Whining/bearing sound from the rear. X166, GL350
Hi, need some advice.
My GL is marking bearing noise from the rear end at 40 km/h. Its increasing and at 55km/h i can hear whining sound. At 60km/h it disapears and comes again from around 80-100 but with much lower noise.
Noise appears only when accelerating. If i release the pedal sound stops immediatelly. All the oils in transmission are changed. Any suggestions?
Mulleage 150k km.
https://youtu.be/1EcDJA4agDw
Mulleage 150k km.
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Received 3,931 Likes
2017 GLE350 4MATIC
Something is not right in the driveline: propshaft, differential or halfshafts.
Whining means high speed, which means either differential or propshaft.
Is there any vibration noted? If you swerve relatively aggressively at highway speed (carefully with no one around you), does the noise change on one side or the other?
Could be bearings or gears in the differential.
thanks for reply. I have some very slight vibration sometimes on ~100-120 km/h. i thought it's wheels disbalance, but i can feel this slight vibration only some times. so wheels shouldnt be the case.
If I swerve - there is no change in that noise. on the highway this sound is really hart to notice so actually no chance to check if it's changing between the sides.
Bearings of gears shouldn't be as the same noise is while driving on any gear. main indicatior is speed.
Main problem is that it's very hard to diagnose such thing, but it's really annoyng and i dont know how much I can trust this car on long road trips.
2017 GLE350 4MATIC
Hi,
Tip in/tip out noise as you indicate means torque related. No side to side noise as you indicated means not the wheel bearings or halfshafts.
chassis (01-17-2022)
2017 GLE350 4MATIC
You said there is a vibration. This is likely propshaft related. Differential bearing and gear noise is high frequency audible, not a vibration.
It could be propshaft flex coupling, center bearing or u-joint.
Just got the diagnose from one of the repair centers. It's the transfer case making sound. They checked this one on the hydraulic car lift. There is DYNO mode on Mercedes, which allows to check such cases.
My question would be if anyone could help with precise part number of the transfer case for the X166 190kW GL350 without off road package.
It's not the turbo wastegate loose as when the car is not in gear, revving the engine does not produce the same sound.
Driving me crazy!
Did you ever get this fixed or find out what the part/problem was? My 2017 GLS 450 is doing the same thing. Slight/Soft grinding sound, only under acceleration at lower RPMs - doesn't matter which gear.
Driving me crazy!
Driving me crazy!
2013 GL350, 2002 ML320, 1995 E300D, 1983 E300TD-D
I had to do both the transfer case chain & rear wheel bearings. Both were pretty easy jobs. Transfer case chain & most all bearings can be done without removing the case. I just changed the chain about 100k miles ago, no bearings. Cobra transmission in FL has a complete rebuild kit for it.
