E53 Exhaust Valves
E53 Exhaust Valves
Hi all,
Ive only had the E53 for a month and still learning stuff.
My car comes with the performance exhaust as standard, and when you put the car into powerful exhaust looking through the tape pipes I can see the valves are open.
I read somewhere that the valves only open after 4K revs. Is this just on comfort? Or just on the non performance exhaust?
Im just trying to work out if I need a valve module, or I can just have powerful set in my Individual profile to keep the valves open.
Received 2,302 Likes
PFL205.064 with M276.823
Hi all,
To have them fully opened, the valve module you mentioned or EVM, exhaust valve module is a good option. Alternatively, if you want them open all the time, you could try exhaust valve bypass-plugs but every time you want them closed, you need to open it manually.
If you want your exhaust valves opened to 100% all the time with the option to hit a button to return to OEM, while also making $800 disappear, this will do it:
https://www.renntechmercedes.com/ind...490-213-detail
