C63 AMG (W204) 2008 - 2015
Urgent-help needed! Lean code
Old 04-23-2019, 06:37 PM
hookah's Avatar
2012 C63 P31 LSD-Current: My past 1999 C43, 2004 Clk55, 1999 C280 sport, 1995 C280
Guys my car is in the shop. Last week I took it for check engine light and car was showing a lean code. They pinpointed a leak in one of the intake manifold gaskets. Replaced both gaskets and bolts for both side. Also did spark plugs while in there. A few days after picking up CEL came back on and now the tech is saying they are finding a leak potentially in the middle portion of the manifold. RPMs started idling high and somewhat sporadic after the initial work as well. He is saying Mercedes does not sell a middle gasket and I would potentially need a new manifold for $3k. Please help with any options or even if you know a good tech in the Bay Area that has expertise in this. Thanks
Old 04-23-2019, 07:04 PM
BLKROKT's Avatar
Received 2,810 Likes on 1,664 Posts
That “middle gasket” is just a rubber oring. When I took mine apart to clean it, I found that mine had a pinch in it from the factory (never noticed any issues, was prob not leaking). I sealed it back up with some RTV on the mating surfaces as well as on the outside, and it’s sealed just fine. I think you should take it apart and spend some time cleaning the surfaces and checking the oring, then sealing with a good amount of RTV. Or ask your shop to do that. Or take it somewhere else. You shouldn’t be replacing the IM unless the metal is rotted away which is about the only thing that can’t be fixed.
Old 04-23-2019, 08:55 PM
hookah's Avatar
Thanks, I was hoping to hear something like that. My tech suggested the same thing. I think I will go that route first and if all checks out when he opens i then just re seal and be set. Hoping thats all it is. Do you know if they sell that O ring seperately? my shop says Mercedes only lists you having to buy a entire IM. I would do this myself but with my current work load I have no time to do bigger jobs on the car.
Old 04-23-2019, 09:27 PM
Crya's Avatar
2009 C63 P30
I personally haven’t used them yet but it’s the shop I’ll use for engine mounts. A guy with a highly modified coupe recommended German Auto tech in Walnut Creek. They did his tune, headers, a bunch of stuff. They may be able to help you out.
Old 04-23-2019, 10:58 PM
BLKROKT's Avatar
They don’t sell the oring separately. MB considers the IM “non-serviceable”. There aren’t even torque values for the clam bolts in WIS.
Old 04-26-2019, 02:57 PM
hookah's Avatar
So my shop split the manifold and re sealed the IM. Unfortunately the tested it after with carb cleaner and there is still a slight leak as the idle fluctuates when carb cleaner is sprayed. I picked it up yesterday and he said the CEL would likely come back. Sure enough it popped back on last night. So seems I will need a new IM. Can anyone help on where to source one? I do not want to pay $3k to buy one from Mercedes. Any help would be appreciated.
Old 04-26-2019, 03:09 PM
BLKROKT's Avatar
That’s weird. Can they not pinpoint exactly where the leak is coming from? It shouldn’t be hard to figure out what’s going on, the idle will jump where they are spraying and that’s where the problem area will be. Is the o ring compromised, did they check it carefully. Only if the metal is rotted or there’s a crack I’d replace it. Otherwise practically anything else can be fixed. I don’t even see how it’s possible for that to get warped, but you have to track down exactly what is leaking and where before you can figure out if it’s a $5 fix or $3k.
I’ve even seen these Al/Mg manifolds get welded before. The R63 guy did it and it was tricky but turned out fine. Don’t give up so easily.
Old 04-26-2019, 03:15 PM
hookah's Avatar
My tech said they cleaned and inspected and could not find any issue with the casing or gasket. I located a company through CARID named RMT that will completely refurbish the IM for about $530. They said I send it out to them and I would have it back by next Friday. Considering this route. They do not have any refurbished ones on hand until June for some reason. I would prefer sending mine out anyway so I keep my original part and plaque.
Old 04-26-2019, 03:50 PM
manuelsm's Avatar
C63 amg
DO NOT USE rmt company i purchased the middle plate where the throttles go and the gasket from them melted and had to do everything again and buy a used plate from ebay
Old 04-26-2019, 04:42 PM
hookah's Avatar
Jeez! Thanks for the heads up. Do you know any company that would be better?
Old 05-03-2019, 02:57 PM
manuelsm's Avatar
C63 amg
Do you only need the gasket ?
Old 05-11-2019, 05:26 PM
p31c63amg's Avatar
12-P31 C63 Coupe- 19-GLC 63 S COUPE -18-911 TURBO S 19 AMG GTR COUPE
vacuum hoses, sounds like either mileage and heat or maybe pulled on a vacuum hose to hard playing with you air filters.
Old 05-11-2019, 05:49 PM
skratch77's Avatar
2005 E55
Need to make sure the vacume hose under the pcv valve has no leaks anywhere it goes to.
That line goes directly under the throttle body flaps and will let air in past the blades.
Old 05-11-2019, 09:26 PM
p31c63amg's Avatar
Leak
It’s most likely where your air intake mounts to the throttle body. You will find a vacuum hose and a some what rigid vacuum tube. Sometimes when you take off your intake or play with removing the air filter housing one could damage one of the two vacuum hoses. I had this happen it caused a CEL light and a lean bank code. Have your local MB AMG tech check for this leak. The techs have all the toys to figure out these types of leaks. It took my tech a few day of replacing intake gaskets among other things to find the less than $100 part to fix it. Hope this helps.
Rate This Thread
Rate This Thread:
Quick Reply: Urgent-help needed! Lean code
