Another vibration thread ...
Hey all, have a 2011 350 4matic, have owned it for almost two years and have driven it about 40k miles since then, (has just under 170k total ... I think, I'd have to double check.) When purchased it had the GLK engine mount vibration but that was all that was wrong with it, it would vibrate at idle and then be glass smooth while driving at any given speed. I haven't gotten around to replacing them as it didn't affect anything other than idle vibration and it's never gotten worse or changed.
With that being said, a new, different vibration has arisen recently. This one starts at about 35mph and continues through to 45, but is almost non-existent between 37/38mph, and then is glass smooth again from 50-60~ and then an ever so slight, very minimal vibration when nearing 70. It changes with speed and is always the same at any given speed, (i.e. it's always the same amount/feel/type of vibration at 42mph and doesn't change; it's always really smooth at 55mph.) I'll note also that this only changes with speed and not engine rpm.
I've jacked it up and taken the wheels off to check wheel bearings, tie rods and ends, ball joints, suspension arms and struts, and everything is tight and unbroken. I had the front wheels balanced to see if that would help because it felt like it was coming from the front and if it did anything it was minimal, but I've been trying to diagnose it for a while and now I'm wondering if it's coming from the rear/center of the car. I'm taking the rears in to have them done but I want to be proactive in case that doesn't completely alleviate it either.
Has anyone had similar kinds of vibrations? My next stop was going to be the flex discs and/or center bearing or possibly changing out the diff fluids and/or doing a tranny flush?
170K on milage huh. Put the car Safely on stands and get under it and grab the front driveshaft (Near the Rear of the shaft where it goes into the T-case) and shake if back-N-forth violently. If it has Any play at all in Any direction, then you have a bad U-joint inside the T-case. Search "Front Output Shaft Failure" for 4Matic MBs and you will find the fix. If you have No play at all, you could still have bad bearings inside the T-case causing vibrations/sounds.
IAWMohror (01-26-2023)
Yugo26 (01-28-2023)
Or it could be the u joints on the drive shaft . As mine was. Don’t let it break if it’s bad, a broken front u joint can destroy the transfer case-transmission and the differential . One guy here paid mb about 10,000 to fix his Glk valued at 10,000.00 . Stupidly mb didn’t put in a brace to hold the front driveshaft, from becoming a weapon, incase the u joint breaks. Imagine a 2’ long 15lb piece of metal driveshaft flying around going down the highway! Destruction!
Edit: I think you might mean the same thing as stated above? Are there traditional u-joints on the GLK driveshaft? I've tried searching for replacements but come up empty handed, the only thing similar is the front driveshaft with the u-joint attached that goes in the transfer case, (I believe), like GLKattitude mentioned.
The one outside the transfer case went bad on me, I was stuck in snow shifting back and forth. I got a whole new driveshaft because it damaged a flange that’s not replaceable. My mechanic said if I hadn’t damaged the piece on the drive shaft he could have replaced just the u joint. But I don’t know if it is sold that way. Look a FCP euro for prices. The Glk is not heavy duty. The driveshaft is difficult to replace, maybe 3 hours. Mb wanted like 3000$ an independent wanted 1200, I got it done for 500.
Mercedes doesn't list the u-joint as a separate part. Sometimes this means it is "staked" in place and not held in with circlips. A drive shaft shop may or may not be able to replace it, but it's not a job for a DIY mechanic.
Ah, thank you for that answer.
I've restored airplanes from the ground up and built race cars and there are a couple things I hate with all my being: diagnosing; obviously finding it before it breaks is way cheaper but I hate the 'hunt' with every fiber of my being. And after doing it for so many years I've slowly started to despise even the work, I can only say that I still do it myself because I don't want to pay someone else. All of this exacerbated when it's a daily driver and not a project or fun car.
The following 2 users liked this post by IAWMohror:
AllPhonesAretap (02-06-2023),
calder-cay (01-26-2023)
2014 GLK350 base model ; 2001 E320 base
Another well thought out MB design, first there is no bracket to keep -hold in place, the front drive shaft from putting your Glk into the junkyard with 10,000$ in repairs , if the front Ujoint breaks, but if you need to replace a bad U joint you need to buy the whole driveshaft! MB will charge you about 3000$ for what would normally be only a few hundred $, on most drive trains . Really well thought out! Thanks MB. It’s things like this that ruin used Glk values.
calder-cay (01-27-2023)
The following 2 users liked this post by GLKattitude:
IAWMohror (01-27-2023),
Silver Shadow (01-27-2023)
Well one has to get the whole "I have to go to the MB dealership blah blah" mentality out of their system. There are Indy repair shops in every town and tons of Youtube vids on how it fix this stuff if One is so inclined. Or..I guess you can just run around scared s#$tless about high repair bills I guess.
But yeah, replacing the front driveshaft doesn't seem bad at all and even a brand new cheap replacement is only $200-$300.
But are you sure it's not wheels or tires? Are you on 19 or 20 inch tires? When I balanced my original 20 inch wheels the tire guys says none of them are straight, but they still balance. When I have certain wheels up front I get vibration. My friend also had weird vibrations on Q7 that was simply due to old tires.
Another thing is suspension bushings can be worn and causing vibrations at certain speeds. On my 911, front bushings would cause pretty bad vinbration at 60mph, I'm not sure who GLK's worn bushings affect things.
Lastly, failing transfer case produces more of noise/whine above 30mph than a vibration.
Curious what you will narrow it down to.
IAWMohror (01-31-2023)
Not sure, no garage and there's snow everywhere so I'm checking it out this weekend. Thursday I'll have flex disc's, center bearing and front drive shaft here just in case. Might as well do all of it and not have to worry about any of it later. I have another car so if it is the t case u-joint it can stay parked until that arrives.
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350, 2003 E320
Check to see if your local dealer has an online parts order site. Mine does and parts prices are mostly the same as the online MB parts sites (25-60% discount). Plus since they’re local, parts can be picked up at the counter with no shipping.
Or you can try https://mbparts.mbusa.com which will direct you to the nearest dealer online order site.
IAWMohror (02-01-2023)
Welp, looks like that's it. I grabbed the shaft and there's no front to back or much play of any kind but that's a lot of u-joint dust.
It'd be interesting to read what others think.
I’m not familiar with the internal construction of this u-joint. But similar ones keep the bearings healthy by sealing lubricant inside. I think it was mentioned that this u-joint can’t be disassembled. Maybe double check for play with a pipe wrench on the shaft?
It's an off-the-shelf u-joint, sometimes called a cross joint, or cross u-joint. the problem is the way it's installed in the yokes. It's staked in place and most drive shaft shops won't touch it. If you're concerned, unbolt it from the flange and move it by hand, checking for smooth operation.
