Feasibility of DIY maintenance on GLK's??
Hello All,
I'm on the tail end of my first overseas tour in Europe, I brought a Toyota Tacoma, which i sold, and bought a 95 BMW 520, i fell in love with the German driving experience, minus the maintenance cost however I was able to do a lot on my own saving me thousands.
Heading back to the states now and I'm considering the 2015 GLK 350. I see that it has several JD Power awards and I'm looking for somthing all wheel drive with some power.
My question is: what's the feasibility of DIY maintenance on these things? Brake jobs, A/C, anything apart from engine or transmission work? Scotty Kilmer says that even a simple brake job requires a computer code reset with his $5000. MB diagnostic tool.. I'm only an enlistedman and dont have that kind of money yet..
Any advice on the subject to include typical repairs with the 2015 that y'all have experienced would be greatly appreciated!
14 GLK 250
Hello All,
4f
4f
4f
4f
Well I do everything myself, and just did my brakes, and did not need any computer. I do have a Mercedes scan tool though, icarsoft MBII, 150$.
It's a car. They mostly all do the same thing and go together in the same general way. If you have always worked on your own stuff as some of us here have then you will be fine. If not then look for something that won't incur the German tax at the service department.
2010 Mb here, pretty easy and basic maintenance like any other car. We have done brakes, plugs, tranny and diff flushes, oil changes. Only needed icarsoft for tranny temp to get the level.
I heard spark plugs are PITA with DFI engines (2013+).
I would seriously consider RWD with good winter tires for winter.
Less stuff to break, cheaper to buy, easy engine mount replacment, better mpg... 4matic is a nice system tho. I’ve had my AWD GLK for 93k miles with no issues, and it gets you thorugh snow banks on all-seasons (not enough snow here to justify winter tires).
If youre looking at a 2015 glk350...you might as well look at an older w166 ml400 or ml550. They're more fun and more autobahn cruisers.
If you're stuck on the size. The glc is a better option as it is updated and more recent of an interior than the glk.
The I carsoft mb2 is 200......dont believe every thing you watch on th e internet.
The following 2 users liked this post by B737:
BLKROKT (05-30-2019),
Bozzy J Winters (05-23-2019)
Some things are easy to replace such as the radar sensors for blind spot monitoring. I replaced it myself without removing bumpers or anything. Front struts and rear shocks are easy to do at home too. Rotors and pads are easy to do. Oil changes are nice and simple. Rear diff fluid is easy. Spark plugs for the m276 3.5L engines are easy but very time consuming. Air filter and cabin filter is easy.
The hardest thing to fix is the shaft seal since the transfer case is built into it. If the output shaft seal leaks, you need to drop the transmission and tear it apart to replace the seal from the inside. Stupid design. It will cost me 2k to fix a damn seal so I'm driving my GLK for the next couple of years while it leaks only in the winter time. It should last me until then.
I have a GLC 300 and my wife has a GLK 250, both are 4 matic. Only routine maintenance so far but both have been pretty easy to work on. The only minor issue was the cabin filter, not difficult but a PITA because you're laying on your back in the foot well. Don't believe this MB "rocket science" stuff. It's in the dealer's interest to make things sound complicated - for obvious reasons.
Location: Saratoga Springs, New York & Sarasota, Florida.
MB’s
Hello All,
Now as far as the 2015 GLK350. The engine and tranny are bulletproof when properly maintained. The engine and trans is a tried and true run of the mill MB powertrain as it is used in many cars in the MB lineup. A simple google search will show that the GLK is very DIY. Brake flush, spark plugs, ect. Here are some videos below. You are 100% in the right place. Use the search forums tool as well to find whatever else you need. There are so many videos, links and articles. Also, there is a GLK Specific forum as well. http://www.mercedesglk.org/
Coolant flush DIY : https://mbworld.org/forums/glk-class...tructions.html
Brake Job DIY:
Oil Change DIY: https://mbworld.org/forums/glk-class...il-change.html
Also read the service guides for the X204 GLK on when to service it. If you have to run to the dealer for every little issue then yes it can be expensive but to DIY you make the car as affordable as a HONDA or Toyota.
The GLK is def easy to work on, but its not without its complexities. It is kind of simple as far as Mercedes go, which is a good thing. However i would reserve the term "bullet proof" for cars from toyota, and honda... def not the GLK. Our GLK is used by my SO and am thankful she doesnt beat on it, because if this truck was abused i could see how easily it could become a problem.
Here is one easy DIY....engine mounts on 4Matic. Engine swap might be easier or about the same.
Front diff without fill plug...actually not as hard as it sound, but still.
Tranny pan with one plug for drain/fill/level...c'mon.
But what I like about GLK is use of aluminum and splash covers! Almost nothing rusts, except for exhaust. Indestructible Land-cruiser/LX570 on the other hand makes a "simple" job a nightmare! I'm conflicted at the moment...Except for engine mounts, I've had less issues and easier maintenance on GLK.
MB’s
uhhh i definitely would not call the transmission in the GLK "bullet proof". Its all-in-one torque converter, transfer case design is really dumb, and prone to leaks. Once it starts leaking, the entire thing needs to come out and get opened up. Thousands of dollars. Want to swap it out? that would need to get coded, likely by a dealer. Just search this subsection for "transmission" and you'll see enough nightmares.
Have you owned other MB's other then a GLK? If you have then you will know the GLK is simple by MB Standard. Especially when compared to the other models like the E, S, CL... The powertrain is a MB bread and butter. Not complex at all. The 3.5 V6 7Speed is a solid set up. I have it in many cars and it has been fine.
A bit off topic but I've included a couple of videos for those who are interested.
MB’s
Completely agree. Much of what I've seen from this guy is outdated, misleading or just plain wrong. One example is the effect of stop-start technology. Comparing what Kilmer says to what John Cadogan (a qualified mechanical engineer) says is pretty enlightening. Both agree that it's annoying, useless and just a way for manufacturers to game the fuel economy figures, but that's where the similarities end. Kilmer says that stop-start will do nasty things including premature engine wear and killing the starter. On the other hand, Cadogan says that due to the technologies involved (stopping the engine at TDC etc) and the fact that starting a warm engine causes zero wear (unlike a cold start where most engine wear occurs), there are no negative effects.
Why Not to Buy a Car with Stop/Start Technology - YouTube
The truth about engine stop start systems | Auto Expert John Cadogan | Australia - YouTube
