Stinky smell after AC turn off
Old 06-24-2019, 11:47 AM
dtd
dtd's Avatar
2017 C300
My MY2017 C300 has a stinky smell in the cabin after the AC is off. I just got a 20K miles service at the dealer. What could be the problem? Your input is greatly appreciated.
Old 06-24-2019, 12:07 PM
C43Flyby's Avatar
C43
I was getting the same thing in my 43. I think it has to do with condensation from the cold air sitting in the vents after being shut off. Usually, I blow the fan at max with the A/C off for about 60 seconds as I'm approaching my destination and that seems to pretty much stop it from happening.
benzw205 (07-01-2019)
Old 06-24-2019, 12:20 PM
dtd
dtd's Avatar
2017 C300
Thank you very C43Flyby. I will try to see what happens. By the way, should the dealer fix it since, the car is still under warranty.
Old 06-24-2019, 12:24 PM
C43Flyby's Avatar
C43
Hard to say. If it's what I've experienced there isn't much they can do. If it's something else though due to something they did, then absolutely. I would try blowing max fan for a bit before you get where you're going and see if that corrects first.
Old 06-24-2019, 12:30 PM
dtd
dtd's Avatar
2017 C300
Will do.Thanks,
Old 06-24-2019, 12:48 PM
chrisdean's Avatar
W205 C200 AMG Line Premium
You shouldn't be turning the a/c off, just adjust the temperature to your liking and that way you will keep the system maintained and avoid any seals drying out and leaking.
Old 06-24-2019, 03:51 PM
Popoff's Avatar
2016 C300 4Matic Sport
Not so.
Need to turn off the AC (not the fan) a few minutes before shutting down to evaporate the condensation in the system that causes the smell. Another trick, in addition to turning the compressor off, is to turn the heat up as high as it will go for a few minutes. This old trick can also get rid of the smell if it already exists.
Old 06-24-2019, 04:18 PM
dtd
dtd's Avatar
2017 C300
Thank you all of you . I will try.
Old 06-24-2019, 04:31 PM
ygmn's Avatar
2015 E400 Sedan
Can of WURTH AC cleaner spray into vents and while system running into inside air intake...
Kills all the nasties
Old 06-24-2019, 10:22 PM
fabbrisd1's Avatar
Received 1,099 Likes on 805 Posts
A gaggle of MB's
My cent's - at 20K B Service - replacement cabin filter is "recommended" - check your Service Invoice to see if that was done - and review in your head what your Service Advisor asked/told you about that.
If you didn't report this issue before your 20K/B Service - and you didn't approve Cabin Filter replacement - then you have some good advice above so far - you can get your Cabin Filter done next service - recommended to use Auto set at comfortable temp for you - use Max Cool for max 10 min then switch back to Auto - don't leave your temp on manual too-low/too-long or that adds "frosting" to your evaporator and when you shut down the car that frost melts leaving evaporator box very wet/damp and leads to moldy/old-gym-shoe smell.
If you get to be in the land of the old-gym-shoe-smell - leave car running - windows up - max heat for 20 min will scorch that sh*t out.
Wurth or Einzett/Nextzett iboth are good stuff for system "cleaning" - and frankly as good as the MB dealer "bacterial cleaning" which they charge arm/leg for.
Old 06-24-2019, 11:27 PM
MariTheBoss's Avatar
2015 C300 4MATIC / 2017 C43 AMG
Fabbrisd1 is correct; set the air to auto at your desired temperature. This has been discussed at length, and of you search the forum there are some substantial explanations as to why the auto setting removes and prevents the smell. Replacing the cabin filter helped for a few days, as did an a/c treatment, but the smell returned. Once I set the air to auto at 67-72, the smell dissipated and has not come back in over a year.
Old 06-26-2019, 09:41 AM
CJG
CJG's Avatar
2016 C300 4MATIC
In the W204's there is a drip line that runs from the evaporator pan to the underside of the car. When ice melt/condensation drips off the evaporator coils it would allow the liquid to drain. This drain would plug on occasion and cause the smell.
I'm guessing the W205's also have a similar drain. Perhaps it's plugged.
Old 07-01-2019, 11:11 AM
benzw205's Avatar
benzw205
hello,
so it is really useful to stop aircon and only let the fan on ?
thank you.
Old 07-01-2019, 11:13 AM
benzw205's Avatar
benzw205
Originally Posted by Popoff
Not so.
interesting, I did not know about the heater. thanks.
W205_Merc's Avatar
2002 E55 AMG, 2015 Mercedes C300 4Matic
Originally Posted by benzw205
hello,
thank you.
After you use the air conditioning and are approaching your end destination.. a few minutes prior to turning the engine off... turn the AC OFF and let the fan run. do this with the temperature at a higher setting from where you were using your AC. When you do this it helps evaporate the condensation that remains in the air vents
I've had this same issue and the smell is ****ing gross. Try using FrigiFRESH or FrigiCLEAN.. its helped me out a lot.
Old 07-01-2019, 11:15 AM
benzw205's Avatar
benzw205
I really doubt that setting the system to AUTO would be better than blowing with air conditioning turned off for 60 seconds, can you explain please ?
Old 07-01-2019, 11:20 AM
dtd
dtd's Avatar
2017 C300
Hi benzw205,
I don't smell anything anymore. I did try what everybody suggested here. I think it works. My wife drives the car most of the time. I only drive from time to time during the weekend. The car has been in B service at the begiining of June, and the dealer changed the in cabin filter , that could be the reason of the bad smell. Before that, there was not bad smell after AC was off. I will monitor and let you know.
Old 07-05-2019, 06:35 PM
TexasBenzBandit's Avatar
2017 AMG C63, 2001 C5 Corvette
Did you cut one? I doubt that's it. OK then while you are at it, you should change your Cabin Air Filter if you haven't before (just ordered one today) and I wasn't aware of this until today, but lot's of good reviews on this stuff (or use similar)
Lubegard 96030 Kool-It Evaporator and Heater Foam Cleaner Lubegard 96030 Kool-It Evaporator and Heater Foam Cleaner
. When you do the Cabin Filter, there is a connection next to it with the glove box cover removed and you can run the hose up through there and try the foam. Apparently, it cleans and kills bacteria. I'm in a Hot Climate so we get more of the bacteria that causes things to stink.
Old 07-05-2019, 06:39 PM
dtd
dtd's Avatar
2017 C300
The cabin filter was changed at the B service ( 20K miles).
Quick Reply: Stinky smell after AC turn off
