Ipod Cable - HK Logic 7
Old 04-19-2019, 05:55 PM
bullrich's Avatar
2007 CLK63
I'm a little new to the 204, but I have recently acquired one with an AUX jack in the glove compartment. How can I install a 30-pin Ipod cable so I can use a bluetooth adapter?
FYI...I have the HK Logic7 system.
Thanks!
Old 04-20-2019, 12:26 AM
Adi-Benz's Avatar
You can just get an aux Bluetooth adapter instead.
The ipod-30s are on prefacelift models.
Old 04-20-2019, 12:48 AM
bullrich's Avatar
2007 CLK63
Problem with that is I can't use the steering wheel controls. I have a BT adapter, but it requires power from the cable to light it up, which I can't get from the AUX jack. So my thought was to swap the 3.5mm AUX jack for the actual 30-pin iPod cable, plug in the CarPro BT adapter and away I go. At least in theory.
And I do NOT have the HK Logic7. I have an Audio 20.
Old 04-24-2019, 08:23 PM
John Tadd's Avatar
mercedes c300
You can buy the cable from Ebay...it's about $35 give or take. It's the mercedes OEM mmi cable....I attached a coolpro bluetooth streamer that I got from Amazon to it and it works just fine...I can even use the steering wheel controls, and the song/ artist info appears on screen as well.
The cable for my particular car is here: https://www.ebay.com/itm/OEM-MI-3G-i...cAAOSwknJX0b0A
But just make sure it's compatible with whichever year/ model you own.
Quick Reply: Ipod Cable - HK Logic 7
