SL/R129: 1991 SL500 R129 Low Rough Idle and Dies on Acceleration
Just picked up this California clean car that doesn't roll. It starts with super low idle. If I try to step on gas peddle it dies. If I manually press down on air flow meter it idles fine. If I manually throttle and press down on air flow meter it revs fine. When cold I need to initially give it a lil bit starting fluid. If keep spraying it idles higher. I don't know if it's electrical
I checked following:
- checked fuel presser at prime and run at fuel distributor.
- vacuum leaks
- cam sensor
- cleaned and checked OVP valve.
- OVP relay fuse
- all other fuses
Assuming this is the old KE-Jetronic fuel system have you checked the duty cycle at idle and at 2500 rpm.
Does it stall both when engine is cold and hot?
RobGT (Today)
