2004 S600: Cyl 1-6 Misfire after 3 seconds of Starting Engine
Ordered my CP (from Clark) and bought a new VT (reman) from MB.
Installed all today and still the same miss. Cleared the codes, still the same thing. Starts up fine, after 3-4 seconds; CEL & misfire 1-6.
I did notice a tube with a vacuum hose coming off the right IC that isn't attached to anything. Could this be the cause, or am I chasing the wrong thread?
I haven't looked, but does SDS have an area to testO2 sensors & MAP sensors?
All help is truly appreciated!
I also plan to change plugs at the same time.
How can I tell if O2 sensors are bad?
1) You need to read the misfire code with SDS (nothing else will do it). If it shows Misfire 1 - 6 TWC DAMAGE, it means the ECU shuts that bank down to protect the cats.
2) You need somebody with the necessary skill to read the O2 sensors on that side "live" with SDS
3) if the O2 sensors are "off", you can change them, but sometimes you can you need to check the cats, and then you can shim the sensors "out" the improve the reading. (there are also shims available with their own catalyst values.) NOT from MB!
4) The transformer you installed MUST match the part number for your engine model; if not will not work right.
Good luck!
BTW: The above codes always clear on next start, and then reappear.
Misfire Listing
The red line is right O2 sensor
Upstream Engine On
Upstream Engine Off
Downstream Engine On
Downstream Engine Off
These O2 numbers look normal?
Car starts up fine, but then gets CEL and shuts off right bank after 3-4 seconds.
Fixed the vacuum leaks and got new spark plugs this morning before these pictures. So its safe to say those two items can be ruled out, on top of the new coilpack and VT.
Get some good Indie help; don't throw parts at it.
Good luck!
BTW: 2.7.1 is for M137; you should be 2.8.1 for your engine model M275 (I believe)
I was thinking of replacing O2 and then looking at the CATS for possibly being damaged or plugged.
I want to do as much as I can before sending it to the Independent.
Based on the pictures, do you think its upstream or downstream O2 causing issues; or both?
Thanks in advance!
I was told that it could be a bad ECU. I am trying to figure out how to check an ECU.
Also, https://mbworld.org/forums/w211-amg/...ispreloading=1
This sometimes seems to help
Thanks!
as well. Ai seems to think it could be a weak grond ? I will be adding more ground wires to see if that helps. Here is a picture of the vacuum box that sits under the intake manifold. Since I had them out already I took my injectors to get flow matched and found out that 2 of them needed replacing
Here is a picture of the two brackets that are a bit difficult to remove.
I recall that bracket which charge coolers mount to ect when replacing the 275 in my 221 car.
The intake manifold that feeds a pair of intake valves per hole is a thing of beauty inside. She is built to make huge torque.
