SL/R230: 2008 SL55 AMG CD REMOVAL
MBworld Guru
2014 E350 Sport 4Matic Sedan
This may be very helpful. For the first time since I bought my SL550, I recently tried to eject the cd changer cartridge. No success. Not even a sound out of the unit. I have not done the simplest diagnostics yet, so I don't know if it's nothing more than a blown fuse, or a burn out cd changer. So all of this may prove to be helpful.
Mike.
It's a Flintstones fix, but I've seen more than once this has fixed the eject problem.
Try that first and let us know if it works for you.
Tribal knowledge says that if the CD changer cartridge does not come out, you can give it a sharp rap on the CD case and it may then eject.
Mike.
I asked about the fuse out of curiosity, the cd changer is getting power. It ejects the cartridge fine too. The problem is that it won't load a CD from the cartridge. It just keeps scanning for a CD and never finds one even though all six slots are loaded. I can see parts moving inside the changer occasionally while it is searching but it never pulls the tray from the cartridge.
Mike.
Mike.
One last thing. Are the disks in right? Try flipping the disks over.
I did not try flipping the disks over but it says on top of the cartridge to insert the discs with the label facing up and they are that way. The changer is not even opening the disk tray so the read head never sees the disk.
Mike.
Mike.
