Spring Perch State Evaluation
Hello!
My 97 E200 was having its front brakes and rotors replaced at the local Mercedes dealership and as the car was lifted I requested a check on the Spring perches. Was able to snap this image to immortalize what I saw.
I pointed out the rust forming at the lower right side of the cup to the technicians. They told me they were fine and proceeded with showing me their strength by trying to wiggle them without being able to move them an inch (not an extreme force of course).
I already have both cups new from Merc, should I replace them asap?
A little bit of context, this car spent all its life on the Lebanese coast in the Mediterranean, never seen salted roads in its life. Also, it underwent a comprehensive renovation that lasted around 6-7 months, and at this point I just want to enjoy driving it a bit instead of keeping it at the dealership
Looking forward to your opinions folks,
Thanks!
Thanks!
Received 1,729 Likes
1922 Ford Model T / no OBD
What your picture shows is bituminous compound showing some rust seeping thru.
For proper inspection you need to scrape it, but experience says that once you have rust visible on the surface, there is much more under.
Can the coating be reapplied once it is scrapped in case the rust damage isn't that bad? I'll flag this during the next proper service of the car. I don't want to go ahead and do the repair if it doesn't need it.
The MB coating seems to be much better than anything I could find, but than - living in dry climates - rust protection is not my priority.
POR products seems to have best reviews, so research what might be the best.
But not only I see the rust signs, but also some indication that it might be patched in the past.
Definitely worth inspecting if you plan to keep the car.
I've had new springs ready to be installed for a while now, doing them in parallel to this repair would be great, will keep you posted.
