C450/C43 AMG
Trouble detecting key
Old 04-17-2019, 12:36 PM
merlin3008's Avatar
2019 C43 AMG, 2016 BMW M235xi (gone)
Hey all...does anyone else have this problem? I generally keep my key fob in my backpack when I head to work. Often, when I get in the car and push start, the car does not recognize that the key is in the car. The screen prompts me to place the key on the pad in the cupholder. This doesn't happen every time, but at least several times a week. Anybody else?
Old 04-17-2019, 01:30 PM
MVEOVR's Avatar
2019 AMG C43 Sedan
I keep mine in my jacket pocket, no issues with it thus far.
Old 04-17-2019, 03:55 PM
SoCalC55's Avatar
2019 AMG C43
I have the same issue, planning on asking MB next time i take the car in. I replaced the fob battery so its not that, but occasionally i have to click the button a few times to start.
I wonder if it has to do with the new start/stop button. Its more of a click vs press of older buttons. That's the only thing i have been able to come up with.
Old 04-17-2019, 03:59 PM
merlin3008's Avatar
Maybe it only happens on Selenite Gray sedans. You have excellent taste.
Old 04-17-2019, 06:20 PM
GreekUPS's Avatar
‘15 C300 4M Sport, ‘20 GLC300
This might work, take out push button and use key to start car. Sometimes the fob needs to "pair" with the car.
Old 04-17-2019, 08:05 PM
SoCalC55's Avatar
2019 AMG C43
Can you even do that with the redesigned key?
I know past MB keys have the IR sensor but the new design is just a fob
Old 04-18-2019, 07:56 AM
MVEOVR's Avatar
2019 AMG C43 Sedan
One thing I had noticed is I needed to hold the brake peddle in a couple seconds longer, otherwise it would crank a bit longer than normal before firing (If I just jumped in and tried to start instantly). Not sure if this helps with the key though. I imagine something with the key less go feature, or as suggested the Selenite Gray .
Old 04-18-2019, 12:59 PM
GuardianVA's Avatar
'19 C43
I experienced this issue occasionally when I had the key fob in the same pocket as my phone. It seems that the key is susceptible to EM interference. Is there a computer or other EM source in the backpack that might be causing interference with the key fob?
Old 04-18-2019, 03:29 PM
SoCalC55's Avatar
2019 AMG C43
Thats a good observation. I wonder if there is a certain level of brake that needs to be engaged for the system to fully prime; I'll be cognizant the next few days.
Or yep clearly a Selenite issue
Old 04-18-2019, 09:15 PM
Trappers101's Avatar
2016 C300 4matic
I've read in other posts the Fob battery was at fault. The Chinese have pirated the industry so well (Energizer Battery in Blue blister packs are supposed to be knock offs the real ones come in a Pink pack) that you cant tell the knock off from real ones. Found a link for MB ones. For $10 it's worth a try if nothing else you've got back up batteries.
Mercedes-Benz Remote Key Battery Keyless Entry Genuine Original 0000388 (2pcs)Average rating:5out of5stars, based on2reviews2 reviewsMercedes-Benz
$10.00
Old 04-18-2019, 10:11 PM
jerhu's Avatar
C43, GLS450
No you cant do this with the newer keys. The bottom does not pop out.
Quick Reply: Trouble detecting key
