E-Class (W211) 2003-2009
Transmission jerks when I put in D or R
Old 05-19-2019, 08:20 PM
Malek Hussein's Avatar
2006 Mercedes E350
Clunks violently when I put it into drive or reverse pulled some codes off of carly but cant find anything on google.
Old 05-20-2019, 09:00 PM
F1Fan's Avatar
Transmission mount needs to be replaced?
Old 05-20-2019, 09:01 PM
2006 Mercedes E350
Thats what i thought but i took it for a spin today and the car doesnt get out of 1st gear even if i try shifting manually
Old 05-21-2019, 08:15 AM
scotterikson's Avatar
01 clk430, 05 e500 4matic
Were you able to clear the codes you posted above? Seems you have an unhappy TCU and are in "limp home" mode.
Old 05-21-2019, 09:08 AM
2006 Mercedes E350
I used Carly to clear the codes and the car is still in limp mode and I can't find out how to get it out.
Old 05-23-2019, 11:01 PM
MBENZTECH's Avatar
W203 W212 W211 R53MCS
You will need a conductor plate. Most likely a malfunction of an internal speed sensor. It's in safe mode.
Old 05-23-2019, 11:44 PM
tjts1's Avatar
C320
Carly can only read codes from the ECU not the TCM. Your car is stuck in limp home mode. You need a scan tool that will talk to the TCM. Limp home mode can be caused by any number of issues and without reading codes you won't be able to find out what it is or bring it out of limp home mode. Your options are find a shop with MB star, I carsoft or Foxwell. Good luck.
Old 05-24-2019, 12:10 AM
2006 Mercedes E350
I bought a icarsoft what would i look for using it?
Old 05-24-2019, 12:17 AM
tjts1's Avatar
C320
What transmission codes do you have?
Old 05-24-2019, 12:22 AM
2006 Mercedes E350
I got 0513 and 0562
Old 05-24-2019, 12:40 AM
2006 Mercedes E350
Cleared the codes and 0513 is the only one that keeps popping up
Old 05-24-2019, 12:49 AM
tjts1's Avatar
C320
Ok and what's the description attached to those? Are you reading these codes from the TCM with the icarsoft tool? Do you have a 5spd or a 7spd?
Old 05-24-2019, 12:53 AM
2006 Mercedes E350
0513 is "The CAN signal for start enable sent to the drive authorization system by transmission control is missing or invalid."
0562 is "The voltage supply of circuit 87 has undervoltage."
Old 05-24-2019, 12:55 AM
tjts1's Avatar
C320
Well it depends on which transmission you have. You can try resetting the codes in the TCM and see if it pops out of limp home mode. If it does that's only a temporary fix.
Old 05-24-2019, 12:59 AM
2006 Mercedes E350
It's the 722.9 transmission. I clear the codes but nothing changes. Can't switch it from comfort to sport and wont go through gears when i manually shift it. It just stays in first gear.
Old 05-24-2019, 01:03 AM
tjts1's Avatar
C320
Well the most likely failure on a 722.9 is a bad conductor plate. The 722.9 conductor plate contains the TCM and the TCM is coded to the car. You need to find a transmission shop that can get a new conductor plate from MB. They won't sell it to just anybody since they need to know the vin of your car to make you specifically for it.
Old 05-24-2019, 01:12 AM
2006 Mercedes E350
Couldn't it be due low voltage from the battery?
Old 05-24-2019, 01:15 AM
tjts1's Avatar
C320
If that was the issue and you fixed the low voltage problem and cleared the codes the transmission would operate normally again. Once the engine is running the operating voltage is determined by the alternator's voltage regulator, not the battery.
Old 05-24-2019, 05:09 AM
Maroc_Specops's Avatar
W211 E320 CDI Sportpackage With Carlsson CD32 Chip 2004
Either ur battery is weak
Or ur tcu needs replacement
Or anything from solenoids to transmission filter clogged.
It's one of the most frequent occurring errors.
Personally, I think ur speedsensor 1 or 2 is gone. Most likely by a broken transmission unit.
Old 05-24-2019, 08:14 AM
2006 Mercedes E350
I'm going to check on the battery tomorrow and have it tested and shouldn't I be getting codes for the speed sensor? So weird how there weren't any warning signs of this happening.
Old 05-25-2019, 02:08 AM
benznyc's Avatar
ml/e420/others
transmission
Old 05-25-2019, 10:43 PM
2006 Mercedes E350
Originally Posted by benznyc
transmission
Great answer!!
scotterikson (05-26-2019)
Old 05-28-2019, 08:54 PM
benznyc's Avatar
ml/e420/others
Great answer!!
yes replace the transmission.had the same problem on my old ml and clk.
Old 05-28-2019, 08:56 PM
tjts1's Avatar
C320
LOL you fool.
Old 05-28-2019, 09:10 PM
benznyc's Avatar
ml/e420/others
was cheaper to change the transmission moron!
Quick Reply: Transmission jerks when I put in D or R
