a gimmick to sell something to people - N2 fills $20 or whatever.
Not as popular now as it was years ago as people read up on it.
Let this gas out.
Repeat many times.
PS.
Most good tire shops comporessor systems have very good water separators and or dryers to remove the water vapor from the compressed air.
So it is not such a big deal.
I mean even MB in owners manual says tire pressure when you drive can increase Ithink up to 5 psi due to tire temps.
just not that big of a deal for street driving and street tires.
Nitrogen has a density of 1.205 Kg/m^3 at STP
A difference of only 2%
We then added 50 PSI (measured on the gauge) to this and used (14+50) as the amount of "stuff"inside the tire.
I am neglecting the growth of the tire due to pressure inside, but this is small, nonetheless.
Let this gas out.
Repeat many times.
Let this gas out.
Repeat many times.
This will make the air inside be significantly less! after rerolling the calculations.
I want to know what and how they create Nitrogen and two, is not using a compressor with 98% dry air the same result / effect. No or extremely low moisture = Stable tire pressures since the moisture is what causes the PSI fluctuations. Heat, moisture expands, PSI increases, cool, moisture contracts, PSI decreases.
Again, it was just one of those things that make you go Hmmmm….
Let this gas out.
Repeat many times.
Let this gas out.
Repeat many times.
Boy this thread must me making some readers nuts..
As Mitch was saying ( I think), if you fill a tire and say it has a moisture content of 10% at say 45 PSI, then you deflate to 0 PSI, yes, there is still air and moisture left in the tire. Now you fill again with 98% dry air to 45 PSI, the moisture content will be less, If you do this 2 or 3 times, you would have removed most of the moisture, hence having a tire with 45 PSI, minimum moisture/water vapor. Since there is little to no water vapor to expand when the tire heats up, the PSI would only increase possibly 1 to 2 PSI. The same tire with more moisture/water vapor under the same conditions will increase possibly 2 to 5.
Now when you cool the tire down (Winter), the moisture will condense, lowering the PSI, the above theory in reverse.
So yes, I agree with you that having a compressor with a good Air Dryer attached is essentially the same as a NITRO filling system. I don't know of any shops that actually would waste the money for equipment for general shop air, would not make sense. The worst think you can do is fill your tire from a Gas Station, the amount of water (moisture) in the hose is nuts. This water is now in the tire causing the Rust to the internal Rim, and extreme pressure swings.
The Air humans breath is made up of about 78% Nitrogen
21% Oxygen and 1% carbon dioxide and argon. Trace gasses include krypton, methane, neon, helium and hydrogen.
Cool, I feel like I'm in chemistry lesson
To me , nitro is like ceramic coating to a car , not tremendously necessary but could help set the owner's mind at ease .
Nice Ride (02-14-2019)
