SL55/63/65/R230 AMG: Chart of Pulley Sizes vs Cfm from SL55
About a year ago I had found a chart online that showed what cfm (compared to stock) that could be expected from a SL55 with various pulley combinations. I printed it out and now I can't find the online source or the print out. If anyone can help I would certainly appreciate it.
PLATINUM SPONSOR
I ran 77mm upper and 195mm lower at one point but for day to day, liked the 172mm lower/ 77 upper combo with headers tune, injectors, cooling mods and UPD cold air intake. HP matched torque converter really made things fun.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
