Differential oil - need clarification
Old 04-20-2019, 10:05 PM
artim808's Avatar
2012 S350 Bluetec 4MATIC; 2011 ML350; 2005 C230k;
Hi guys I need to clarify which oil to use for 2011 ML350 4MATIC.
According to WIS, oil in transfer case should be 236.12 spec, rear differential should be 235.15 spec and front differential should be 235.74 spec.
I thought that oil in transfer case is the same oil as in transmission - 236.15 spec, and both front and rear differentials have same oil.
Can someone check WIS and confirm the specs for both differentials and transfer case? I would like to change the oil but I want to be sure I'll use the right one
File Type: pdf
Old 04-20-2019, 10:49 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Here are the specific charts.
BlackML550 (06-22-2020)
Old 04-20-2019, 11:13 PM
artim808's Avatar
This is same chart I attached to my post. Is there any difference between 235.15 and 235.74? Both are 75W-85
Old 04-20-2019, 11:30 PM
Originally Posted by artim808
This is same chart I attached to my post. Is there any difference between 235.15 and 235.75? Both are 75W-85
I didn't open your link.
Then check both sheets and compare manufacturers.
https://bevo.mercedes-benz.com/bevolisten/235.0_en.html
Old 04-21-2019, 01:43 AM
artim808's Avatar
Ok so I searched more and since I don't have differential lock, both front and rear differential have same oil but different specs. Front differential has spec 235.74 and rear has 235.7 but oil is the same for both specs: A0019893303
Now according to the sheet I should have to use spec 236.12 for transfer case. I know that 236.14 spec replaced old 236.12 spec for ATF but I'm not sure if that's valid for transfer case as well.
It's confusing. In transmission I have 236.15 (blue ATF fluid) but for transfer case I have to use 236.12 (old red fluid)? If yes can I use newer version of red fluid 236.14?
Old 04-21-2019, 05:55 AM
artim, I don't own a diesel. I won't recommend any fluid in case something goes wrong. Why can't you just use what the charts say?
Or call a dealer and give them the last 8 digits of your vin # and ask them.
Old 05-23-2019, 09:32 PM
MBENZTECH's Avatar
W203 W212 W211 R53MCS
236.14 trans oil is perfectly ok to use in your transfer case.
Old 05-24-2019, 09:07 PM
wannawagon's Avatar
2006 ML320 CDI (2 of) and 2008 GL320
I use the Fuchs 4134? in both - am pretty sure I looked it up on Fuchs website and that was there recommendations - in Australia had issues trying to get a good enough fluid for transmission
Old 06-05-2023, 11:07 AM
anavabi's Avatar
2006 ML500, 2008 ML350
Hi Major,
I know this is an old post, but I came across it just now in my search for gear oil for front and rear differentials on my 2006 ML500.
On the "BB00.40-P-0231-01A" that you provided, would you please explain how to find out if on my car, I have:
1- "Rear axle with differential lock model 164"
2- "Rear axle model 164 with rear wheel drive (4 X2)"
Document attached.
File Type: pdf
Old 06-05-2023, 12:49 PM
DLB_Adelaide's Avatar
ML320 W164 OM642 722.902
Originally Posted by anavabi
Hi Major,
Document attached.
I haven't seen Major active posting here.
Anyhow, there is a dial on your middle panel like the one on the right (picture below). See thread for discussion. 12-mark is set to AUTO 3-mark is set to transfer case lock? 6-mark is set to diff lock? If you look under the car on the differential housing, you will see the big motor as well.
Diff motor
Quick Reply: Differential oil - need clarification
