Intermittnet EDU problem
AMG C63 2015
Hi,
Have had this happen on two occasions on my 2015 AMG C63 (normally aspirated V8): 1st occurrence: Hit a shallow puddle (very shallow, not much splash). Warning signals came up on the dash about all the proximity-related sensors/functions, and the big issue: I lost throttle. Punch the pedal, sits around 1500 RPM and doesn't change. Pull over, turn everything off, restart the car, problem disappears. Stayed that way for months. Then, #2: Went over a slight bump - an expansion joint on a concrete roadway. Same thing happened.... Anyone have ideas of what the issue is? Thinking an intermittent short in either the ECU or a cable/connector issue in that neighborhood. Thoughts, Ladies and Gentlemen?
