The Ultimate Guide to the w212 AMG E63
Received 1,886 Likes
(MY 2012-2016)
I've been compiling and organizing the most commonly asked questions on this forum and requested DIY related to the w212 E63. This is also predominantly about the m157 engine and therefore may help you with other AMG platforms in a wider range of model(s) years(s). Also most of these discussions will apply to m278 engines. I'll keep updating this thread as we go along. Keep in mind that if you don't find an answer to your w212 non-amg question here, consider searching the w212 non-amg forum:
https://mbworld.org/forums/e-class-w212-109/
If you have questions about the m156 engine
(MY 2010-2011) you may gain more traction in the w204 amg section (C63) as it has the same engine and is an active forum:
https://mbworld.org/forums/c63-amg-w204-93/
If you are in the market for a used w212 2012+ E63 or m157 based AMG this is a resource that may help you while shopping.
Thanks to the many forum members that contributed to or started these great discussions.
************************************************** *****(MY 2012-2016)
¥¥¥¥¥¥¥¥¥¥¥¥¥¥¥¥INDEX¥¥¥¥¥¥¥¥¥¥¥¥¥¥¥¥¥
- Getting to know this platform
- ⚠️ Oil Pump Solenoid - MUST READ
- Brakes Discussion
- Front End
- Fluids
- Tuning/Misfires/Boost/ECU/TCU/Trans
- Spark plugs, indexing, coil packs
- Airmatic, Lowering the w212
- Weird Noises
- Throttle/Shifts/Lag
- Panoramic Roof Issues
- Exhaust Discussion
- Audio Talk
- ⚠️ Oil in Wire Harnesses - MUST READ
- Wheels
- Alignment
- Vacuum Check Valve Repair
- Interior, Miscellaneous, ⚠️ Cylinder Scuffing
GETTING TO KNOW THIS PLATFORM 📚:
COMMON M157 ISSUES - GREAT ARTICLE:
https://tuningpro.co/the-5-most-comm...gine-problems/
DETAILED SPECS ON M157 ENGINE:
https://dustrunnersauto.com/mercedes...-need-to-know/
MORE INFO ON M157 ENGINE - BENZ ISSUED
https://mbworld.org/forums/attachmen...matic-m157.pdf
M156 vs. M157 VIDEO AND DISCUSSION:
https://mbworld.org/forums/w212-amg/...6-vs-m157.html
2014 E-CLASS BROCHURE:
https://cdn.dealereprocess.org/cdn/b...014-eclass.pdf
2014 E-CLASS OWNER'S MANUAL:
https://www.mbusa.com/content/dam/mb...n_Operator.pdf
2014 E63 Dealer Ordering Guide:
https://mbworld.org/forums/attachmen...s_dog_v2.7.pdf
W212 AMG PRODUCTION NUMBERS:
https://mbworld.org/forums/w212-amg/...numbers-2.html
BULLETINS/TSB/CAMPAIGNS ON W212 PLATFORM:
https://mbworld.org/forums/e-class-w...212-sedan.html
REAR SUBFRAME CORROSION/COVERAGE:
https://mbworld.org/forums/w212-amg/...corrosion.html
EXTENDED WARRANTY CYLINDER HEAD, EXHAUST VALVE:
https://mbworld.org/forums/ml63-amg-...nder-head.html
SERVICE INFO ON W212 PLATFORM:
FACTORY WIS AND REPAIR DOCUMENTS:
https://mbworld.org/forums/w212-amg/...documents.html
@kenneyd E63 DIY YOUTUBE CHANNEL
https://youtube.com/@ExoticCarDIY
⚠️ CYLINDER SCUFFING Discussion:
https://mbworld.org/forums/w212-amg/...ight-help.html
WHAT IS STOCK MAX BOOST?
https://mbworld.org/forums/w212-amg/...psi-stock.html
E63 vs E63S
https://mbworld.org/forums/w212-amg/...3-s-worth.html
E55 to E63 DISCUSSION:
https://mbworld.org/forums/w212-amg/...63s-wagon.html
PICS OF UNDERCARRIAGE:
https://mbworld.org/forums/w212-amg/...ml#post8678933
OVERVIEW OF THE E63S - VERY INFORMATIVE!
https://mbworld.org/forums/w212-amg/...ml#post8300568
2014+ RWD vs AWD E63S AND DRAG RACE VIDEO
https://mbworld.org/forums/w212-amg/...ml#post7976320
2013 vs 2014+ E63? AWD vs RWD
https://mbworld.org/forums/w212-amg/...-2014-e63.html
MORE AWD vs RWD E63 DISCUSSION:
https://mbworld.org/forums/w212-amg/...een-years.html
CARMAG REVIEWS
https://www.roadandtrack.com/new-car...-model-4matic/
https://www.motortrend.com/reviews/2...omparison/amp/
https://www.caranddriver.com/reviews...n-test-review/
HOW TO SAFELY JACK UP THE E63 (keep airmatic happy):
https://mbworld.org/forums/w212-amg/...-way-lock.html
JACKING POINTS
https://mbworld.org/forums/w212-amg/...ing-point.html
IS THIS CAR WORTH PURCHASING OVER 100K MILES?
https://mbworld.org/forums/w212-amg/...100kmiles.html
ADVICE ON BUYING USED E63?
https://mbworld.org/forums/w212-amg/...-oil-leak.html
GOOD HIGH MILES M157 STORY
https://mbworld.org/forums/w212-amg/...ml#post8693630
100,000 miles - WHAT PREVENTATIVE MAINTENANCE TO CONSIDER?
https://mbworld.org/forums/w212-amg/...things-do.html
FIDELITY EXTENDED WARRANTY DISCUSSION - With real experience on claim
https://mbworld.org/forums/w212-amg/...60k-miles.html
722.9 Transmission Guide
https://blog.fcpeuro.com/the-definit...c-transmission
TRADE A CHEVY FOR AN E63?
https://mbworld.org/forums/w212-amg/...-ss-e63-2.html
OIL PUMP SOLENOID
Disconnect to help save your engine?
⚠️ MUST READ ⚠️
https://mbworld.org/forums/w212-amg/...lenoids-2.htmlOIL PUMP SOLENOID
⚠️ MUST READ ⚠️
+++++++++++++++++++++++++++++++++++++BRAKES:
https://mbworld.org/forums/w212-amg/...placement.html
https://mbworld.org/forums/w212-amg/...-dealer-2.html
https://mbworld.org/forums/w212-amg/...rs-dealer.html
DO I EVEN NEED BRAKES YET?
https://mbworld.org/forums/w212-amg/...20k-miles.html
EBay BRAKE KIT / FCP EURO - full brake job $1400 (MY PERSONAL STORY)
https://mbworld.org/forums/w212-amg/...kits-ebay.html
DIY BRAKE JOB
https://mbworld.org/forums/w212-amg/...ad-change.html
LINKS TO CHEAP BRAKES/PARTS/PADS/ROTORS
https://mbworld.org/forums/w212-amg/...brake-job.html
BRAKE JOB: TORQUE SPECS
https://mbworld.org/forums/w212-amg/...e63s-w212.html
BRAKE PAD COMPARISON AFTERMARKET
https://mbworld.org/forums/w212-amg/...nt-brakes.html
CONVERT STEEL TO CARBON CERAMIC BRAKES CCB
https://mbworld.org/forums/w212-amg/...t-numbers.html
390mm BRAKE CALIPER INSTALL:
https://mbworld.org/forums/w212-amg/...y-no-dust.html
WEIGHT OF STEEL vs CCB
https://mbworld.org/forums/w212-amg/...ml#post8596451
FLAKING AND PEELING OF RED CALIPER PAINT AND WARRANTY DISCUSSION:
https://mbworld.org/forums/w212-amg/...-calipers.html
STICKING PARKING BRAKE:
https://mbworld.org/forums/w212-amg/...ing-brake.html
BRAKE LINE FAILURE/LEAK:
https://mbworld.org/forums/w212-amg/...-2014-60k.html
W213 BRAKES/CALIPERS/ROTORS ON W212
https://mbworld.org/forums/w212-amg/...s-fitment.html
FRONT END:
TORN, LEAKING CV BOOTS -
https://mbworld.org/forums/w212-amg/...-our-cars.html
FRONT END/SUSPENSION SQUEAK/CREAK?
https://mbworld.org/forums/w212-amg/...ml#post7808601
FRONT DIFFERENTIAL LEAK (common)
https://mbworld.org/forums/w212-amg/...diff-leak.html
CONTROL ARMS....COMMON ISSUE
https://mbworld.org/forums/w212-amg/...front-end.html
MEVOTECH control arm (tie rod/control arm) front: CMS101396 (will NOT show e63 compatibility - that's ok it still fits)
https://a.co/d/5j5SPqD
https://www.rockauto.com/en/parts/me...trol+arm,10401
MEVOTECH control arm superiority to OEM:
https://mbworld.org/forums/w212-amg/...ure-again.html
MEVOTECH @ 44,000 - FLAWLESS
https://mbworld.org/forums/w212-amg/...000-miles.html
FRONT SUSPENSION AND BALL JOINTS WITH VIDEO - GROANING WITH STEERING:
https://mbworld.org/forums/w212-amg/...bad-30k-2.html
FRONT AXLE TORQUE SPECS
https://mbworld.org/forums/w212-amg/...que-specs.html
FLUIDS 💦
BLACKSTONE OIL ANALYSIS M157:
https://mbworld.org/forums/w212-amg/...is-result.html
TRANS AND DIFF FLUID TYPE AND CHANGE
https://mbworld.org/forums/w212-amg/...ml#post8199006
BEWARE FCP EURO TRANS FLUID (liquid moly)
Rough shift after trans fluid change:
https://mbworld.org/forums/w212-amg/...id-change.html
FRONT DIFFERENTIAL SERVICE
https://mbworld.org/forums/w212-amg/...l-service.html
WASHER FLUID DELAY - fixed
https://mbworld.org/forums/w212-amg/...uid-delay.html
LOW COOLANT ISSUES?
https://mbworld.org/forums/w212-amg/...nsumption.html
https://mbworld.org/forums/w212-amg/...reservoir.html
LOW COOLANT
https://mbworld.org/forums/w212-amg/...ant-level.html
COOLANT MIXING WITH OIL
https://mbworld.org/forums/w212-amg/...ing-about.html
TURBO COOLANT LINES LEAK/REPAIR/COST:
https://mbworld.org/forums/w212-amg/...bite-dust.html
TURBO COOLANT LINES REPAIR WITH PICS:
https://mbworld.org/forums/w212-amg/...lacment-2.html
WATER PUMP REPAIR
https://mbworld.org/forums/w212-amg/...king-m157.html
INTERCOOLER PUMP FAIL, signs, symptoms, HIGH IATs
https://mbworld.org/forums/w212-amg/...ml#post8660722
OIL LEAK PASSENGER SIDE:
https://mbworld.org/forums/w212-amg/...ing-cover.html
OIL CHANGE: MIGHT VAC EXTRACTION VS. DRAIN FROM BOTTOM:
https://mbworld.org/forums/w212-amg/...l-changes.html
OIL CONSUMPTION DISCUSSION:
OIL CONSUMPTION - PART 2
https://mbworld.org/forums/w212-amg/...gs-2015-a.html
OIL CONSUMPTION - PART 3
OIL TEMP TAKES LONG TIME TO WARM UP:
https://mbworld.org/forums/w212-amg/...e-problem.html
OIL CAPACITY, OIL CHANGE DISCUSSION:
https://mbworld.org/forums/w212-amg/...questions.html
OIL TEMPS DROP ON HIGHWAY IN WINTER:
https://mbworld.org/forums/w212-amg/...ow-winter.html
⚠️ OIL PUMP SOLENOID- "UNPLUG IT" Discussion
CHECK OIL PRESSURE (wis/pdf):
https://mbworld.org/forums/w212-amg/...sor-gauge.html
COOLANT AND WATER PUMP REPAIR:
COOLANT EXPANSION TANK LEAK/DIY repair
https://mbworld.org/forums/w212-amg/...ml#post8671398
COOLANT TANK AND CAP PROBLEM:
https://mbworld.org/forums/w212-amg/...eak-flush.html
COOLANT PUMP FAILING WITH PICS
https://mbworld.org/forums/w212-amg/...lant-leak.html
🏎️ TUNING :: FUEL :: MISFIRES :: BOOST 🏎️
DYNO MODE
https://mbworld.org/forums/w212-amg/...-mode-how.html
LOSING POWER/BOOST MID-RPM-RANGE:
https://mbworld.org/forums/w212-amg/...30-45-mph.html
FAILING FUEL PUMPS - FUEL STARVED
P0087 code
https://mbworld.org/forums/w212-amg/...situation.html
LOW BOOST DISCUSSION:
https://mbworld.org/forums/w212-amg-146/
HP TUNERS DISCUSSION:
https://mbworld.org/forums/w212-amg/...w212-m157.html
IS AN AFTERMARKET AIR FILTER WORTH IT?
https://mbworld.org/forums/w212-amg/...installed.html
CAN I BUY AN EXTRA ECU FOR TUNING PURPOSES?
https://mbworld.org/forums/w212-amg/...cu-tune-2.html
AMS TUNE WITH SECOND ECU:
https://mbworld.org/forums/w212-amg/...ng-strong.html
AMS TUNE UPDATE:
CEL / MISFIRES on AMS tune, DIY to REPLACE COILPACKS WITH VIDEO:
https://mbworld.org/forums/w212-amg/...ml#post8073603
MISFIRES 2:
https://mbworld.org/forums/w212-amg/...-e63-amgs.html
MISFIRES 3:
https://mbworld.org/forums/w212-amg/...-misfires.html
MISFIRES 4:
https://mbworld.org/forums/w212-amg/...t-misfire.html
MISFIRES 5:
https://mbworld.org/forums/w212-amg/...h-exhaust.html
MISFIRES 6:
https://mbworld.org/forums/w212-amg/...min-drive.html
VIBRATION AT IDLE OR MISFIRING AT IDLE?
https://mbworld.org/forums/w212-amg/...up-idling.html
MORE ON THIS AND CHANGING COILS:
https://mbworld.org/forums/w212-amg/...ml#post8493913
RENNTECH TUNE FEEDBACK AND REVIEW:
https://mbworld.org/forums/w212-amg/...ml#post7793777
RENNTECH TUNE REVIEW WITH DATA LOGGING - EXCELLENT:
https://mbworld.org/forums/w212-amg/...ml#post7879825
RENNTECH R1 Tune issues with great discussion:
https://mbworld.org/forums/w212-amg/...ge-issues.html
EC EUROCHARGED TUNE:
https://mbworld.org/forums/w212-amg/...rformance.html
MUST READ TUNER THREAD:
TCU TUNE
https://mbworld.org/forums/w212-amg/...tcu-tuned.html
MY PERSONAL TCU TUNE STORY:
AMS ECU TUNE PLUS EC TCU TUNE
https://mbworld.org/forums/w212-amg/...k-amazing.html
MY PERSONAL EUROCHARGED E30 tune story:
https://mbworld.org/forums/w212-amg/...w-amazing.html
BEST MODS - RETURN ON INVESTMENT:
https://mbworld.org/forums/w212-amg/...rket-mods.html
BEST MODS // BANG FOR BUCK:
https://mbworld.org/forums/w212-amg/...ml#post8190721
STOCK E63S DRAGY DATA, 0-60, 60-130, etc
https://mbworld.org/forums/w212-amg/...k-14-e63s.html
TUNED 60-130mph DRAGY DATA:
https://mbworld.org/forums/w212-amg/...-13-e63-2.html
AMS 100 OCTANE "SPARTAN TUNE":
https://mbworld.org/forums/w212-amg/...internals.html
BLACK BOOST M157 ENGINE BUILD
https://mbworld.org/forums/w212-amg/...lackboost.html
TUNE DISCUSSION ON LIMITS OF STOCK INTERNALS
https://mbworld.org/forums/w212-amg/...ml#post8695629
BENT RODS WITH TUNE:
https://mbworld.org/forums/w212-amg/...ence-m157.html
BLOW OF VALVE BOV INSTALL, REVIEW, VIDS
https://mbworld.org/forums/w212-amg/...st-review.html
TUNE E63 WITH HIGH MILES?
https://mbworld.org/forums/w212-amg/...2015-e63s.html
CONSIDERING PURCHASING A TUNED E63?
SELL IT MODDED OR STOCK?
https://mbworld.org/forums/w212-amg/...ded-stock.html
PART 1: FASTEST M157 E63 IN THE WORLD:
https://mbworld.org/forums/w212-amg/...201-3-mph.html
PART 2: FASTEST M157 E63 IN THE WORLD:
https://mbworld.org/forums/w212-amg/...12-record.html
PART 3: FASTEST.... DYNO VIDEOS
https://mbworld.org/forums/w212-amg/...goes-dyno.html
THE E63 "R" - A UNICORN BUILD
https://mbworld.org/forums/w212-amg/...ml#post8430101
INSTALLING BLACK BOOST INTAKES
https://mbworld.org/forums/w212-amg/...ml#post8416120
BLACKBOOST VS STOCK INTAKES WITH DATA:
https://mbworld.org/forums/w212-amg/...-intake-6.html
P2099 - Black Boost related?
https://mbworld.org/forums/w212-amg/...t-p209900.html
BLACKBOOST CLUTCHPACKS
https://mbworld.org/forums/w212-amg/...e-no-joke.html
BUILDING A BULLETPROOF TRANSMISSION:
https://mbworld.org/forums/w212-amg/...ans-build.html
P1CE8 or P1CE8 Code after black boost install:
https://mbworld.org/forums/w212-amg/...p1ce8-cel.html
ALWAYS ON IC PUMP MOD (Lower IATs)
https://mbworld.org/forums/w212-amg/...-rewiring.html
ETHANOL SENSOR INSTALL:
https://mbworld.org/forums/w212-amg/...tallation.html
SPARK PLUGS ⚡️
SPARK PLUGS AND GAP DISCUSSION FOR TUNES:
https://mbworld.org/forums/w212-amg/...tuned-e63.html
https://mbworld.org/forums/w212-amg/...-mercedes.html
DIY SPARK PLUGS
https://mbworld.org/forums/w212-amg/...ark-plugs.html
INDEXING PLUGS CORRECTLY
https://mbworld.org/forums/attachmen...g-indexing.pdf
SPARK PLUGS AND INDEXING:
https://mbworld.org/forums/w212-amg/...s-changed.html
INDEXING SPARK PLUGS
https://mbworld.org/forums/w212-amg/...ing-video.html
AIRMATIC ISSUES & LOWERING THE W212
airmatic won't rise after putting car on lift:
AIRMATIC aka airtragic malfunction #1
https://mbworld.org/forums/w212-amg/...-replaced.html
AIRMATIC malfunction #2
https://mbworld.org/forums/w212-amg/...ml#post8639544
AIRMATIC malfunction 3:
https://mbworld.org/forums/w212-amg/...pped-up-2.html
AIRMATIC malfunction 4: fuse blown compressor dead
https://mbworld.org/forums/w212-amg/...use-block.html
https://mbworld.org/forums/w212-amg/...tion-sign.html
AIRMATIC MALFUNCTION #5 - recal and block
https://mbworld.org/forums/w212-amg/...-airmatic.html
AIRMATIC malfunction 6: valve block fixed
https://mbworld.org/forums/w212-amg/...ion-light.html
HEADLIGHT LEVEL SENSOR AND SUSPENSION SENSOR ISSUE
https://mbworld.org/forums/w212-amg/...popped-up.html
REAR HEIGHT:
https://mbworld.org/forums/w212-amg/...de-height.html
AIRMATIC STUCK IN SPORT HEIGHT
https://mbworld.org/forums/w212-amg/...ic-issues.html
LOWERING THE W212 AMG
https://mbworld.org/forums/w212-amg/...w212-e63s.html
WEIRD NOISES 🩺
METALLIC GRINDING SOUND AFTER CAR SHUT OFF:
https://mbworld.org/forums/w212-amg/...-solenoid.html
CENTER DRIVESHAFT BEARING HUMMING:
https://mbworld.org/forums/w212-amg/...ain-30mph.html
HUMMING FROM WHEEL - WHEEL BEARING DIY
https://mbworld.org/forums/w212-amg/...ght-wheel.html
TENSIONER RATTLE FIX:
https://mbworld.org/forums/w212-amg/...rs-beware.html
RATTLE WHEN STARTING (Tensioner):
https://mbworld.org/forums/w212-amg/...ttle-help.html
WHISTLING AT 50MPH
https://mbworld.org/forums/w212-amg/...nt-grille.html
CLICKING HEARD OVER 50MPH
https://mbworld.org/forums/w212-amg/...nd-help-3.html
REAR DRIVESHAFT TICKING during first few miles/when cold between 30-40mph;
clicking from front end while driving has been described and has a fix:
https://mbworld.org/forums/w212-amg/...ound-help.html
NOISES AND OR GROANING WHILE TURNING
https://mbworld.org/forums/w213-amg/...-skipping.html
CLICKING WHILE TURNING
https://mbworld.org/forums/w212-amg/...you-think.html
STEERING GROANS AND MOANS:
https://mbworld.org/forums/w212-amg/...s-morning.html
MORE STEERING GROANS:
https://mbworld.org/forums/w212-amg/...ing-noise.html
MORE ON FRONT END CREAKING
REAR CLUNK - TOP MOUNT/SWAY BAR
https://mbworld.org/forums/w212-amg/...top-mount.html
DIY DRIVESHAFT FLEX COUPLER REPAIR
https://mbworld.org/forums/w212-amg/...-couplers.html
M157 TICKING/KNOCKING
https://mbworld.org/forums/ml63-amg-...ng-source.html
REPLACE REAR SHOCKS (not air bags):
https://mbworld.org/forums/w212-amg/...ar-shocks.html
PROBLEMS WITH THROTTLE, SHIFTS, LAG:
⚠️ UNPLUG OIL PUMP SMOOTHS OUT SHIFTS AND IMPROVES THROTTLE LAG AND MCT ENGAGEMENT
THROTTLE LAG (NOT TURBO LAG) - SPRINTBOOSTER HELPS (OR PEDALBOX)
https://mbworld.org/forums/w212-amg/...-annoying.html
TCU RESET AKA "PEDAL DANCE":
https://mbworld.org/forums/w212-amg/...oost-back.html
https://forums.mbclub.co.uk/threads/...n-when.249842/
DRIVELINE CLUNK DRIVE->REVERSE
https://mbworld.org/forums/w212-amg/...ine-noise.html
ROUGH DOWNSHIFT TO FIRST GEAR
https://mbworld.org/forums/w212-amg/...-1st-gear.html
2015+ UPDATED TRANSMISSION DISCUSSION:
https://mbworld.org/forums/w212-amg/...ifference.html
JERKY MCT BEHAVIOR:
https://mbworld.org/forums/w212-amg/...r-service.html
https://mbworld.org/forums/c63-amg-w...tcu-reset.html
MCT RE-ADAPTATION
THROTTLE LAG AND SPRINTBOOSTER
https://mbworld.org/forums/w212-amg/...-mct-e63s.html
HESITATION WITH SHIFTS UNDER WOT
https://mbworld.org/forums/w212-amg/...ml#post7750230
PANORAMIC ROOF ISSUES:
PANO PANORAMIC ROOF CREAKING CLICKING MAKING NOISE
https://mbworld.org/forums/e-class-w...ml#post6076954
FIX PANO ISSUES YOURSELF?
EXHAUST DISCUSSIONS 💨
X-PIPE SOUNDS CLIPS AND OTHER CLIPS:
https://mbworld.org/forums/w212-amg/...ound-clip.html
EXHAUST TALK
https://mbworld.org/forums/w212-amg/...uggestion.html
CUSTOM DOWNPIPES INSTALLED
https://mbworld.org/forums/w212-amg/...l-testing.html
RESONATOR DELETE - I WANT LOUDER EXHAUST
https://mbworld.org/forums/w212-amg/...ket-parts.html
MORE SOUND AND VIDEO CLIPS:
https://mbworld.org/forums/w212-amg/...-delete-2.html
AUDIO DISCUSSIONS 🔊 🎼
FULL AUDIO BUILD
https://mbworld.org/forums/w212-amg/...on-pics-2.html
ADD A SUBWOOFER
https://mbworld.org/forums/w212-amg/...sspro-hub.html
https://mbworld.org/forums/w212-amg/...rade-w212.html
APPLE CARPLAY FOR E63
https://mbworld.org/forums/w212-amg/...ispreloading=1
OIL IN ENGINE WIRE HARNESS,
OIL LEAK IN SENSORS
⚠️ MUST READ ⚠️
REPLACE/INSPECT CPS CAMSHAFT POSITION SENSORS - they leak oil and cause engine cancer - catastrophic issues:OIL LEAK IN SENSORS
⚠️ MUST READ ⚠️
https://mbworld.org/forums/w212-amg/...sors-leak.html
OIL IN CAM SENSORS
https://mbworld.org/forums/w212-amg/...ml#post8628042
OIL IN ECU AND WIRE HARNESSES:
OIL IN GL63 ENGINE WIRE HARNESS:
https://mbworld.org/forums/gl-class-...e-harness.html
MORE OIL IN 2015 E63S WIRE HARNESS, ECU
https://mbworld.org/forums/w212-amg/...ak-thread.html
OIL IN HARNESS GL450 - GREAT PICS, HOW TO CLEAN YOURSELF
https://mbworld.org/forums/gl-class-...ness-help.html
SACRIFICIAL HARNESSES TO PREVENT OIL CREEP:
https://mbworld.org/forums/w212-amg/...or-change.html
HARNESS PROTECTORS FOR LEAKING SENSORS
https://www.fcpeuro.com/products/mer...des-2711500156
CAN'T GET A SOLENOID OUT?
https://mbworld.org/forums/w212-amg/...rness-oil.html
🛞 WHEELS 🛞
WHAT DO STOCK WHEELS WEIGH?
https://mbworld.org/forums/w212-amg/...l-weights.html
WHEEL AND TIRE DISCUSSION
https://mbworld.org/forums/w212-amg/...formation.html
WHEEL FITMENT:
https://mbworld.org/forums/w212-amg/...ment-e63s.html
WHEEL SPACERS WITH VIDEO
https://mbworld.org/forums/w212-amg/...ited-w212.html
W213 WHEELS on W212
https://mbworld.org/forums/w212-amg/...eels-w212.html
WINTER WHEELS
https://mbworld.org/forums/w212-amg/...-packages.html
LIGHTER WHEELS
https://mbworld.org/forums/w212-amg/...l-14-e63s.html
YOU CAN'T DO 18" WHEELS ON AWD E63
NEED AN OEM RIM?
https://www.originalwheels.com/merce...ss2014rims.php
https://i1parts.com/
https://wheelsamerica.com/?product_c...t_type=product
WHEEL TIRE COMBO ULTIMATE THREAD:
CURB RASH REPAIR:
https://mbworld.org/forums/w212-amg/...sh-repair.html
WHY YOU NEED WINTER TIRED IN WINTER
https://mbworld.org/forums/w212-amg/...e63-wagon.html
ALIGNMENT:
CAR PULLS TO RIGHT OR LEFT:
https://mbworld.org/forums/w212-amg/...lls-right.html
ALIGNMENT AND EXCESSIVE TIRE WEAR DISCUSSION
https://mbworld.org/forums/w213-amg/...r-i-think.html
ALIGNMENT TALK:
https://mbworld.org/forums/w212-amg/...ps-please.html
MORE TALK:
https://mbworld.org/forums/w212-amg/...alignment.html
VACUUM CHECK VALVE REPAIR:
https://mbworld.org/forums/w212-amg/...ve-repair.html
https://mbworld.org/forums/w212-amg/...ml#post8637128
INTERIOR, ENGINE, CODES, AND OTHER ISSUES:
WAGON 3RD ROW RETROFIT:
https://mbworld.org/forums/w212-amg/...agon-done.html
AC SMELLS/ODORS:
https://mbworld.org/forums/w212-amg/...ml#post7751277
AC ISSUES: ac button blinking:
https://mbworld.org/forums/w212-amg/...ac-button.html
REPLACE STEERING WHEEL:
https://mbworld.org/forums/w212-amg/...ing-wheel.html
SHORTENED INTERIOR CHIME:
https://mbworld.org/forums/w212-amg/...ml#post7759205
MULTIPLE HEADLAMP DASH ERROR MESSAGES
https://mbworld.org/forums/w212-amg/...-messages.html
RESTORE LEATHER AND ALCANTERA
https://mbworld.org/forums/w212-amg/...storation.html
CLEANING ALCANTARA STEERING WHEEL
ALCANTERA STEERING WHEEL CLEANING
OIL FILTER HOUSING REPAIR
HOMELINK PROBLEMS
https://mbworld.org/forums/w212-amg/...-2012-e63.html
ECO NOT WORKING
https://mbworld.org/forums/w212-amg/...-go-green.html
MOTOR MOUNTS REPLACEMENT:
https://mbworld.org/forums/w212-amg/...ml#post8636360
UPGRADE MOTOR MOUNTS:
https://mbworld.org/forums/w212-amg/...-upgrades.html
MORE OPTIONS FOR MOUNTS:
https://mbworld.org/forums/w212-amg/...ne-mounts.html
BOOSTED BENZ MOUNT INSTALL AND REVIEW AND STEERING RACK DIY METHOD FOR MOTOR MOUNT INSTALL:
https://mbworld.org/forums/w212-amg/...nt-review.html
CRANKCASE VENT VALVE AND DUMMY FIREWALL REMOVAL TO ACCESS
ACCESS PCV AND REPAIR/REPLACE DIY:
https://mbworld.org/forums/w212-amg/...-pcv-unit.html
OEM VS AFTERMARKET WINDSHIELD
https://mbworld.org/forums/w212-amg/851653-oem-vs-aftermarket-windshield.html
AMG / BENZ ENGINE COVER EMBLEM
https://mbworld.org/forums/w212-amg/...ml#post8669586
AMG / BENZ ENGINE COVER EMBLEM 2
https://mbworld.org/forums/w212-amg/...ar-emblem.html
P0128 - ENGINE NOT GETTING WARM
THERMOSTAT STUCK OPEN (common)
https://mbworld.org/forums/w212-amg/...-warranty.html
CPO CRITERIA FOR WARRANTY WORK
https://mbworld.org/forums/w212-amg/...ml#post8186731
REAR FENDER/WHEEL ARCH OEM PROTECTOR
https://mbworld.org/forums/w212-amg/...ml#post8198260
BLIND SPOT INOPERATIVE
https://mbworld.org/forums/w212-amg/...operative.html
INTERIOR AMBIENT LIGHT UPGRADE
NAVIGATION MAP UPDATE
https://mbworld.org/forums/w212-amg/...ap-update.html
NEED A NEW M157 ENGINE?
https://mbworld.org/forums/w212-amg/...ld-engine.html
TIMING CHAIN, STRETCH, REVISION:
WANT TO CODE IN SOME NEW FEATURES?
https://www.mbhouse.ca/store/1-11.html
SHIFTER NOT SHIFTING INTO PARK - PARK BUTTON NOT WORKING
https://mbworld.org/forums/w212-amg/...errerid=317874
CENTER CONSOLE CUP HOLDER REPAIR
https://mbworld.org/forums/w212-amg/...ck-closed.html
ROOF RACK PLASTIC TRIM REPAIR
https://mbworld.org/forums/w212-amg/...pair-pics.html
CLOTH INTAKE TUBES GOING BAD
https://mbworld.org/forums/w212-amg/...going-bad.html
AIR INTAKE CLOTH FIX:
https://mbworld.org/forums/w212-amg/...pipe-m157.html
REMOVE BUMPER COVER AND GRILL
MORE REMOVE BUMPER VIDEOS
https://mbworld.org/forums/w212-amg/...mper-trim.html
ADJUST GRILL SPACING HOOD TO BUMPER
https://mbworld.org/forums/w212-amg/...ml#post7983699
STEERING BOLT RECALL
https://mbworld.org/forums/w212-amg/...ts-recall.html
REPLACE STEERING BUTTONS
https://mbworld.org/forums/w212-amg/...rts-china.html
CHANGING STEERING WHEEL TRIM DIY
https://mbworld.org/forums/sl-class-...m-install.html
FREQUENT KEYFOB BATTERY/DETECTION ISSUES:
https://mbworld.org/forums/w212-amg/...batteries.html
WINDSHIELD WASHER FLUID DELAY FIX:
HARDWIRE RADAR DETECTOR
https://mbworld.org/forums/w212-amg/...-bay-help.html
AL PRIORITY SYSTEM INSTALL/GETTING WIRES THROUGH FIREWALL
P0299 CODE
https://mbworld.org/forums/w212-amg/...ease-help.html
P0299 UNDERBOOST CODE
https://mbworld.org/forums/w212-amg/...ck-engine.html
P0299 MORE UNDERBOOST ISSUES
https://mbworld.org/forums/w212-amg/...-low-code.html
CHANGE VOLTAGE REGULATOR
https://mbworld.org/forums/w212-amg/867664-alternator-voltage-regulator-replacement.html
FUEL SMELL (not exhaust related)
https://mbworld.org/forums/w212-amg/...uel-smell.html
IMPORT CAR FROM 🇨🇦 CANADA
https://mbworld.org/forums/w212-amg/...adian-amg.html
WALNUT BLASTING
https://mbworld.org/forums/w212-amg/...ake-clean.html
REAR CUPHOLDER REPAIR OR REPLACE
https://mbworld.org/forums/w212-amg/...e-armrest.html
FOLDING MIRROR RETROFIT
https://mbworld.org/forums/w212-amg/...-retrofit.html
AFTERMARKET ANDROID SCREEN ISSUES
https://mbworld.org/forums/w212-amg/...t-working.html
Last edited by PeterUbers; 03-14-2024 at 03:46 PM. Reason: routine update and refinement
The following 23 users liked this post by PeterUbers:
1MBsleeper (01-05-2023),
a100steaksauce (12-12-2019),
BCP (02-10-2022),
Benzaddict32 (09-03-2023),
Bkman74 (11-28-2021),
and 18 others liked this post.
Received 1,003 Likes
E55, GLS450, GL63, GLE350
Nice, how much do you want to bet that some lazy poster looking to buy an E63 asks "what should I look out for before buying an E63?" before your posts leaves the fist page of the forum?
CPO issues
Hello guys I just became the owner of a W212 E63 AMG and had noticed a few issues within the first day...
First if I have what sounds like an exhaust rattle from the driver side when the car is warm.
Second the Tire Pressure monitor shows that 3/4 of my tires need air (I think because it needs more that 44
Third I am getting a malfunction Message for my suspension.
Can anyone chime in if they had similar issues?
2. Did all these things happen the day of delivery? It's cpo correct?
3. Your airmatic needs servicing - be glad you're under warranty!! Take it in, see the first post.
4. Driver's side rattle -- not sure ... can you hear it when you listen to the car when you're outside of it and listening to the underside of the car? Can you hear it in the engine bay when the hood is open?
1. What pressure do each tire have? You can reset the monitor to any pressure you set as the threshold
2) Exhaust rattle happened when I brought it home 40 min drive and had work after on a Saturday couldn’t go back
3.) My dads 2007 had several of these issues with the suspension its only the rears on this model correct? And yes thank god for warranty
4.) I can hear it with the hood closed but only after some spirited driving
The car is a CPO
1) Front 38 44 Rear 39 40
The car is a CPO
The car is a CPO
there is a tsb for this
reset your tire pressures in the menu system and you'll be fine ... rapid drops in pressure also triggers Warning and this could be due simply to temp changes
im 42 all around
E63 SL55 996TT C5Z06
Peter hey. How’s your traction with ESP fully off using the 42 psi tire pressure on all four wheels? I was at 44 all around and dropped the tears to 36 and trying to determine if that’s improved reaction (with ESP fully off)
So since I have ultra high perf all seasons I'm burning rubber at 42psi with all nannies off .. yikes!
Thx as always Peter for your feedback!
Anyone other than me have an issue with the front lower control arm press-fit bushing loosening up? It's actually loosened so as the arm slid forward, which is a bit unusual. No signs of impact either.
Anytime brutha-- also I figured that 110 F was terrible to take the 63's to dragaway or Byron so let's look at August September?
Just got mine replaced at 26k miles. Brought car in for new tires and complained that the steering wheel and gas pedal vibrate abnormally while driving on the smoothest of roads at 60-80mph and while stopped at a slight incline (such as leaving a parking lot). Vibrations were subtle but high in frequency, not normal idle engine feel. Thought it was engine or transmission mounts. They found bushing on left control arm had come out completely, replaced under ESLW and now back to normal.
MISFIRE discussion - bad coils
TURBO BOOST LEAK POINTS:
https://mbworld.org/forums/w212-amg/...ak-points.html
TIMING CHECK VALVE UPDATED TSB
https://mbworld.org/forums/w212-amg/...-valves-2.html
B&O AMP CUTTING OUT
https://mbworld.org/forums/w212-amg/...ier-b-o-2.html
VALVE COVER LEAK AND SEALANT REPAIR
https://mbworld.org/forums/w212-amg/...over-leak.html
KW HAS KIT INSTALL AND DISCUSSION
MISFIRE/RPM CUT OUT AT MODERATE LOAD
https://mbworld.org/forums/w212-amg/...ad-no-cel.html
ROOF RACK DISCUSSION
https://mbworld.org/forums/w212-amg/...your-rack.html
