This sound is driving me nuts.
Old 04-06-2019, 06:52 PM
mrm143's Avatar
2012 c250 coupe
I took a video of the gurgling sound that the Mechanic’s day is normal. Every time a new person gets in the car they ask what is that noise. I always said I was told it was normal. I decided to take a video once and for all to see if you guys and gals think it’s a normal sound. Not the turbo whine. Listen for the gurgling noise. Can’t hear it outside the car. Only inside under acceleration. If it’s normal then fine but I need to know.
Old 05-19-2019, 10:00 PM
MBENZTECH's Avatar
W203 W212 W211 R53MCS
How are your motor mounts?? I have had 2 customers come in with this and both cars have collapsed motor mounts.
Old 05-19-2019, 10:01 PM
mrm143's Avatar
2012 c250 coupe
The engine isn’t moving or vibrating excessively. Is their any way to check them?
Old 05-20-2019, 09:32 AM
mrm143's Avatar
2012 c250 coupe
you may actually be right. If I put my hand on the rear transmission tunnel I can “feel” the gurgling. I know their are 3 mounts total including transmission. Transmission being the easiest. Should I attempt the transmission one and wait or do all 3. Not even sure if it’s something I could do
Old 05-20-2019, 12:33 PM
mrm143's Avatar
2012 c250 coupe
I called my mechanic and was quoted about 500 parts and Labor for all 3 mounts
corteco mounts.
I would rather not spend the money on a hunch though.
Old 08-02-2023, 10:06 AM
Ahmed3adel's Avatar
Mercedes Benz C250 Coupe
https://youtu.be/dpFRqNdgSL8
i have the same sound in my c250 coupe 2013
very annoying, already changed the 2 engine mount, didnt change the gear mount yet, but want to make sure if you figure out what was this sound coming from!!
you only hear it inside the car coming from below the dashboard.
Old 08-02-2023, 10:11 AM
mrm143's Avatar
2012 c250 coupe
yes it was changing the tranny mount that fixed it in the end.
Old 08-02-2023, 10:33 AM
Ahmed3adel's Avatar
hot it, will get it changed tomorrow and hopefully will get rid of this sound 🙏🏼. Thank you for the fast reply, appreciate it 👌🏼
Quick Reply: This sound is driving me nuts.
