wheel size question
wheel size question
Hello everyone, I just bought used rims because the ones on my car are corroded. While installing them, I noticed that two are 8.5jx 18h2 et49 and the other two are 7.5jx 18h2 et44. The four I had in my car are 8.5jx 18h2 et48. My car is a 2010 e350 4matic.
Can I still use the ones I got? Can I mount a new set of 245/40 r18 that I already have? Or should I just keep the ones that were installed? Thanks.
2014 Cummins, 2014 E250 Bluetec
I believe the ones you got are offset for the rear wheel drive cars. The 4matics have same size all around. People get away with a certain amount of difference but you would have to search what that is and take it upon yourself to deal with possible negative outcomes.
As far as a new set as long as it has proper dimensions like off set and such you would be fine, 18" is fine but not sure about the rest
