S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
1990 300SE starts and dies
Old 05-31-2024, 07:42 PM
jlee4171's Avatar
1990 300SE
Hello MB experts. I need help identifying the problem with my car, with only 116k miles, car drives fine once it gets going, no rough idle or stalling issues. Car starts fine with engine cold (like first start in the morning), and car starts fine when engine is relatively hot (like after stop at gas station or a quick meal). Car normal idle is around 800 rpm. The issue is after running the engine and let it sit for about an hour or so, temperature gauge dial drops from 80C to about halfway down to the bottom (like about 60C), that's when it will start and dies immediately. It usually starts on the second try, but one time it took me 4 or 5 tries to get it started. One thing I've noticed at a cold start (like in the morning), the idle remains pretty low at around 800 rpm, I thought the choke(?) would keep it at a higher rpm like above 1000 rpm or so, then drops down to normal running temperature after engine warms up...but not sure since I am not familiar with the Mercedes car choke function...maybe that is normal?? Previously I posted the same question and someone pointed out it may be the Fuel Pressure Regulator, and advised to keep the key in position 2 a little longer before cranking, I've tried numerous times and it didn't seem to help. I am thinking it may be related to something like the idle control or something to do with the choke, any ideas? thanks in advance.
Old 06-01-2024, 10:22 AM
HedonisticFrog's Avatar
1996 S420, 2001 SLK320
There's no choke on a KE jetronic system for starters. If you think it's fuel pressure related then you should get a fuel pressure tester and see if the fuel pressure is dropping when it's acting up. I just had a somewhat similar issue with my 1987 420SEL where it had difficulty starting, the idle wasn't stable, and it would hesitate under acceleration which turned out to be a bad engine ground. It's a quick easy thing to check, bad grounds will give you weird symptoms.
Old 06-01-2024, 10:47 AM
jlee4171's Avatar
1990 300SE
Thanks HedonisticFrog. So in the morning or when engine is cold, is your idle speed stays at a higher rpm than the normal running rpm, or is it like mine that keeps it at about 800? I don't remember the last time my engine stays at above 1000 rpm during cold start.
If it's fuel pressure related, why is it only acting up when engine cools down, and not an issue when engine is completely cold, or hot?
Old Yesterday, 10:10 AM
JohnLane's Avatar
222 S-65
OP worth checking is ‘false air’ AKA vacuum leaks. A smoke machine is most effective for finding them.
Old Today, 03:38 AM
adler's Avatar
check ldle control valve . Clean with cleaner spray ,if dirty it will be erratic
Idle
Quick Reply: 1990 300SE starts and dies
