Lower Control Arm Ball Joint HELP
I've literally searched everywhere for this and tonight spent 4 hours staring and fiddling with the ball joint that needs to be compressed/pressed out of the lower control arm/steering knuckle area. To be clear,the knuckle area contains front lower control arm that has the ball joint built into it, where you just need to separate it to replace it. Then there is the tie rod part which I am not replacing. There is then the lower control arm which houses the sway bar/airmatic shock, etc. This lower control arm sits on top of a ball joint that is compressed into the steering knuckle.
For those of you that have succeeded in pressing this ball joint out, what tools did you use and how did you gain "leverage" upon it? Because others on some posts commented they succeeded with only autozone generic ball joint press tools, I just purchased this generic kit off Amazon:
However, no matter how hard a turn the breaker bar attached with some counterforce, after 1-2 full rotations with the breaker bar, I seem to have reached a terminal force that I cannot overcome? I take a peek and the ball joint has not even moved one bit.
Do you need to remove the front lower control arm to press out the ball joint? I see some people do it and some don't on the forums. The cup seats perfectly fine when positioning the ball joint press.
Thank you
Thank you
That lower control arm, sometimes called spring control arm, has to be removed from the knuckle before you can press out the ball joint. Because of the amount of force that is holding the ball joint when attached to the knuckle, a normal ball joint clamp will not be strong enough to free it. Since you are replacing that ball joint, I recommend you either hammer it off the knuckle, then use the ball joint tool to get it out of the control arm. Or use a ball joint clamp to get it freed off the knuckle and then proceed.
Thank you for your reply. I am having trouble pressing out the ball joint as the ball joint press won't go any further. Getting the control arm/spring control arm off the ball joint is no problem. Just having trouble pressing out the ball joint out of the knuckle.
yeah mine was in there really good, I finally popped after what seemed forever (and shot me right in the chest when it did)
that was what I saw used in the one tutorial I read (Pelican Parts maybe?)
it seemed it kept turning without moving, but once it went, it was impressive.
Thanks for you reply, but the one you linked to, is a ball joint separator, which separates the control arm from the ball joint. I was inquiring about pressing out the actual ball joint itself. I keep turning, but it has reached a terminal force when it just won't budge. If I try to turn it more, the silver c clamp turns with it.....
Thanks! Is that set-up how you pressed out or pressed in the ball joint?
This is the ball joint I am talking about:
Yes that ball joint. I both pressed it out and back in. The tool comes with several different size adapters. You'll have to figure out how to use them. Make sure to heavily Grease the screw on the C clamp and I had to use an impact gun to make it work. It takes a lot of force, more than I could apply with my hands.
There were three rings right? When pressing them out, did you use the small, medium or large ring? I keep trying with the medium ring.....
When this happened to me
It was that I was trying with the adapter that looked like it fit correctly but in fact did not. I rounded the large bolt in the c clamp, really struggled. I wound up using the one adapter that seemed slightly too large and not well seated and it came right out. The adapter Has to sit around/ outside the lip of the ball joint and touching the arm so that when you press from below the lip of the joint does not get stuck on the adapter. The top adapter effectively is the catch for the joint.
If the lip gets stuck on the adapter you will never be able to remove it. I hope this helps.
