I'm I in trouble?!
2014 e250 bluetec
I'm I in trouble?!
Hey guys it's awesome to be here. I just bought a 2014 e250 bluetec and the engine light came one with the following:
- adblue malfunction
-soot particulate problem
-02 sensor
- adblue system problem
How do I go about fixing these issues and how serious are they???
thanks guys
-02 sensor
thanks guys
-02 sensor
thanks guys
-02 sensor
thanks guys
2014 e250 bluetec
How serious are these problems though?
A 02 sensor and probably the adbkue heater.
It's the beginning of a laundry list of serious problems. If possible ask them to take it back. It's a sacrifice and an understanding you'll have to gauge yourself to see if it's worth keeping.
2014 e250 bluetec
I mean the things you mentioaned are very vague, but I can guess you need a new dpf, which are very hard to get a hold of.
I'll write it more detail as to what the codes are:
- Adblue system has a malfunction (internal component fault)
-Adblue control unit malfunction (sporadic fault)?
-Oxygen sensor fault
-soot particulate fault
I pray to God they fix it or else I'm screwed
Received 1,729 Likes
1922 Ford Model T / no OBD
Code numbers would allow for precise answers, but bad news is that even those engines have good reliability - their emission systems don't
To add salt and pepper to the wound - parts are very expensive.
Roughly you might be facing DEF tank and DPF replacement.
We are talking north of $8000.
Get the codes and keep on top of your warranty.
Buy ScanGauge who will allow you read soot level and DPF regeneration.
2014 e250 bluetec
Hey man thank you for the reply, I have the codes from the scanner :
P204
P140
P13d
P2A0
p24A
are you familiar with these codes ?
These are generic obd2 codes. Youll need a mb specific scanner to get the in depth knowledge that you'll need to find out what's going on.
2014 e250 bluetec
OBD codes have 4 digits after "P" and I can't make anything from what you posted. Do you have description on your scanner? Can you take a picture?
If you turn DEF off, the computer will put car in countdown. You will have 10 starts to fix the issue, or car becomes the brick.
Now let's talk about the warranty. Can you get your money back?
Doesn't look like this is going to be easy, or cheap fix.
If the seller refuses, take the car to dealer and have them estimate the repairs.
2014 e250 bluetec
Now we can see whole code number.
All those are stored codes, so they can't trigger CEL. What does?
Anyway, so many codes indicate lot of troubles with that car and as I said -not cheap ones to correct.
When i bought my new diesel I thought I was pretty smart. Great fuel economy, lots of torque, engine that will last hundreds of thousands of miles with proper maintenance. I wish I had known what I now now. Sorry for your troubles, but I would never buy a used diesel car of any brand unless it was almost free. My 4 year old ML is about to exit the factory warranty and it's worth less then a third of MSRP. For the last 6 months it has been nothing but trouble. Just got it back from the dealer for the second time in the last 6 weeks. I have zero confidence that it won't let me down. I know it won't matter but I'm sending a letter to MBUSA to tell them how I feel. I have bought 3 new MB cars in the last few years and will not buy another.
The only gasoline engines I have are boat and generators.
Diesel for long years was for my family the cheapest way for transport and even now- with low driven miles they might not make economical sense, but I still like them.
The 440HP engine in my F350 is a beast (who I can't hear in the cabin), while 40 mpg quick MB cruisers are really desirable.
In last couple of years new tools come on the market, so it is much easier to monitor DPF regeneration, what was main issue in the past.
DEF tanks might be low-reliability items and it is really bad that small part inside require whole tank replacement, but than worse come to worse, even if you spend couple thousands on part every few years, you will get your money back in fuel savings and smile on the face.
Lot of gasoline W211 have similar issue with fuel tank replacements.
Than more and more tuners offer DPF and DEF delete. This is gray area, but becomes valid option.
Still dealing with all that takes lot of homework.
Meaning it is not for everybody
2014 e250 bluetec
Hey buddy thank you for the reply. So if I understand correctly I can just find a tuning shop and just delete dpf and def?? Would that cause any issues to the car though ? If not than I would consider it since I've read replacement for those is very experience and I just bought it!!!
So what happen to the warranty?
Read the topics about DPF delete. It works when it does, but so far each tuner who takes the job -has some problems down the road.
Than you did not fill up your location, so we don't know if you have to smog your cars?
2012 X6 35i Sport, 2013 ML 350 BT, 2019 4Runner TRD Pro, 2020 CRV-AWD
I really am curious to see how our BT holds up after the deletes, spin-on oil filter and high-zinc oil.
And btw, I've had zero issues since doing the deletes. It's only been 6 months or so, but so far, very satisfied. Tune by Malone Tuning
You guys started driving MB diesels too late.
I started with W123 and when I sold it for $3000 with 300k miles, now looks like it might be worth double what I sold it for.
Just last year my father donated perfectly running 30 years old W124 with 300k as well. Nobody would offer $2000 for it.
I had 3 of W210 diesels in my family and had contact with 2 buyers. Those cars are probably over 300k miles or way above.
Ross on other forum drives W211 E320 cdi and at short of 1/2 million miles - he had to rebuild transmission.
I still have faith in German engineering and to my knowledge the OM651 short blocks are bulletproof.
it is the US-forced emission system that has baby teeth.
I plan to keep the car with DPF delete till electric MB will flood the market
Doubt the diesel 40-50 mpg can be improved by much.
2014 e250 bluetec
I called this tuning shop and asked him about the DPF delete and he told me it costs $5K.. holy **** at this point its almost better to spend the money and fix it. Unfortunately my warranty is out of the question because I surpassed the kms. so now I really dont know what to do. Should I delete the warnings and hope itll fix itself!? ****
Which shop?. My tune cost me $1400 including a custom bypass for the DPF using my flanges.
And no, fixing that crap will allow it to come back at you in a couple of years.
2014 e250 bluetec
