Faulty SBC - compatible replacement E220 W211
E220 CDI W211.006
Hello,
I have a E220 W211.006 (2004) 150hp Mercedes. VIN WDB2110061A581551 There is an issue with the SBC system and I want to replace it. The OEM code mine has written on it is A 005 431 33 12. I am looking for a second hand one, but I can't find and exact match. For an example I found: А 005 431 72 12, A 005 431 80 12 , A 005 431 81 12 and others.
I am looking to replace the part without the need to update the software.
Are these compatible numbers ?
Does anyone know if they will work if they are just replaced ?
Is there a list somewhere with interchangeable model numbers?
Thanks in advance!
Thanks in advance!
Received 1,466 Likes
Can't really help you, but someone else might. If you wanted to figure it out yourself, you probably need a copy of EPC/WIS. You can buy a knock off copy on eBay for around $6 in the US, not sure what it would be in your country. You just download it and install it on your computer. EPC would tell you what part number you need once you put in the VIN of your car. They remanufactured those parts so the replacements may have different part numbers. Sometimes parts were also updated with new part numbers so that's why you need EPC to figure it out. WIS would have the documentation on how to do the repair. It may still need to be coded even if you get the exact same part, you'd probably have to read the WIS to figure that out.
Received 4,415 Likes
'71 Pinto
Not sure why 0054313312 is not listed but MB Xentry shows: 0054317912, 0054319692, 0084313812, and current 0094312612. See attachments.
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
The extended warranty on the SBC is only for the US so it most likely doesn't apply to OP.
E220 CDI W211.006
That question goes to everybody - are the part numbers the same in USA/EU ?
'71 Pinto
I would think so, print query provided (post 3) is specific to your VIN.
'71 Pinto
0054317312 & 0054318112.
