W223 Rear Battery Tray
Old 03-19-2022, 07:10 PM
Sleeper Benz's Avatar
W223 S500 LWB 4-Matic, W222 S450 LWB 4-Matic, W211 E500 4-Matic Wagon
To access the rear AGM 12V battery in the trunk you need not remove any fasteners. Simply open the hinged hatch. It can be suspended to the trunk lip by the plastic hook and lanyard. Then pull the felt covered molded plastic battery well cover rearwards and upwards. About halfway out, start to pull downwards on the cover where it pulls out from behind the bumper sill plate area. It's flexable enough in warmer weather as to not crack.
Looks like the tray is made of carbon fiber or fiberglass.
bishop64 (03-20-2022)
Old 03-20-2022, 07:46 AM
mbsl550.19's Avatar
2024 GLE 53 2023 GLA 252021 S580 2023 MB GLA 250, previous 2015 Porsche Turbo S 2014 Cayenne Diesel
I've done this a couple of times not easy to remove nor install. MB finally replaced by AGM battery under warranty. Think it
sat at the port too long. even though they may have charged it apparently it was not up to a full charge.
Old 03-20-2022, 08:54 AM
AGM Batteries are indeed expensive. The one in the photo says Made in Germany on top but there is a sticker on the the side that says Made in Czech Republic. I wanted to make sure the battery connections were good and see how much extra storage space would be available without the cover in place. Turns out, quite a bit more than the little recessed tub allows in the cover.
Old Today, 11:14 AM
EBRANGER's Avatar
1992 300E, 2023 S500
2023 S500 Battery Failing after delivery
@mbsl550.19 The same thing happened to me in the fall of 2022. My 2023 S500's battery would not stay charged a couple weeks after delivery. My car also sat at the port for a couple months due to some pricing issues. The dealership replaced my battery and it has worked properly since. I don't think they wanted to replace it though :-(.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Quick Reply: W223 Rear Battery Tray
