C43 'launch' question - transmission damage ?
Given that there is no launch control in the 2017 C43, hard braking then mashing the throttle is the only option.
At what point can doing this damage the transmission ?
How do others attempt this ? At what RPM do you release to get a good start and where is Boost showing as ?
AMG C43 3LV6 (02-21-2019)
If youre needing to launch your C43 regularly you probably bought the wrong car. Ive never launched it myself and while its tempting, I also dont want to cause permanent damage to my engine.
I got my car tuned therefore just wanted to know my new 0-100 km/h time, it's not a regular event at all.
Pre-tune was 5.1 secs, post tune 4.7 which I think is pretty poor hence my question. My attempts were done at no less than 28 degrees C (82 F) which I think is not optimal, I'll give it another go when the weather cools down :-)
don't hold past 2200 rpm and you'll be fine on the brake boost. I don't find my self launching all the time as a courtesy for the driver behind me. I usually try to launch only when its just me. I am tuned so spinning all 4 wheels is not an issue and don't want to throw rocks at the car behind me. as long as you aren't doing it every day I wouldn't worry about it.
You're very polite to those behind you!
2021 Mercedes C63s AMG Coupe
I have launched the car more than 500 times I am sure. (8 track days with an average of 20 hard launches, and countless dragy sessions of me in an empty road) and nothing has changed so far. Ofcourse how you launch matters a lot. If you hold the RPM at anything above 2000, it is a problem, which a lot of people do. Holding is bad, cant emphasize that enough. The correct way is to press the gas pedal, and when the rpm needle is swinging towards 2200, the moment it reaches it, let go of the brakes. (3.4s 0-60, dragy verified ).
May not be the launch most are looking for however I find if you activate the "HOLD" brake feature by depressing hard on the brake at a stop and taking your foot off the brake, then when the light turns green go hard on the accelerator you get a more aggressive launch from stand still.
2004 E55 K Wagon &. '96 SL500
The car will protect itself if you are getting close to damaging it. The main strain is on the torque converter and drive shafts.
The torque converter is basically a fluid coupling device, meaning there is no mechanical connection between in- and output shafts. Instead fluid is used by means of a pump (input shaft) and turbine (output shaft) to transfer (or convert) torque.
So when you do launch control or brake boosting (holding the brake and mashing the throttle) what happens is that the pump is rotating, but the turbine is stationary. This causes “shear” which results in fluid friction and in the end heating of the transmission fluid. And heat is the enemy of transmissions! So if you do it for long, the transmission fluid will get very hot and this can cause damage to the transmission, but if the fluid gets REALLY hot (we are talking red area hot) the engine will limit torque to reduce the risk of damage to the tranny.
The shafts are under a lot of strain in the split second you release the throttle, so they can be damaged, but most modern, high powered, cars have quite strong shafts.
So in the end, don’t do brake boosting when the tranny is cold (because you should not strain any part of the car when fluids are cold) and don’t do it when the transmission fluid is very hot, but avoid these pitfalls, and it probably isn’t going to do much damage.
Manual cars is a completely different bag of worms as the clutch is a mechanical coupling device so when engaging it, the speed difference between the input and output cause A LOT of friction. If the torque is higher than the clutch friction, it results in slip and more friction which will cook the clutch! So when you dump the clutch at high revs, this causes a huge torque on the clutch and this wears the clutch down!
Not all new performance cars are that over built though .
For example the C7 RS6 have weak driveshafts and many tuned cars have broken theirs.
There are bound to be exceptions but generally these cars are pretty overengineered because they are going to be driven hard. But eventually a bean counter somewhere will say “no need to put 50% over-engineered drive shafts on” and they will end up with lots of failures and lots of dissatisfied high end customers! But look at the power people are pulling out of some of these cars and the amount of extra abuse the whole driveline will have to cope with! And some of those RS6’s are putting out 800+ hp and 1000+ Nm of torque, which is just crazy!
