190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
blower works when ignition on ACC but not when on RUN
Old 02-15-2019, 02:24 AM
markmccaughan's Avatar
190e 2.3-16
Weird one for the forum. The blower works fine - so i turn the key on to ACC - blower works ok - all speeds. Then i go to start the car - blower cuts out - when car is running, blower wont work - turn key off - back to ACC - blower cuts in again.
Is the blower wired via the IGN switch other than ACC / Start ?
cheers
Old 02-15-2019, 07:13 PM
Plutoe's Avatar
1999 E300TD
IGN turns the voltage access on
Old 02-15-2019, 08:19 PM
190e 2.3-16
Ok cool. So what does that mean ? It's over-voltage ? Any suggestions where to check ?
Old 02-16-2019, 10:55 AM
Plutoe's Avatar
1999 E300TD
It means that when the key is in the on position it allows voltage to be accessible throughout the car and that means that voltage is accessible when you turn the AC on---think of the ignition switch as a light switch---what happens when you turn the wall switch on and there is no light----what two things could be faulty?
Old 02-16-2019, 03:23 PM
190e 2.3-16
Maybe i wasn't clear
Blower works fine and there is power . All works when the ignition is on accessory position.
when I move to start positon and when engine is running , blower stops. Turn the car off and key back to accessory, blower works again.
So that's my issue .why does the blower work except where .car is running ?
Old 05-11-2022, 06:49 PM
anabel13bermude's Avatar
Gmc envoy xl
Question have the same issue
Question
Did you figure this out , I'm having the same problem with my 03 GMC envoy xl
Quick Reply: blower works when ignition on ACC but not when on RUN
