What is A7 Service, and how much should I expect to pay?
I'm a few hundred miles overdue for "A7" service as my alert screen keeps reminding me. I know it's supposed to be oil changes, but I'm not sure what the "7" means. Also what should I expect to pay for this, and is it by chance included in my 60k-70k-80k package that I bought? Anyone know what the 7 is supposed to be mean?
I recall reading on here before that those numbers indicated the sequence of services (A1, B2, A3, B4...). So maybe the car thinks its the 7th service. Not sure. But they really don't matter as they follow the maintenance manuals on what's needed at each interval.
And it should be included in your prepaid maintenance along with any other required maintenance items like ATF, plugs, engine filter, etc. that are due.
The following 2 users liked this post by thefisch:
JettaRed (09-22-2024),
pierrejoliat (04-07-2022)
http://autocats.ws/manual/sdmedia/me...us_204__en.pdf
2012 E350 A7 Service
I was quoted $850 from the local dealership - and it includes the following:
I will continue to use my independent mechanic.
- Synthetic Motor Oil Replacement**
- Oil Filter Replacement**
- All fluid level checks and corrections are dependent on factory-recommended service intervals for your vehicle’s year and model
- Tire inflation check and correction
- Brake component inspection
- Reset maintenance counter
- Cabin dust/combination filter replacement
- Brake flush & fluid renewal (additional $205.00 charge) *Recommended by Mercedes-Benz during this interval
should be just a normal A service which is Oil change.
The 7 denotes it is the7th service for the car as your next one will be called B8
Read website to see that a B service is an A service plus they replace brake fluid.
MB website: Mercedes Service & Maintenance | Mercedes-Benz USA (mbusa.com)
What is Service A?
With the first visit at approximately 10,000 miles or 1 year whichever comes first – and then approximately every 20,000 miles or 2 years after that - Service A includes:- Mercedes-Benz motor oil replacement
- Oil filter replacement
- Fluid level checks and corrections
Received 1,844 Likes
2015 Model Year Maintenance Manual. Full manual attached.
All of them -- except mine. My service indicator was at A3 after 4 previous service indicator resets at A1, B1, A2, and B2. However, resetting at A3 resulted in B6, 464 days overdue and next service in 25,000 miles. There is some chatter on the internet that the Assyst Plus system has software bugs that requires dealer intervention to correct. Sounds like a great strategy -- make service interval reset procedures ever-changing, provide owners absolutely no information about interval indications and workshop codes, stop publishing service interval maintenance guides, and make sure the Assyst system is buggy so that a dealer installed update is periodically necessary.
my simplified A/B service list for a 2016 E350 4matic. probably same as 2014+ and maybe earlier.
“A” Service at 12 months or 10,000 miles, then every 2 years or 20k (eg, odd 10k intervals)
“B” Service at 24 months or 20,000 miles, then every 2 years or 20k (eg, even 10k intervals)
Every 10k miles or year (A and B)
Additional work:
- Read service data, reset ASSYST PLUS display (A,B)
- Oil and filter change (A,B)
- Check brake fluid level (A,B)
- Check coolant level (A,B)
- Inspect tires (A,B)
- Inspect brake pads, rotors (A,B)
- Check/correct tire pressure (A,B)
- Check/correct spare pressure (A,B)
- Check warning/function lights (A,B)
- Check interior and instrument lighting (A,B)
- Check horn (A,B)
- Check washer fluid (A,B)
- Check exterior for visible damage (A,B)
- Check windshield for damage (A,B)
- Check wiper blades (A,B)
- Check first aid kit expiration (A,B)
- Clean visible area of water deflector (A,B)
- Check parking brake (A,B)
- Check exterior lighting (B)
- Check wipers,washers (B)
- Replace charcoal interior dust filter (B)
- Check poly V belt for wear (B)
- Check vehicle underside for leaks,damage (B)
- Check tires for damage/cracks (B)
- Check condition of steering, tie rods (B)
- Check front axle and ball joints (B)
- Check rear axle and ball joints (B)
- Check spring/strut/shocks (B)
- Check drive shaft flexible couplings (B)
- Check power steering fluid (B)
Additional work:
- Replace brake fluid - every 2 years
- Clean/Lubricate Panoramic Roof - every 30K/3 years
- Replace engine air filter - every 50k/5 years
- Replace spark plugs - every 50k/5 years
- Replace ATF oil/filter - every 60k/6 years
- Replace fuel filter - every 150k/15 years
one thing that bugs me, is there's no interval there for checking or changing front/rear diff fluids... I'm thinking thats a good idea at the 60k mile or 6 year interval.
pierrejoliat (09-24-2024)
replace brake fluid normally listed under B service
Schedule Mercedes-Benz Service
What is Service B?
With the first visit at approximately 20,000 miles or 1 year after the previous service, and then approximately every 20,000 miles or 2 years after that — Service B includes:- Mercedes-Benz motor oil replacement
- Brake fluid exchange
Each service occurs every two years but alternate each year. So, if the brake service is missed at a 2nd service, let's say the first B service, it will be picked up at the next A service and then every two years.
Also, notice the items under the A service also apply to the B service. Then, all of the Other services occur at a specific time or mileage.
My cars have always come with the month and year of the last brake fluid change written with a Sharpie on the reservoir, so I know when it needs to be done again. The Sharpie ink is easily removed with rubbing alcohol.
I will also say to check the maintenance schedule for your specific model and year. For example, my 2014 C350 requires the fuel filter to be changed every 15 years or 150,000 miles, while my 2015 SL400 requires the fuel filter to be changed every 10 years or 100,000 miles.
Great info above! Curious that while tire checks are listed, nobody has added tire rotate/balance. Obviously there are constraints if you're staggered, but I have my square setup done every 5K miles. I have 22K on my current set and am 8/32 on all 4, down from 12/32 new with no unusual wear. Dealers usually charge extra but many tire dealers do it free on tire sets they sell.
A MB UK forum post (https://forums.mbclub.co.uk/threads/...roblem.278284/) discusses a bug on the 5th reset cycle. Last week, I was at "A3" (the 5th -- A1, B1, A2, B3, A3), and resetting caused my Assyst to register "B6, 464 Days overdue, 40,000 km". I wasn't able to change it until after I'd driven some distance (~160 miles) a couple days later. It's now sitting at "Service B due in 359 days". I keep my own service records and do A/B service every 5K miles or 12 months, whichever occurs first, so as long as I'm not getting overdue indications at startup, I don't care how buggy Assyst is.
JettaRed (Today)
