Front jack point broken
As I found that my hydraulic jack was too short to lift the front of our ML320 (2007) at the center jack point, I lifted the driver side using it and tried to lift the passenger side using the OEM jack.
Upon lifting the passenger side, the jack point started to give in. Corrosion had crept between the pad and chassis.
Is there any known good fix to this issue?
Actually, the rubber pad itself is intact.
Above the pad, there seem to be a pack of thin metal sheets which have corrosion in between. Since the pad is available as a spare, I guess the pad needs to be pried off and the metal replaced or re-welded?
Front jacking point corrosion
Did you get a resolution to the problem as I have the same problem.
When the side steps are installed they cover the original jacking point so the side steps have their own jacking points. These jacking points can be purchased separately, not sure if left, right, front & back are the same part number, the pictures below are front right.
2007 ML63, 2008 CLK63 AMG Black Series
thanks @Ianmway, led me to the right direction
part numbers below:
Front Right - 164 698 13 31
Front Left - 164 698 12 31
Rear Right - 164 698 11 31
Rear Left - 164 698 10 31
part numbers below:
