p0112 p0500
Old 04-19-2019, 10:28 AM
clk500!'s Avatar
clk500
p0112 p0500
Hello every one I need help please, where is the Intake air sensor located and also the vehicle speed sensor on CLK 500 2004?
I have two codes P0500 and P0112
Old 04-19-2019, 04:14 PM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
The first one is on the intake. I believe the other is on ther conductor plate in the trans.
clk500! (04-19-2019)
Old 04-19-2019, 04:31 PM
clk500!'s Avatar
clk500
Thanks Insame1, is it deferent than the mass air flow sensor? do you know the part# by any chance ?
Old 04-19-2019, 08:43 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
P0012 = "P2006 - [2] B2/5b1 (Intake air temperature sensor) : Short circuit to positive or open circuit". B2/5b1 is the MAF sensor.
P0500 = "Event P20CA - [8] No CAN message 'Vehicle speed signal left rear wheel' from control module N47-5 (ESP control unit) or message faulty. : Read out fault memory of control unit ESP." This sounds like a faulty speed sensor for the left rear wheel.
clk500! (04-20-2019)
Old 04-20-2019, 09:36 AM
clk500!'s Avatar
clk500
Thanks Rudeney, I changed the MAF last year but honestly I got a cheap one from ebay, I will find the MB brand and switch it, so The VSP is the same like wheel speed ?
Old 04-20-2019, 09:45 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Yes, the vehicle speed is calculated by averaging the four wheel speed sensors, so VSP = wheel speed sensor.
clk500! (04-21-2019)
Old 04-21-2019, 12:08 AM
clk500!'s Avatar
clk500
Thanks!
Quick Reply: p0112 p0500
