C450/C43 AMG
Spacers for 2019 Sedan
Old 03-22-2019, 10:13 AM
navalos's Avatar
C43 AMG
Yes, there are many threads about spacers and offsets, I'm aware. I'm also aware that none of them have a definitive answer to my question: I'd like to go 5mm front and 15mm rear on my 2019 C43 Sedan (with OEM 19" AMG twin 5-spokes). Are these 2 sets the correct ones to purchase? Additionally, where and what size/type of extended lugs would I need?
https://www.ecstuning.com/b-h-and-r-.../1055665sw~hr/
https://www.ecstuning.com/b-h-and-r-.../3055665sw~hr/
Thanks in advance guys.
Old 03-22-2019, 10:48 AM
Juniorp187's Avatar
C63 S AMG
On my 2015 c63 I think I have the same setup 5mm and 15mm. I don't remember if the installers had to get bigger lugs. I think they did, it was the SUV ones like the GLE for example. They fit perfectly and must be radius. I found lock ones online and cheaper. The bigger the better because you can cut them if needed. These were the ones I put on my w205. Make sure its same metric and radius for your car.. I think they are 45mm shank (length of the thread)
Amazon link below.
Amazon Amazon
Old 03-25-2019, 08:48 PM
BMS
Former Vendor of MBWorld
BMS's Avatar
2018 C63 Sedan
We've found 12mm to be the perfect size, and have plenty in stock.
http://www.burgertuning.com/mercedes...l_spacers.html
Capt Slo (03-26-2019)
Old 03-26-2019, 12:33 PM
Capt Slo's Avatar
2019 C43 Sedan and 2020 Volvo V60 CC
I'm rocking the stock 18" wheels on my 2019 C43, what size would you recommend for a flush fit? I'll order them today from you.
Old 03-26-2019, 01:58 PM
BMS
BMS's Avatar
2018 C63 Sedan
We run 12mm all around on our C43 and C63... Very happy with the look.
Old 03-26-2019, 03:12 PM
alexasa's Avatar
c
12mm is too aggressive if you're not lowered.
Once again BMS more interested in a sale than providing good information to customers.
Old 03-27-2019, 12:56 PM
Capt Slo's Avatar
What would you recommend?
Old 03-27-2019, 02:18 PM
alexasa's Avatar
c
18's actually have a more aggressive offset than the 19's in the rear by 3mm. I would probably recommend a 10mm (a 12mm would be fine too).
The front is the same, but 12mm up front looks like this: (which is mexi flush if you ask me. I typically try to sway people towards a 5mm spacer as anything between 5-10 is iffy because you can't use the factory hub to center to the wheels.)
Here is a 5mm on my old car:
I also have pictures of 17mm on the rear to give you a better idea of what a 12 would look like (I have 19's so 17 - 3 = 14, which is 2mm more aggressive than the 12 that you are tentatively debating).
Old 03-27-2019, 03:05 PM
BMS
BMS's Avatar
2018 C63 Sedan
We just gave our opinion on what works and looks good with our car, not sure what information we gave is wrong.
Being aggressive is what they usually want when going with spacers, no need to purchase if you don't want them
Old 03-28-2019, 05:05 PM
AlabasterC55's Avatar
2019 C43 AMG
2019 c43 Sedan here with 19" twin spoke wheels. Going to be lowering on H&R springs. I have been searching the forum and i know 10mm and 12mm spacers does not work.. so what is is the best combo to run for a non rubbing flush fitment? Thanks!
Old 03-28-2019, 06:39 PM
Finite's Avatar
B9 Allroad, Velar
There are certain 10-12mm spacers that don't work, for example ECS but there are others that work just fine. I plan on lowering on H&R springs, and doing 5/12 on the 19" multi-spoke wheels.
Old 03-28-2019, 06:48 PM
2019 C43 AMG
If that is the case do you happen to know of a vendor that sells spacers that have been proven to fit in those offsets?
Old 03-28-2019, 06:54 PM
Finite's Avatar
B9 Allroad, Velar
This post has tons of information, but the entire thread is worth a read. You specially need to ask for the special 12mm spacer if you use H&R. Almost any 5mm spacer should work on the fronts.
https://mbworld.org/forums/c450-c43-...ml#post7272599
Old 03-29-2019, 08:08 AM
CClement's Avatar
2009 C230
It all depends on the wheels you are using. When you guys say ECS 10mm don't work, that's if you are using them with the OEM wheels. I run ECS 10mm spacers all around and they work perfect but I have Velos Signatures S1 wheels, they would NOT work with my stock 19s.
Quick Reply: Spacers for 2019 Sedan
