C63 AMG (W204) 2008 - 2015
2011 C63 - wheel setup
Old 03-18-2019, 11:46 PM
Gpow's Avatar
W204 63
Hey guys,
New to channel, I was hoping to get some help with wheel specs. Came a across a set of wheels with the following specs:
F- 19x8.5 +30
R- 19x9.5 +35
Do you know if this will fit on my w204 c63, currently on stock height.
Cheers gpow
Old 03-19-2019, 01:09 AM
thebug44's Avatar
2012 P31 C63
Originally Posted by Gpow
Hey guys,
F- 19x8.5 +30
R- 19x9.5 +35
Cheers gpow
good info here
https://mbworld.org/forums/c63-amg-w...el-thread.html
Old 03-19-2019, 11:30 PM
Airspeed1's Avatar
2011 c63
For the rear that offset would be very aggressive +45 is as far as I would suggest based on my experience with the car
Old 03-20-2019, 09:30 PM
Sick AF's Avatar
'12 C63 Coupe
F- 19x8.5 +30
R- 19x9.5 +35
I'm about to order a set of wheels with the exact specs you mentioned. Its only roughly .4" more aggressive than the conservative recommendation.
Curious to hear if anyone else has run this spec ?
Old 03-20-2019, 09:57 PM
AMGonFire's Avatar
2012 c63 AMG, 2011 GLK 350, 2019 GLS 450
It will not fit. The front maybe. The rear no way. Unless you are going insane stretch and camber with roll fenders and even then.
Old 03-21-2019, 11:05 PM
rexiferp's Avatar
c63 amg
Im running +45 and it's rough. Would probably do +47 myself next go around.
Old 03-22-2019, 02:45 PM
Former Vendor of MBWorld
Blaque Diamond Wheels's Avatar
2014 S63
Front: 19x8.5 +32
Rear: 19x10 +38
Blaque Diamond BD-3
Old 03-22-2019, 04:20 PM
toosteeley's Avatar
Present: 2019 C43 Estate
^ It would probably help the thread starter more if you included offsets.
Old 03-22-2019, 05:40 PM
2014 S63
The car above is running an aggressive set up of:
19x8.5 +32
19x10 +38
To answer OP's question, we would recommend running:
19x8.5 +32
19x9.5 +42
Old 03-23-2019, 07:36 AM
Vladds's Avatar
2010 C63 2019 GLA45
19x8.5 +32
19x10 +38
19x8.5 +32
19x9.5 +42
And this offset is available with no spacers and no spacers were used in the picture, right?
Old 03-25-2019, 01:56 PM
2014 S63
Absolutely, no spacers on the set up shown.
Old 03-25-2019, 07:38 PM
AMGonFire's Avatar
Front: 19x8.5 +32
Rear: 19x10 +38
Blaque Diamond BD-3
what!!!!!!! No way that is a 10 inch wide wheel running a 38 offset. Please do that op please cause I will bet you all my money in my bank account it rubs like a mo fo.
Old 03-26-2019, 04:51 AM
ertimark's Avatar
C63 AMG Coupe
The FRONT is OK, but I also bet you cannot run less than +50-52 offset in the REAR with 10 inch wheel with no rubbing imo.. (with factory fenders).
Old 03-26-2019, 02:02 PM
2014 S63
There are no rubbing issues with the set up. Rubbing does occur when driving over bumps as excessive speeds and so fourth, but if you look at the tire, you can see hardly any wear from rubbing.
EDIT: Rear is a +42****
Here is a closer look:
Old 03-26-2019, 02:04 PM
toosteeley's Avatar
^ That looks more like a +48 offset with a 255 tire to me
BLKSHRK (03-26-2019)
Old 03-26-2019, 02:14 PM
2014 S63
Correction; the rear is a +42. My mistake, I apologize.
Quick Reply: 2011 C63 - wheel setup
