E-Class (W211) 2003-2009
Strange Charging problem
Old 04-22-2019, 11:13 AM
J911brick's Avatar
W211 W204
08 E320. New to Mercedes, but not wrenching. The car doesnt charge, but if you disconnect the battery and hook it back up it will charge for a while, then stop again and battery voltage will drop till things start turning off. Disconnect the battery, jump start it and it will be charging at 14v again. battery is AGM and less than a year old, alternator replaced twice. What am I missing?
Old 04-22-2019, 11:49 AM
J911brick's Avatar
W211 W204
Does this car have the Aux battery and if so where is it. Its not under the charcoal filer.
Old 04-22-2019, 12:01 PM
jimbo1763's Avatar
2007 E350 Sedan
No aux battery on a 2008.
Old 04-22-2019, 12:09 PM
J911brick's Avatar
W211 W204
Old 04-24-2019, 10:54 AM
05w211wagon's Avatar
2005 e500 w211 wagon
what brand of alternator did you purchase?
Old 04-24-2019, 11:00 AM
ygmn's Avatar
2015 E400 Sedan
Did you get battery tested?
Old 04-24-2019, 04:33 PM
J911brick's Avatar
W211 W204
Valeo
Old 04-24-2019, 04:34 PM
J911brick's Avatar
W211 W204
Yes, several times.
Old 04-24-2019, 04:37 PM
J911brick's Avatar
W211 W204
My thought right now is either the DME or imoilizer is not energizing the exciter circuit after the car has been turned off (possibly with setting the alarm).
Old 04-24-2019, 04:38 PM
I would get a bosch or oem alternator these cars are pretty suborn about their alternators.
Old 04-24-2019, 04:39 PM
mrmotoguzzi00's Avatar
16 E550 Cab, 2003 Ram bright red crewcab 4x4 we call Clifford :)
sounds like your left with questionable battery ? if you really want to confirm you could put a temp battery in there or borrow a known good one if you have another car.... rig a multimeter inside or under the wiper to watch it real time.... just tossing stuff out there....
J911brick's Avatar
W211 W204
Wiring diagrams would help.
Old 04-24-2019, 05:24 PM
J911brick's Avatar
W211 W204
You are probably right but I thought valeo was oem?
Old 04-24-2019, 05:27 PM
J911brick's Avatar
W211 W204
Trying to source another battery to borrow.
Old 05-03-2019, 10:38 PM
J911brick's Avatar
W211 W204
Turns out problem was alternator. Replaced with New Valeo unit.
Rate This Thread
Rate This Thread:
Quick Reply: Strange Charging problem
