Bridgstone Potenza RE-71R’s Installed
Old 04-20-2019, 10:01 PM
karpetcm's Avatar
2006 E55 AMG
Well i finally got some sticky tires out back and i done went too big, lol. If I would’ve stuck to 275/30/19’s i would’ve been fine but I went to 285/35/19’s and got slight rubbing. Only rubs a bit in comfort mode and runs more is S1/S2. Needless to say fender rolling will be done on top of that i got abs/esp malfunction, guessing when they lifted just the back the wheel spun a bit and caused the sensor to trip a code and now i think maybe the speed sensor is done. Same thing happened when i did my E550 everytime i go to do rims and tires i get this code. Either way here are some pics.
Old 04-20-2019, 10:18 PM
E42AMG???'s Avatar
E420
What’s your front tire size, the rolling circumference might be too far off. They look good so who cares about some lights.
Old 04-20-2019, 10:48 PM
karpetcm's Avatar
2006 E55 AMG
My fronts are 245/35/19’s Perelli Centurato P1 Plus. Thank you for the compliment👍
Old 04-20-2019, 11:01 PM
E42AMG???'s Avatar
E420
That’s going to be your issue you’ll have too hook up to verify. It will be a wheel speed/ can signal implausible fault. You could get new front tires that match the height of the rears to fix the issue.
Old 04-20-2019, 11:12 PM
boosted305's Avatar
broom
To get the same diameter/height as the 245/35s you'll have to go to 285/30's
Old 04-20-2019, 11:26 PM
karpetcm's Avatar
2006 E55 AMG
Here is a side profile just to give an idea of stance.
Old 04-20-2019, 11:38 PM
boosted305's Avatar
broom
The gap actually looks slightly better in the rear...beautiful car, love the color
Old 04-20-2019, 11:40 PM
karpetcm's Avatar
2006 E55 AMG
just before doing the rear tire swap I raised the front end to match up with the perelli’s i had looks like i have to drop the front back to were it was. Thank you for the compliment 🙏
Old 04-20-2019, 11:48 PM
boosted305's Avatar
broom
Ah, that should do the trick...just out of curiosity, why the RE71R's in the rear only?
Old 04-20-2019, 11:55 PM
karpetcm's Avatar
2006 E55 AMG
I wasn't going to track the car and I needed traction out back. I like the look of them and from the people around me they always go with the obvious choice NT555R’s or Proxes 888’s and a couple of others.
Old 04-21-2019, 02:24 AM
tw2
tw2's Avatar
2005 E55 AMG, 1991 MR2
They look like some pretty serious rear tires. Let us know how they go. They look like a track tire.
Old 04-21-2019, 08:37 AM
StarvingArtist's Avatar
CLS 55 AMG E500 99 ML320
You don't actually have to match them, just get closer.
Quick Reply: Bridgstone Potenza RE-71R’s Installed
