Ac blowing in one vent
Why is only one of my vents blowing cold air the others are blowing relatively warm compared to that one I just replaced the blower motor and the cabin air filter
Probably a stuck or broken blend door actuator. Try moving temps way low and way high several times to see if it loosens it.
did it like 20 times still same and also the car has freeon and the ac is just not freezing like it should be I also own a 2008 Mercedes c300 and it gets so cold I have to turn down the ac this one does not do that
Do you have a diagnostic tool to read the codes? I forgot, also try moving the air around from the various vents too. I know you probably already did that but just want to be sure.
The following 2 users liked this post by wildta:
CaliBenzDriver (07-28-2024),
juanmor40 (07-29-2024)
If the coil provides cold air for one vent it means it provides it also for all vents that the system settings ask for. It is NOT about low refrigerant in the A/C system, It is about the air flow mixer valves that control air temperature coming out of the vents.
There is only one evaporator coil for the A/C to cool the car unless you have the dual system that I think has another one for the rear passengers.
