E Class Style Ambient Light Led Air Vents for W205 - I tried to resist :D
Not mine, but a close friend's car after the air vents change.
I actually prefer the slatted A/C vents. The ambient lit vents are one of my least favorite parts of the whole ambient lighting setup in the newer cars.
I like the footwells & the ribbon from the doors & along the dash, but that does it for me. Don't care for the speakers & A/C vents to be lit.
My friend got the 10" directly in China, so no link. But i would think that it's similar to the ones should in Aliexpress.
Have heard issues with the 10" though, and so far those on the 9.33" ones said they had the better resolution and it works better. I don't have the full details, cos i'm still on my stock ones.
benzdude (04-10-2019)
2015 C300 4Matic Sport
The following 3 users liked this post by benzdude:
Looks great. Love the tennis ball
The following 2 users liked this post by DylanM:
benzdude (04-19-2019),
MaverickC43 (12-18-2021)
Before I purchased, I assumed the entire ring was illuminated, but it's just the small area around the vent knob. The rest is just light reflecting off the silver trim. But it works. You don't want your cabin to be super bright and adding more things with leds will do that.
If you look at the bottom photo you can see how bright it gets with all the lights off. This is how you look driving down the highway. Bright enough in person.
I am making excuse to drive around at night.
The following 4 users liked this post by benzdude:
Now you need to find an upgrade for the rear A/C vents. Consistency & all that.
These look pretty good & are tempting. I will say that your door ambient lighting looks a little bright for my tastes, compared to the vents.
Rear vents are only 2 inches wide and are a different overall design than the stock fronts. I don't spend time back there, so no need for leds.
What I might do is get 2 ambient lighting speaker covers for the full range door speakers in back, for balance.
https://www.aliexpress.com/item/Car-...006063164.html
Looks good, but if I were you I'd really look into changing the rear vents. And yes, the only time I use the back of my car is to hang stuff or put stuff on the floor that I can't be bothered to put in the boot.
Thumbs up though on the job you've done.
Changing to match the propeller look of the fronts or also adding 3 color ambient light?
I looked around and even the chinese DIY guys don't think those rear vents are worth it.
There isn't a mod currently available for those rear vents online.
If anyone is interested,
The Mercedes Benz 3 color ambient lighting system in the console only uses one led for the 3 colors and only has 3 wires.
One wire is ground and the other two are 12volt depending on which color you want. ( blue, yellow or white ).
If the blue wire is 12 volt, you get blue color. if the yellow is 12 volt you get Yellow (solar) color. l am not really sure how white is triggered, probably by sending 12 volt to both blue and yellow wires at the same time?
I was surprised to find that they use clear plastic tubes to transmit the ambient light along the edge of the console and not long leds strands.
There is only one led attached to both ends of each clear tube. 4 in total.
jevsays (08-05-2019)
Both if possible, more for symmetry. But it's a bummer since they aren't available...
