A first world problem..........
...... windshield wipers shudder and are noisy when they make the change of direction at the end of their stroke.
Using windshield washer fluid helps temporarily but they are soon back to their noisy selves
Any thoughts or solutions to my seriously first world problem ;-)?
Below is the link. Other companies offer similar products like Rain-X but I've found Liqui Moly the longest lasting and cleanest on application ( Rain-X can fog the windscreen requiring buffing with a micro-fibre - not a big deal but a con nonetheless )
https://www.sgcarmart.com/products/overview.php?ID=5765
One application will last 2 to 6 weeks, depending on amount of rain exposure and dust. One bottle lasts me about 3 months but I like to apply a lot.
On my new W213, I have yet to use the wipers so far during 8 months of ownership.
Wash your windshield good. I had chattering wiper blades in a brand new F-150 pickup and the mechanic wahsed the windshield. I don't know what fluid was used but it worked. I like ammonia and water.
Mike.
Mike.
I just did a search and found that there has been a class action law suit against Rain-X claiming that it damages fluid level sensors and I just put Rain-X in my SL The suit was dismissed but I don't know if it was proven to be true or not.
Mike.
Mike.
It makes noises because it's dirty. You can use denatured alcohol diluted with water, this will strip away any grease, grime, wax etc from the glass (and the paint if you overspray), if you want a safer option use some no-ammonia glass cleaner, do several passes. You also have to clean the wiper blades, you can use the same glass cleaner or a mild degreaser, even a bit of dish soap.
I dont use rainx, I want to use the rain sensing wipers that I paid for.
gfmohn (07-29-2019)
2021 E450, 2020 C43, 2015 C300, 2007 C280
Thanks for the part about the finger oil. My MB is not garaged, and I frequently have to remove tree bits stuck under the wipers. I'll use a rag from now on. I have used Rain-X on previous, non-Mercedes cars and on the visor of my motorcycle helmet.. It was effective, but it took a lot of work to buff it clear.
Anyone having this problem I would strongly advise to contact your dealer and MB, after you’ve cleaned your windshield and issue is still there it’s obvious its not the windshield but the defective wipers.
Some years ago, I wanted to replace wipers on a Toyota Avalon. It had been a while, and they didn't clear as well as I thought they should (but they ran smoothly). At Sam's Club, I saw these relatively expensive wipers for sale, special super-duper wipers, for like $30 each. I bought them, and after installation, those things hopped across my windshield like an Olympic hop, skip and jump! Cleaned the windshield with everything I could think of: no change. Took them back, and bought $5 Trico wipers from Walmart. Worked like a charm, and lasted well.
Sometimes higher quality, just isn't.
Hi
I hear many people referring to rain x. But I don’t use rain x and have been back to the dealer on so many occasions. They cant fix this damn issue and it is so frustrating for an expensive car.
I have a 2017 E300 and I have been told this is normal wiper movement - it is not.
Is this a big issue and what numbers do you know are affected. Maybe the only thing that will work is taking a class action against Mercedes.
Has the dealer preformed any fixes that truly worked?
05 SL55, 10 C63, 12 SLK350, 20 S560, 08 Bentley, 14 Porsche Cayman S
Clean the glass. First clean the glass with window cleaner then clay bar the glass. Then use the window cleaner again. You won’t believe how much it helps.
I clean the wiper blades with a microfiber cloth when I wash the car and keep the glass very clean. I've never had an issue with wipers. Do not let rain water dry on the glass because it contains impurities that will adhere. A quick cycle with washer solution is enough to avoid the problem.
As I've said before, upon picking up my new 2020 E450 wagon from the dealership and driving it an hour home, a light rain occurred, and my wipers hopped across my new windshield. Of course they'd just cleaned the car, had it inside presented with a bow (just after Christmas), etc. I think it's design, or the wiper material.
