E-Class (W211) 2003-2009
Airmatic level one side lower
Old 04-21-2019, 05:47 AM
panam93's Avatar
CLS 500 w219
Hi everybody, after replacing the shocks before, I have a difference in level between the left side and the right side after an automatic calibration with sd conect 5 succeeded.
Old 04-22-2019, 11:04 AM
bbirdwell's Avatar
'99 and '05 E55 AMG
SD connect 5 autocalibrates? Using an older system, I had to set it manually using an inclinometer on the front control arms and the rear axles. Absolutely level floor, front control arms equal to each other and between 3.1* to 4.1* (inboard higher than outboard) plus rear axles between -0.9* and -1.5* (outboard higher than inboard). Set inclination angles, ensure sensor voltage values within allowable range, confirm inclination angles, go to next screen, enter recorded inclination angles, press "calibrate".
Potential causes:
-car not absolutely level prior to calibration,
-front control arms not equal inclination angle,
-rear bolts were tightened in such a way that one side is binding,
-front control arm bolts tightened so that one side is binding.
Those are the ones off the top of my head.
Old 04-22-2019, 12:26 PM
panam93's Avatar
CLS 500 w219
Hi bbirdwell,
Thank you very much for your precious response, I didn't think about that. I'm going to look in this direction
Thanks a lot
Quick Reply: Airmatic level one side lower
