Radio Rebooting Every 2 mins ???
Old 05-26-2019, 08:18 AM
FastWagon's Avatar
My 2014 G550 radio comes on and plays for about 2 mins then it will freeze (no buttons works during this time) it will then reboot. It will keep doing this cycle about every 2 mins. One thing that I have noticed is if you try to select Navigation when it first comes on I will give you a drive error. (DRIVE unavailable). I think that the NAV is trying to load and when it does not load it makes the unit reboot. I have only had this vehicle for a few months. Is the navigation built into the Comand unit? Has anyone seen this before?
Last edited by FastWagon; 05-26-2019 at 09:41 AM. Reason: Adding a picture and fixing a typo
Old 05-26-2019, 09:41 AM
FastWagon's Avatar
When you click on the Navi option this is what you get on the screen.
Old 05-26-2019, 10:24 AM
lou1947's Avatar
Try disconnecting the main car battery and let the system reboot. Hope it works.
Old 05-26-2019, 12:05 PM
Mopars's Avatar
2018 G63
Sure sounds like a corrupted program. Good luck with battery reboot.
Old 05-26-2019, 11:56 PM
fabbrisd1's Avatar
Received 1,099 Likes on 805 Posts
A gaggle of MB's
Please do not disconnect the battery - if you go that route then you need to reset a handful of other things like - reset each window - and reset sunroof - or you stand a good chance down the road to "blow" a window regulator or the sunroof.
For your COMAND - hold the Power Button down for 10-15secs and the COMAND "should" go into reboot mode.
It is quite possible the COMAND unit will need to be reprogrammed at the dealer - which online in the shop can takes up a couple hrs shop time - the good news is there probably a updated COMAND programming - you can call your local dealer about that.
Old 05-27-2019, 06:07 AM
ygmn's Avatar
2015 E400 Sedan
go get the COMAND software updated...
Had same issue on my 2015 E class....
First time they could not duplicate...
Second time I specificially said problem is still there please check if there is software update as I am sure it will fix my issues...
(got a tip on some TSBs in W212 section TSB which had similar issues and stated update software)
Good Luck
Old 05-27-2019, 08:19 AM
Mopars's Avatar
2018 G63
If you are in the US you can use this site to see if there is a recall affecting your G.
https://www.nhtsa.gov/recalls?gclid=...E&gclsrc=aw.ds
FastWagon (05-28-2019)
Quick Reply: Radio Rebooting Every 2 mins ???
