C63 AMG (W204) 2008 - 2015
Replacing HK speakers
Old 04-20-2019, 10:59 AM
prestonhendu's Avatar
2015 E350 Sport 2014 C63 507.
I know most of you love your HK but I want a little more sound. I’m going to add an amp for front and rear plus sub. I’ve seen plenty of write-ups upgrading to HK but can someone point me to a write-up of HK to aftermarket? OAN my ‘14 E350 HK sounded much better than the one now in my 507. I added a sub to the system and it was decent.
Old 04-20-2019, 11:55 AM
Solo wing's Avatar
2020 E 300 Coupe and 2019 GLS 400
I am going through a similar process with my ML63. It has the HK system. I replaced the factory head unit with a Kenwood DNX995S. I will be installing an SQ system. Focal KRX3 in the front, FPS4160 AMP and caps, in addition to a subwoofer. The rear speakers will remain HK through the factory amp for rear-fill.
If you want to keep the factory nav+HU, here are the integration solutions to add an amp to the factory HU:
http://mobridge.us/compatibility/mercedes-benz/
This would be suitable if you want to buy an analog RCA amp:
http://mobridge.us/product/da2-analog-pre-amp-most/
or this one:
http://mobridge.us/product/da3-dsp-professional-most/
I have no experience with this company, just found them through searching. I used Connects2, a British company that manufactures integration interfaces. I have full SW control, rear camera integration, and MOST amp connection.
I have always disliked HK systems. The KRX3 sounded amazing in my previous E55.
Old 04-21-2019, 08:24 AM
sqitis's Avatar
C63 P31
Where are you installing the 4" mid from the KRX3? I've ran Focal in my world champion IASCA car many years ago and yea they rock when setup correctly.
Old 04-21-2019, 11:11 AM
Solo wing's Avatar
I thought of installing them above the 6.5 woofers, in the door panel- > this means cutting the panel, but would retain the clean factory look, and would keep everything together in one place.
Another solution is to buy the 3.5 pods for the A-pillars. The shop who installed these in my previous E55, told me they sound far better ON-axis so I might give that a try. Focal suggest placing them ideally high in the doors.
Old 04-21-2019, 09:01 PM
AMGonFire's Avatar
2012 c63 AMG, 2011 GLK 350, 2019 GLS 450
The pods look like garbage. I would not do that ever.
Old 04-22-2019, 07:23 AM
sqitis's Avatar
C63 P31
The closer together the better. This will help with time alignment for sure.
Old 04-22-2019, 10:01 AM
Does the HK system use passive crossovers between the midrange and tweeter or is it actively from the gateway? Whats the impedance on the front and rear channels? Im asking this because I want to add my amp to the front and rears first, get a feel for the sound, then replace with Polks if need be.
Rate This Thread
Rate This Thread:
Quick Reply: Replacing HK speakers
