Recommendations - Is a 2012-2015 ML350 Bluetec worth buying?
Old 02-20-2019, 10:17 PM
clevedonML's Avatar
Mercedes-Benz ML320 CDI SPORT
Hi there, looking at an ML350 Bluetec (used)? Is it worth looking at at all? I know there has been some problems with the Bluetec engine on these? Just wondering if anyone has had an actual good experience with one of these. I have an 08' ML320 CDI Sport that i keep well serviced and has been going pretty well, is a solid SUV. Any suggestions recommendations would be greatly appreciated. Kind regards from Clevedon, New Zealand.
Old 02-20-2019, 11:06 PM
kombifan's Avatar
2010 Mercedes GL450; 2000 Mercedes ML55 AMG; 2016 VW GLI SEL Stick!!!
the main problems you hear about on here are unique to the US market due to epa regulations.
You'll have some common issues like the adbkue tank heater....but being in nz you should be OK.
Go find one!
Best of luck
Old 02-23-2019, 07:43 PM
C280 Sport's Avatar
Location: Saratoga Springs, New York & Sarasota, Florida.
MB’s
Just get a 2015 ML350 gasser. You will not have the issues like with the BT.
Old 02-23-2019, 08:00 PM
kombifan's Avatar
He’s fine. Diesel should be fine.
I can imagine there is not a lot of choice In New Zealand. .
Old 02-24-2019, 11:26 AM
Diabolis's Avatar
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
Adblue tank heater failures seem to be prevalent among cars that are often parked outdoors in sub-zero temperatures where the DEF fluid in the tank goes through a lot of freeze-thaw cycles, but they do happen. The (earlier) oil cooler seals are also known to fail, although you might luck out with a later model and end up getting one that has the Viton seals from the factory which are less prone to leaks.
The diesels are great cars for as long as (1) your diesel is not full of corn syrup, (2) you regularly change the oil and engine air filter, and (3) you don't have completely unrealistic zero-maintenance expectations... in other words, if you're not American.
There is a tendency among American consumers to expect to spend exactly zero dollars on R&M and an expectation that things ought to last forever with no maintenance, and when this doesn't happen (in particular when they buy used goods that are already worn out) there is lot of weeping and wailing and gnashing of teeth. Unlike American pickup trucks, modern cars - and in particular luxury cars with many creature comforts and high-tech features - are no longer simple mechanical pieces of equipment that have as many parts as a hammer. With any German or Japanese car, if you budget on spending ~5% of the new purchase price of the car annually in R&M after the warranty expires, it will go on forever. If you expect to buy a used ML for new Kia / Hyundai money and are not prepared to spend money on R&M, then you are going to be disappointed.
Quick Reply: Recommendations - Is a 2012-2015 ML350 Bluetec worth buying?
