GL Class (X164) 2007-2012: GL320CDI, GL420CDI, GL450, GL550
No power on Homelink
Old 04-05-2019, 12:15 AM
mini11's Avatar
2007 Mercedes Gl 450
I have 2007 Gl450. The Homelink has no power when I touch them. I used to work before any suggestions how to fix that. Thanks in advance.
Old 04-19-2019, 09:04 PM
NCite's Avatar
GL450
Was the ignition on? The ignition needs to be on for operation.
Old 04-24-2019, 11:39 PM
mini11's Avatar
Yes, It was On.
Old 04-25-2019, 09:16 PM
kombifan's Avatar
2010 Mercedes GL450; 2000 Mercedes ML55 AMG; 2016 VW GLI SEL Stick!!!
Do the reading lights work? The ones under the mirror?
Old 04-25-2019, 09:51 PM
mini11's Avatar
Yes, Reading lights works. There is no Yellow light underneath the mirrors, Which usually we press in order to open garage door. There are 3 buttons on the mirror but I tried all of them they doesn't blink or stay solid.
Old 04-25-2019, 10:02 PM
kombifan's Avatar
Have you checked to see if the button isn't sunken in?
That happened to mine and I had to replace the mirror.
I'm afraid a connector might be shorted out.
Does the auto dimming function work?
Old 04-25-2019, 10:10 PM
mini11's Avatar
It is not sunken in. Auto Dimming function works.
Old 04-25-2019, 10:27 PM
kombifan's Avatar
Check the fusebox. It might be a blown fuse.
On a ml a blown fuse for the glove box caused the homelink to not work too. Does the glove box light work?
Old 04-25-2019, 10:32 PM
kombifan's Avatar
https://mbworld.org/forums/attachmen...es-gl-2008.pdf
mini11's Avatar
Glove box has lights on. Homelink bottons blinks sometimes then it never shows the blinking light.
Old 04-25-2019, 10:34 PM
kombifan's Avatar
So it does blink?
Try the reset procedure and reprogram it.
Quick Reply: No power on Homelink
