Run Flats psi
Run Flats psi
I drove 330 miles today on the IH. Psi bounced from 38-41.
Tomorrow I'm dropping to 33 on all corners. Tires are 20" Pirellis. Ride was harsh at hwy speeds although not the slickest road surface either.
thoughts?
thoughts?
2016 S550 sport, 2018 GLC300, M3, Zo7, 2021 Sierra Denali
I have lowered the psi also with no luck. The runflats are that bad. Its a heavy car and the sidewall has to be able to support the car if flat....which equals a very stiff hard sidewall regardless of psi. When I slowly go to enter my garage there is a 1 1/2" elevation and when I hit it it bangs as if no give at all in the tire. Michelins to come!!
My afternoon psi experiment was a bust. Tires gain 4psi running at 80. I'll reset to 32 in the AM when it's cool. Try again but not anticipating much from a RF.
Yes, I am on 20's. psi has always made a noticeable difference on some of my cars, some like a little more, some improve with a little less.........not these runflats. I have the Goodyears. Short sidewall, heavy car.
2023 S580 (current), 2019 Range Rover HSE V6 (current),2021 S580, 2018 S560 4Matic, 2015 S550 4Matic
I took off my 19inch OEMS with runcraps, and put 20inch aftermarkets with the same conti dws 06 and the ride is night and day. I did get the mini spare with short lugs like Streamliner did. Didn’t get jack and all as in the event i get a flat, i will be calling roadside to come change my spare.
Donnymac (04-22-2019)
The following 2 users liked this post by 1bad540:
Donnymac (04-22-2019),
Phillyfinest (04-22-2019)
My 2018 S560 shows different recommended psi pressures: driver's door 41, fuel cap shows 32. I don't know if it's a misprint/error or how to explain it. Dealer had initially inflated to the door pressure of 41. I have my first service A scheduled in 30 days and will ask then.
Nice Ride (05-14-2019)
