GL X164 Trans Conductor Plate Speed Sensor Fix
2007 GL320 CDI, 2002 Jetta TDI, 1999.5 Audi A4 4.2
This is my experience with fixing my GL320's (X164) 722.9 Transmission Conductor Plate Speed Sensor.
I was experiencing the transmission going into limp mode (2nd or 3rd gear only, enough to get you to the side of the road), usually after a hard acceleration event, or sometimes at random. The issue started increasing in frequency as time went on. First once a month maybe, then once a week, then to where we would expect the transmission to go into limp mode at least once per drive.
Scanning for codes, I found two faults. Sometimes one or the other, sometimes both:
The faults indicated are a signal not present or intermittent. The speed sensors Y3/8n1 and Y3/8n2 (and Y3/8n3 output RPM sensor, for that matter) are hall-effect sensors, and sense tone-wheels (toothed rings) at these stages in the driveline. When the hall effect sensors sense a tooth they output (usually) a 5V signal, and a valley (no tooth) will be 0V. This creates a square wave as the tone wheel passes the sensor. The faster the changes in hi to lo, lo to hi, the faster the frequency detected by the sensors. These sensors are used by the Transmission Control Unit -TCU (which is integrated in the conductor plate) to determine revolutions per minute (RPM) at these stages in the transmission. The TCU uses these signals to determine if slip is occurring and to calculate when to shift and what gear to shift into, based on vehicle speed and torque input (accelerating hard, easy, decelerating, etc.). The issue with these sensors, I've learned, is that they either go bad after several years of use -which seemed to by my case, or they have a buildup of metal shavings from the clutch and other various transmission components over time that impede the ability to accurately read changes in tooth depth.
My issue was specifically with the input sensor Y3/8n1, but the same thing could happen to the Y3/8n2 internal sensor or even the Y3/8n3 output sensor. The output sensor I believe is less likely to these problems, I think this is because it is located in a different, less harsh environment that the first two are in. That's my speculation though. Interestingly, the output Y3/8n3 sensor seems to be a hard sensor to get a hold of or have repaired. If this sensor has gone bad for you, it might be able to be replaced still, but it may take a bit more research to find someone able to replace this, or even able to locate the sensor.
Now, in order to fix my Y3/8n1 (input turbine sensor), I had a few options:
So there's the victory story, but now for the helpful part:
First, here is the transmission fluid, gasket, filter, aluminum oil-pan bolts, and transmission overflow plug kit I bought from FCPeuro:
722.9 Transmission Service Kit
The kit was $82.99 when I bought it, but at the time (2019 March 26) of this post it is now a hefty $108.92. Still not horrible, but maybe you can find such a kit cheaper somewhere else. Maybe not.
Here's the most important first step: Be SAFE about it! Put the car on solid jack stands so you aren't squished! I found another clever use of the air-ride suspension for this service: Before you start the job, raise the vehicle to its highest level, then put jack stands under the frame rail. Be sure to prop the car up and not to rely on the suspension holding up. Remember that this vehicle does the auto-leveling thing even when the car is turned off? And that sometimes it levels by squatting down a bit? -And that it could try to squat right on your chest. So I played it safe here and used jack stands and always kept one door open. The auto-leveling won't work if one of the four doors are open. The tailgate isn't baked into this equation, unfortunately).
So, the actual first step here: Remove the harness from the transmission. Before Valve body is removed, after oil pan is dropped, remove the connector and then remove that connector insert with a 7mm hex bolt:
I can't remember if mine had the bolt or not. It's a good idea to check though. If there is a bolt holding the harness on, remove it.
BE VERY CAREFUL WITH THIS STEP! You do NOT want to break the connector. If the connector is difficult to remove, use some penetrating oil and leave sit for a few hours and try again. If the connector portion of the conductor plate is broken, you may be required to find another conductor plate and go through the rigamarole of dealing with MB to marry the new plate to your ECM.
Here is a good guide to draining (and refilling) the transmission oil and replacing the filter, gasket, and bolts:
Below is the Valve body Removal/Installation guide I used when removing it.
Again, USE THE UTMOST CAUTION with this procedure. Pay particular attention to the conductor plate's connector upon removal. This should slide out easy. Do NOT torque or bend this part. As the above states, if you break the conductor plate you may be looking at finding a new conductor plate and all the pain that comes with that.
As the below procedure mentions, do make sure to leave the two front and rear bolts in a couple threads, and once all other bolts are removed, you can GENTLY guide the valve body/conductor plate assembly out from the transmission. The valve body weighs somewhere around 10lbs, and can seem pretty heavy when you're trying to maneuver fine motions with it -especially when working under the vehicle and arms are already half-bent.
722_9 VB Removal-Installation Guide Edited.pdf
@JamesMitchell has posted a helpful video showing the extraction of the connector from the transmission just a few posts below. -Thanks James!
Here is a video of removal and installation. It should help you understand how you need to wiggle and pull the valve body. Unfortunately the video is a bit simplistic, cutting off some of the finer details, but between this video and the instructions above you should have no issues.
Lastly, here are a couple of documents on the 722.9 transmission, just in case you were interested in more intricate details and interworkings:
722.9 a.pdf
722.9 b.pdf
I will have to come back to this post to add my personal photos once I get Flikr figured out, or a new place to host images. Not much else to add though, the above information should be great resources to get this job done.
Good luck!
- Y3/8N1
- 0717 - The signal from component Y3/8N1 (Turbine Speed Sensor (VGS)) is not available
- 0718 - The signal from component Y3/8N1 (Turbine Speed Sensor (VGS)) is defective
- First, I could have elected to take it to someone else (or the dreaded dealer) and get reamed over the coals for service (somewhere north of $2k, if I remember, sheesh! According to what MB says, the conductor plate, which is the plastic tray that sits above the transmissions valve-body, and contains sensors, shift solenoids, and the TCU, would have to be replaced in its entirety. Yes, this would mean a new TCU, because they decided to locate the TCU to the conductor plate inside the transmission. And yes, this would mean that the new TCU would have to be mated to the Engine Control Module (ECM), or Unit, ECU, whatever acronym you want to use here. And yes, since each module has security features to prevent theft (or DIY work!) this requires an MB star diagnostic tool that's licensed and has a link to Mercedes-Benz's database, so that they can be officially paired. See the rabbit hole here?? This is over the top ridiculous. Finding even a certified mechanic (that has this diagnostic tool and the license to use it) that's not explicitly a MB dealer would cost such a great amount. -And rightfully so; the poor mechanic must recoup his license costs somehow.. So, this is out. I'd say this isn't necessary even if you don't plan on replacing the sensor(s) yourself but are willing to pull the conductor plate from the transmission, because of option two; see below.
- Second, I could send the conductor plate into someone to replace the sensor. There are a few places I've found around the interwebs that offer such service. They will usually replace both internal sensors (the Y3-8n1 input and Y3-8n2 internal sensors). I've found a good and reputable business charging $300 for this service. This is much easier to swallow.
- Third, I could take the self-service a step further and do it myself, purchasing the sensors and a punch-removal tool from ebay for ~$40. That seemed great. So actually, that's what I tried first. Verdict: I wouldn't recommend it for the faint of heart. I received the new sensors and a punch tool that was supposed to be used to cut the plastic around the sensor so it could be extracted. Sounds good in theory, and it did work in the ONLY TWO videos I could find of someone using this tool. One was in Chinese and the other in Russian I think. Both were so shaky you could barely tell what they were doing. But it seemed simple enough: Desolder and detach the ribbon cable and use the punch to remove the sensor. For me though, after a few wacks with the punch and a hammer the punch started to fold on itself, loosing its sharp edge, and I figured if I kept at it I would crack the conductor plate and then be up a creek, trying to find a new conductor plate (and TCU) and being forced to go with option one above.
722.9 a.pdf
722.9 b.pdf
Good luck!
The following 7 users liked this post by 4loops:
86ortega (03-28-2019),
bensitto (04-04-2019),
eric_in_sd (03-30-2019),
Innova801 (09-14-2021),
JamesMitchell (04-13-2019),
and 2 others liked this post.
Good man. After many hours of research and staring at this problem from a clueless beginning you have effectively crystallized what needs to be done to fix this 722.9 transmission problem. Let this be a solid guide for those in the future that will run into this issue. I'd rather pay $500-600 than $2300 as I was quoted by the stealership!
I actually had similar experience.
My 2011 GL550 decided to not shift anymore, so RPM's would increase without the car's speedometer actually increasing. This happened during a road trip of course, so we took it to the nearest dealer to have it looked at and also received a loaner. They diagnosed it as a bad wheel speed sensor on the left front wheel and wanted $800, including labor to replace that speed sensor. I declined, towed it to a friends house and replaced it myself. Part no. 1649058200. Car was back running.
Fast forward a couple of weeks: with me knowing the left front speed sensor had failed, I decided to replace the other 3 wheel speed sensors myself. Part no. 1x 1649058200 and 2x 1649058300.
Car was driving smooth one day until same thing happened again! Checked codes this time and found the turbine speed sensor faulty code. Cleared codes and continued driving.
Couple of weeks later, GL had the same symptoms, RPMs increase without speed increasing. Checked codes with Autel Maxisys, and found turbine speed sensor faulty. Did some more research and found that the 722.9 transmissions must have the conductor plate replaced due to the faulty sensors vs the 722.5 transmissions where the sensor is replaceable DIY. Further research concluded that the 722.9 transmissions conductor plates must be "NEW" because they must be "VIRGINIZED" with the car.
We took the GL to our local dealer and had them diagnose it to confirm it was the conductor plate. However, my service advisor could not figure out what was wrong since the problem was intermittent, he even requested for the GL to go home with the technician through the weekend. Monday, I come back and the technician says "everything is fine with the car and I can't find any codes on there......". I show them my code that I got through my scanner and they still claim the car is fine. Literally, 4 days later, I'm driving home, about to turn on the local roads, and same symptoms occur AGAIN!
We then called around the area with different dealers regarding quotes for replacing the conductor plate. Cheapest I quote I received was $1500 including parts and labor. We proceed with that quote and drove 1 hour and 30 minutes to drop the car off. Rental was given to us. 2 days later, the service advisor calls saying he can't do the repair because he can't find any actual code, so Mercedes-Benz does not authorize repairing the conductor plate if no actual codes are found......, even if I wanted to pay out of pocket.......
Did further digging and digging and found some had relief of the transmission fluid being flushed and replaced. The reason behind this is the "metal shavings" OP mentioned may what be causing the sensors to go bad. If fluid was flushed and refilled, then there could be a chance you fix this problem. Some said that the reason the transmission conductor plate sensors fail is because of neglected maintenance and following the maintenance schedule of the truck. I went to a local indy and did the job. $300. It has almost been 8 months without the conductor plate symptoms . Knock on wood........
The following 2 users liked this post by WinterPark321:
Mikchek (07-01-2019),
StradaRedlands (09-22-2019)
Very nice writeup.
If one had a Star system, could one reprogram one's new VSS using the resident coding in that system - or does it HAVE to be connected online to and MB database?
Thanks.
Max
Thanks.
Max
If you are just replacing the speed sensors in the conductor plate, no programming is necessary. If you are replacing the whole conductor plate (which includes the Transmission Control Module), then you will have to pair/marry the new TCM to the ECM, which will require STAR, and as far as I have researched, must be connected to Mercedes Benz's server/database for "security". My feelings are more toward making this a pain in the @$$ for anyone trying to do a repair, but that's my silly opinion.
This is why I'd suggest the much cheaper and much easier option of simply replacing the speed sensors on the conductor plate. This way, you are still using the original TCM and the ECM/vehicle is none the wiser.
You will likely not even need to clear codes, as they will clear as they see a good signal from the speed sensors once the fix is made. If the codes are lingering after the fix, you can use any simple off the shelf OBD tool to clear codes. I use an 'el cheapo $10 bluetooth OBD 2 adapter and clear it with an app on my phone, but you could more easily drive to most any car parts store and ask them to clear your codes for you. They will do that for no charge.
The following 2 users liked this post by 4loops:
Max Blast (08-05-2022),
I have a CLK550 (different car but same trans), and I have a rough shift in 1st and 2nd gear mostly when cold (and sometimes when warm). Did you have any such issues?
My car has no codes when scanned with STAR, but there's obviously something going on. I'm very tempted to try this fix to see if it might improve anything.
Thanks for any info you may be able to provide.
Hey nkx1,
Yea, I do believe I had experienced intermittent hard shifts prior to replacing the speed sensors, yes usually when cold. I'm remembering the most notable thing was when slowing down and coming to a stop, when the trans would shift too early into first gear. My theory here is that if (in my personal experience) I was seeing codes for intermittent/implausible signal from the trans input speed sensor, (or any speed sensor I'd assume could cause this), then the TCU isn't seeing correct speed, and if it thinks the vehicle is moving slower than it actually is it might think its time to downshift. This could also be the issue with yours, and that the signal is not bad enough to throw a fault. That's my theory though. My guess is that your thought process is bang on, I'd also suspect speed signal(s) to be providing a less than perfect signal. Unfortunately, there's no easy way to throw a mobile scope on the output of the hall-effect speed sensors, as they go directly to the TCU, which is inside the transmission. That is, unless STAR has a graphical monitor for speed sensors, but I doubt it. Not having a STAR, I can't be for sure on this though. I'd hate to recommend you go through this process as it's basically throwing money and effort at it and hoping that'll fix it. However, without a good method to monitor signal quality from the speed sensors there might not be many other troubleshooting options.
Good luck bud.
Good luck bud.
nkx1 (06-22-2019)
Hey nkx1,
Good luck bud.
Good luck bud.
That's a good idea, to potentially evaluate the quality of the speed sensors with STAR. I also doubt this capability exists, but it can't hurt to ask (I'll ask my mechanic).
In the end, I'm probably going to have to just try the speed sensor fix to see if it improves anything. Thanks again!
To help rationalize the decision to get the speed sensors fixed, consider that it might be close to time to do a Trans flush and filter change anyway, and since you're in there already... the conductor plate is just right there on top of the valve body. So at that point it's just asking for it, really
As a reminder to anyone following this thread, simply changing the speed sensors does not require any reprogramming. Just swap and go, the TCU and ECM is none the wiser. Nkx1, I see you deleted this part after posting initially -I'm sure you reread and saw reprogramming wasn't required, but I thought I'd just mention it again here for others reading.
Cheers!
Cheers!
Cheers!
Cheers!
Therefore, I'm probably going to have to find a local place to replace the sensors the same day. I contacted a local place that does the speed sensor replacement, and they said that my issue (rough 1-2 and 2-3 shifting when cold) is likely more of a hydraulic issue and not an electronic one given the absence of error codes. Given that my mechanic didn't have any strong guesses without tearing apart the transmission, I'm thoroughly confused about what to do. Since the speed sensors are almost certainly going to eventually fail no matter what, maybe I can use that as a justification to give this experiment a whirl.
My mechanic seems to think that the trans fluid has already been changed because the drain plug has been removed before (or some similar rationale), but I'm not entirely convinced of this. Man, what a hassle lol.
You're right though, a giant hassle. Sorry to hear you having so many troubles with it currently. But also, right you are: It's not a matter of if the speed sensors will need replacing, but of when. (at least that's what I keep reading on similar forums)
I hope you're able to find a local place that can swap 'em on the spot and get you taken care of quickly.
You should start a thread about your struggles and post your solutions (when they come, hopefully soon!). We can keep growing this knowledge base and help the next poor sucker that's stuck in a similar situation! If you do that, do post a link to it here so folks can jump to your thread.
Concerning your trans fluid.. It could have been changed recently, before you took ownership.. but there's no way of telling that the right fluid was used. I've learned in the past that this can make a big difference. -Just a thought.
I may get flack for saying such things as this, but when most EV range is above 250 miles and a bit more affordable I'm totally looking forward to jumping ship. At least for the commuter vehicle. This maintenance stuff is just starting to eat up too much time.. especially now that there's a bazillion extra engine and emissions controls to keep working. I enjoy wrenching, but geez!
Yeah, I'll post a thread if/when I ever get this sorted out. Good point about the trans fluid.
Regarding EVs, I'm in full agreement with you. No reason to hassle with an overly-complicated ICE-based vehicle when a comparatively simple EV will out perform the ICE-based vehicle in almost all regards. I've read about up-and-coming technology that should provide 80% charging in 5 minutes. The coming years should be interesting.
If I could go back in time, I probably would have avoided buying this car a few months ago. PPI didn't reveal any transmission issues, and I didn't notice it when I bought it. I have better things to do and spend money on than something as basic as ensuring my car works!
Great Write Up!
4Loops -
Brother man, thank you for your detailed writeup! It helped me tremendously! I've got about 188K miles on my originally purchased new '07 GL450. I took a 7 hr drive and (thankfully) at the stop sign prior to my house on the return trip, I got the symptoms of pressing on the accelerator with increased rpm's but slowly moving car - limp mode. I thought to myself, I guess I need to get a new transmission. Then I found your write-up. What a life saver! I did a scan of the transmission and found that my speed sensor codes of my transmission were the problem. Specifically, I had code 2767 "The signal from component Y3/8n2 Internal speed sensor VGS is not available." and code 2768 "Component Y3/8n2 Internal speed sensor is defective." I followed Step 2 of your procedures and sent my transmission circuit board to circuitboardmedics.com. Folks can look at my previous write-ups and know I'm not sponsoring anyone. I had a major problem with my transmission and was contemplating getting a used transmission. But, I was able to extract the circuit board of my transmission's control module and send it to Circuit Board Medics to repair the speed sensors of the transmission. Cost was $299 as of this writing. I want to say that the circuit board arrived back to me in 5 days and I installed it and the car is running perfectly (so far, knock on wood). Here are a few pointers for anyone who find themselves in this predicament and wants to tackle it themselves:
1. Removal of the transmission pan will be messy. I cut and taped down garbage bags below the car to keep the transmission fluid from messing up my garage floor. I also jacked up my car on all fours to keep the transmission pan level to refill after the work was completed.
2. During extraction of the transmission control module, pay particular attention to 4Loops' method of leaving two of the screws (one at forward and one at aft - he annotated these in blue) partially screwed in. The reason for this is because when you remove the 10 screws holding the TCM to the transmission, the entire body will want to fall down (about 10 lbs) and this will cause stress on the electronic control (circular electronic module towards front of car) that is partially stuck in by two O-rings and will likely break if you don't very carefully leave two screws in. If you break this part of the board - you'll need to get another circuit board which is a PITA and will require a trip to the dealership or an authorized indy to mate the new circuit board to the ECM. Once you've got the TCM down to the last two partially screwed in screws, follow the procedure in the below video to "gently" work the circular electronic part of the TCM to break it free with a screwdriver (at :20sec in the below video). Then you can remove the remaining screws and remove TCM.
3. The above video also talks about cleaning the regulating sensors, which will be removed prior to sending your board for repair. I put each sensor in a labeled ziplock bag and drew a diagram upon removal to help with reinstallation.
4. Circuitboardmedics.com and FCPeuro.com have several videos on Youtube that can help in the removal of transmission fluid, removal of TCM and circuit board from TCM as 4Loops indicated above. I did a search for 722.9 transmission control module and found a number of valuable videos to get acquainted with the process. Also, the above procedures from 4Loops that have printed instructions were handy and definitely helped in the process.
This picture is what the TCM with board looked like after taking it out of transmission:
This is what the board looked like after return from Circuit Board Medics:
After return from Circuit Board Medics. The two green arrows show where the input/output speed sensors are located following repair.
5. What I did to install the transmission fluid: the procedures for filling can be intimidating. Don't be. I have an Autel scanner that allows Live viewing of the transmission - a lot of inexpensive scanners have this function. You need to be able to monitor the temp of the transmission to ensure you have the proper amount of fluid at the proper temperature. Sounds complicated, but it's not. And, Circuitboardmedics can rent a scanner to you for $40 to monitor the temp if you don't have one. It's in the drop down menu when you order the service. I got a Motive brake bleeder from Amazon for about $50 and cut off the end for the brake cover as well as the portion just above the middle junction. This gave me 12" or so of clear 1/4" line. I bought a ball cutoff valve from Amazon for $7 and put the cutoff valve just above the Motive junction and the rest of the 12" line to the filler adapter at the transmission pan. I bought the 722.9 transmission kit from FCPEuro for $109 and it included the transmission pan filler. I used a zip tie to affix the 1/4" line from the Motive line to the filler adapter. Put the transmission fluid into the Motive tank, pumped to about 12 psi then opened the ball valve. I installed 5 liters initially, then I started the car to get the trans. to warm up. Once it approached 100 deg F (target for filling is 113 deg F or 45 deg C) I got the 6th liter of fluid in the Motive tank ready to fill. As the temp approached 108, I started to fill more into the pan. I actually ended up using 6 1/4 liters of fluid as the temp approached 113, I pulled the 1/4" line from the pan filler and saw a slight stream of fluid coming out. I quickly put the drain plug in and torqued it appropriately (I think it was to 22 N-m). Caution: the transmission tank temp will continue to rise, so you will need to work quickly. My trans temp got to 118 deg F, so I had to wait a while for the trans to cool off. Also, pumping fluid in a 1/4" tube takes time. It's a slow process. Be methodical and patient. In the end though, I got the proper amount of fluid in and got the refill procedure complete. Here's a link to the items I bought:
Circuit Board Medics: https://circuitboardmedics.com/merce...te-tcm-repair/
FCP Euro Transmission Kit: https://www.fcpeuro.com/products/mer...em-7229erlysk1
Motive bleeder: Ball Check Valve:
What the Motive with check valve setup looked like:
Good luck to anyone who experiences this issue with their transmission. It cost me $299 plus about $40 shipping for the circuit board. About $60 for the Motive tank and check valve. About $120 for the transmission kit from FCP Euro. Or about $520 total to repair the transmission total - a fraction of what it would have cost anywhere else. I drove it over the past few days and it's driving awesome through all 7 speeds and no leaks. PM me if you have any specific questions. Again, thanks to 4Loops and all who contributed to this thread.
The following 2 users liked this post by JamesMitchell:
Received 1,156 Likes
2015 SL400 (M276 Turbo), 2014 C350 Sport (M276 NA), 2004 SL500, 2004 Audi TT225
I did break off my connector when I removed my conductor plate. Fortunately, Circuit Board Medics was able to juryrig some way to download the controller coding and initialize a virgin board they sold me for an additional $200. No trip to the dealer required. I can’t recommend them enough!
The following 2 users liked this post by JettaRed:
Wow, I'm so glad to hear they were able to still get you taken care of without the trip to the dealer. The tow and hassle of it alone would be stressful enough, and then trying to deal with a Merc' service department. I'd say bullet dodged... but maybe: bullet... dislodged??
Glad you were able to get it sorted out in the end though, and glad to hear these guys can repair such a break!
@JamesMitchell : I'm glad this worked for you, and thank you for an excellent addition to the write-up and procedure!
I wish I had used a pressurized bleeder as you had, whereas I used a cheap pump I adapted to fit in the bottle of trans fluid. My arms were KILLING ME somewhere between 150-200 pumps! (I would really suggest this for anyone attempting this procedure!)
-I'll be sure to go edit my original post to caution excessively about the removal process and to be careful to not break the conductor plate's connector.
For those following: I used an iCarSoft MB II scanner (Bought via amazon for ~$100) to read the transmission temp during the process. The Autel scanner James mentioned sounds like a more thorough and complete unit though. Still, the iCarSoft is able to do simple things like clearing the service interval reminder after each oil change, reading some live data (such as trans oil temp), and checking codes at each module; which covers the majority of any diagnostics and troubleshooting I do.
